Question about FUJIFILM Cameras
HOW CAN FLAS OFF IN FUJIFILM CAMERA
FUJIFILM A170
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • FUJIFILM Master
  • 102,366 Answers
Press cursor-right (marked with a lightning bolt) then select the lightning bolt in a circle with a slash through it.
See page 22 of the manual: http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/a/fujifilm_a170_manual_01.pdf
Posted on Apr 19, 2014
  • 11967 Answers
SOURCE: i have just bought a fujifilm a170 digital camera.
A new card must be formatted in the camera to erase and optimize it for the camera.
Posted on May 06, 2010
  • 166 Answers
SOURCE: FUJIFILM A170 Digital Camera
check to be certain the battery is holding a charge, is inserted correctly, make sure the SD card is inserted correctly, IF it is holding charge and card is in correctly is the card full? if so empty it. if you have a SD card slot in the computer see if there are photos on the card if you dont have one in your computer and the camera hooks to the computer DONT DO IT! take the card to walmart, walgreens or somewhere they can see if something is on the card. we are trying to see if its a battery problem a card problem or a Camera problem. if the card is good and has no photos then put it in the camera and asuming the menus come up then format the card. try taking photos if this works great if not see if a friend will barrow their card to you to try in your camera make sure again that their card is BLANK otherwise if you have a bad camera it can blank their card too and you are SOL. try online and search for the model and see if you come up with others that have the same problem. read the manual and if you dont have it do a manual search for the camera model.
Posted on Jul 22, 2010
ginko
  • 19396 Answers
SOURCE: I have a fujifilm A170
Hi.
Test the camera using a 2GB memory card. Depending on firmware version the camera will accept only 2GB. Most models accept up to 4GB.
If that is not the problem, try formatting the memory card (try also with old malfunctioning card.
Instructions on how to format the memory card can be found at page 73 on the manual available below.
Here the user manual.
Regards.
Ginko.
Posted on Nov 15, 2010
SOURCE: The lens of my digital
Please clean your lens!!
best regards!
Posted on Dec 22, 2010
Testimonial: "thank you very much"
caroldon
  • 17129 Answers
SOURCE: blank screen when turning on
The display being black can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the display is not seen, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the camera aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Please click on the link for tips to replace a LCD
http://www.youtube.com/watch?v=aB4x7F5Chow
Thank You for using fixya
Posted on Sep 21, 2011
HOW DO YOU REMOVE A PHOTO FROM THE CAMERA TO THE COMPUTER WITHOUT A MEMORY CARD
Without a memory card in the camera, connect the camera to a computer.
May 09, 2014 | FUJIFILM A170 Digital Camera
Need driver for computer
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Apr 22, 2014 | FUJIFILM A170 Digital Camera
I have a fuji A170 digital camera i have 256
All of them will work just fine. The main difference is that a larger card will let you take more pictures.
Sep 20, 2013 | FUJIFILM A170 Digital Camera
How can I reset my FUJIFILM A170 Digital Camera to factory settings without turning it on?
Remove the battery for 15 mins. replace the battery then go to the camera's Menu to set the Date & time.
Oct 18, 2012 | FUJIFILM A170 Digital Camera
Copy photo from FUJIFILM A170 SD card
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
If you're asking how to copy the pictures from the card to somewhere else, please reply to this post and specify to where you'd like to copy the pictures.
Sep 11, 2012 | FUJIFILM A170 Digital Camera
I want to repair my fujifilm camera from minor problem, please help me.
To repair digital cameras you need a philips screw driver #000. Buy parts cameras from ebay to replace in your camera. To keep it in good condition store camera in ziplock bag when not in use. Remove batteries too.
Dec 22, 2010 | FUJIFILM A170 Digital Camera
I bought a fugifilm a170 ..my problem is that the cd i installed is in spanish as i bought it in spain..how do i change the language to english??
You can download English-language software from the manufacturer's web site at http://www.fujifilm.com/support/digital_cameras/software/
If you need an English-language manual, you can also download that from the manufacturer's web site at http://www.fujifilm.com/support/digital_cameras/manuals/#a
Jun 05, 2010 | FUJIFILM A170 Digital Camera
Cameras Logo
Top FUJIFILM Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
