Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
How do you remove nozzle window on bissel carpet cleaner model 8804
SOURCE: bissell model 8910 carpet cleaner
Depending on which style you have, it may have a opening on the right side as you look at the front of the machine. If not you may need to remove the cover. If it does it says "belt access" and has two 1/8" (about) slots in the cover. with a small screw driver or something similar insert tool into slot and gently pry(if you are looking from the side) the left slot up and towards the right and the right slot up and to the left. It will slowly (or quickly depending on how hard you have to push) pop up and you can slide it off and see the pump. I think it is easier to just remove the 4 screws that hold the pump in place so you can replace both belts at the same time and not struggle with having to stretch the new belts. The last time I did this the Sprocket(small metal peice with teeth that turns the brushes) had broken off. I cleaned and dried everything and used 30 second epoxy to glue the sprocket back on and it works fine lasts a long time. Once you have removed the 4 screws holding the pump you can use a flashlight and screwdriver, knitting needle, pen etc. to hook the belt from the brush on to the pump shaft(sprocket) very easy. You may need to tilt and angle the pump a little to gt the belt over the lip on the sprocket. Like I did when I did this you will need to put the smooth belt on over the pump shaft first then put on the brush belt and screw the pump back into place (4 screws just snug because you can easily strip the plastic mounting holes) and put smooth belt on the electric motor shaft. you may need to stretch the belt a little because it has no gears it is just friction that turns the pump. Clean and dry everything this will make this repair last longer. If you will take a few minutes after each use to clean at least around the belt area they will last a long time. You can even put a belt conditioner on them for added life. Have a wonderful day!!!!!
Posted on Nov 10, 2007
  • 184 Answers
SOURCE: bissell carpet cleaner won't spray water or cleaner
If I may! In most cases the heater is clogged. It might be clogged with soap that has harden over time. You need to take the handle apart. You will see a metal box(thats the heater) besides the wires there are two tubes connected to the heater. remove the tubes but label or watch which tube goes where. now turn the heater upside down. there are 6 screws on the side and 1 in the middle. remove them carefully. the 6 on the side have a small gaskets under them..you don't want to lose them. the 1 in the middle has no gasket, now the bottom plate of the heater can be taken off (there is a gasket with that plate ...be careful . you will now see the long channels inside the heater and need to clean it. the holes where the tubes where connected have to be clean also but carefully. the metal is soft.so it bends. now put it all back. hope this helps. if you want to keep this from happening.the best way is to run clear water after you are done.this will remove any soap in the machine which will harden after the machine drys out. hope I helped .
and to mr. reddevil6 I am learning lots from you. Thanks
Posted on Feb 13, 2008
SOURCE: schematic parts diagram for bissell proheat 9200 carpet cleaner
http://www.nelsonappliance.com/bissell+proheat2x+parts.asp
hopes this helps, they also have parts, but shop around.
Posted on Jan 08, 2009
  • 29 Answers
SOURCE: bissell carpet cleaner brushes won't turn
Make sure you have released the handle, as if you wanted to push the machine forward. If the handle is locked upright, the brushes do not spin.
If they still don't spin, you may have a broken belt. Look carefully at the base, on each side. As I face the front of mine, on the right side of the machine, a small belt goes around one brush and a small cog wheel. On the left side, a larger belt goes around both brushes. If either belt is broken, the brushes will not spin. This can happen if you let gunk build up inside the clear plastic side pieces or around or above the brushes. It's very important to constantly be cleaning your Bissell. The belts can be ordered online and replaced. See your owner's manual.
Posted on May 29, 2009
  • 25 Answers
SOURCE: Bissell carpet cleaner not sucking up.
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Posted on Apr 24, 2010
Not sucking up the water
Look at the pickup nozzle to see if it's plugged up. There is a flapper valve that closes when the tank has too much water in it. Make sure it opens after you dump the water out.
Aug 14, 2016 | Bissell Carpet Cleaner Powerbrush Deep...
How do i replace rubber casket on my upright bissell carpet cleaner
get make and model of the bissell cleaner and go to http://www.bissell.com/parts/ find out what part you need and order most likely the gasket is not that costly through bissell if it is you can always do a price comparison check ebay i find most items on ebay for reasonable prices. so long as you have a part number you are good to go .. hope this helps
Dec 24, 2014 | Bissell Upright Carpet Cleaners...
No suction on my Pro heat steamer
You may want to check to see if the removable nozzle is correctly placed into its place. This is the plastic part where the water is sucked up through by the carpet cleaner. The nozzle notches must fit into the groove on the cleaner correctly and the metal bar need to snap back on top of the removable nozzle, Also sometimes if you have hair trapped in the nozzle or the bristle, it will affect the suction power of getting up the dirty water. The dirty water tank need to snap in place by making sure the top of the gray snaps on each side is over the top groove of the dirty tank on each side and the the gray snaps are pushed down and pushed into the tank to until it is snapped in place.
Super Simple answer could be: The Dirty water tank could have bubbles in it causing it not to **** too.
Mar 03, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
My power steamer model 1697, 8804 series doesn't **** up the water
I filled up my Bissel power steamer with hot water. I also filled up the formula mix. It turns on and sprays. The "dirty" water was seen the first time I used it. Now there the clean water is on the carpet and no dirty water is in the tank what"s up???
Jan 01, 2011 | Bissell 1697-7 Powersteamer Pro Deluxe...
My carpet cleaner bissell pro heat wont extract the water from the carpet
1) Remove the Tank-in-Tank Assembly and place your hand over the motor intake valve. This valve is located next to the Floor Nozzle gasket (at the top of the Floor Nozzle window) and behind the SmartMix Bottle. If you feel vacuum-like suction at this area, your suction power of the unit is working but air is escaping at some point. If there is no suction at the motor intake valve your machine will need to be inspected by an Authorized Service Center Technician.
2) It is possible the Floor Nozzle on your machine is inserted incorrectly. This would directly affect the suction of your machine. Please follow the directions below for removing and replacing the nozzle.
Before starting, please be sure the machine is unplugged and the machine handle is reclined.
To remove the Floor Nozzle window, first detach the Phillips head screws located at the base of the nozzle. Then, remove the Tank-in-Tank Assembly. Next, pull forward at the top of the Floor Nozzle window to release the tabs of this window from the receiving holes of the machine. This window is designed to allow access for cleaning.
When replacing the Floor Nozzle window, please be sure the tabs at the TOP of the nozzle are properly inserted into the receiving holes provided. If you do not have the tabs in place properly, the suction power of the machine could be affected.
Rotate the window down into place and replace the screws.
3) Ensure that the Ready Tools knob (diverter knob) is in the proper setting and the valve opens and closes freely. Ensure the black foam gasket is in place under the valve.
4) Check to ensure the Tank-in-Tank assembly is seated properly and that it is not full of dirty water. (If this tank has a drain cap, make sure it is in place and that it has a black o-ring).
5) Check the float and baffle to ensure they are properly installed on the Tank-in-Tank. The larger square portion of this part should be below the clear baffle of the tank with the red flag portion of the float resting on top of the baffle.
6) Check the Tank-in-Tank and lid for damage. Is the lint screen clogged? Make sure the lint screen is in place on the tank lid and not placed into the motor duct. Also, clear the holes on the lint screen.
7) Check to see if the upholstery hose has suction. If the hose has suction and the floor nozzle does not, check the diverter valve to see if it opens and closes freely. This can be seen through the Floor Nozzle window as you switch the diverter knob from the floor to tools setting.
If these suggestions do not solve the problem, please have a technician at a local BISSELL Authorized Service Center inspect your machine. BISSELL supports your machine with a one-year warranty for any defective or malfunctioning part.
Nov 22, 2010 | Bissell 8910 ProHeat Clear View Upright...
Unable to attach nozzle and cleaner will not **** up dirty carpeting.
Contact BISSELL Consumer Services, they will be happy to walk you through the process over the phone.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Aug 13, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do I clean the hoover steam vac floor cleaner machine
Nozzle Clean Out tool is NO LONGER AVAILABLE from Hoover. Hoover stopped making this part over 1 year ago, and it's not sold any more. What you'll need to do is remove the dirty solution thank, unscrew the one silver screw on the suction port of the clear window, then turn the machine upside down and remove the two silver screws on the bottom corners of the see thru window. This will then allow you to completely remove the see thru part to clean inside of it. Unfortunately with this model that's really the easiest way to do it now that the tool is no longer available.
Apr 18, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I have an older model Bissell rug shampoo machine, model # 1631. I have several bottles of Bissell 5 One carpet formula to use in this machine, however I have lost the measuring bottle that tells me the...
I have a older mod. Bissell carpet machine plus mod. 1630-5 and need a floor nozzle part num.013-6194 and grip tube w/button part num.014-4181 and trigger part num.010-9406 and tube
Mar 22, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Powersteamer 1697, 8804 series, Smartmix will not despense cleaning solution
there is usually a button or release lever by the handle that u sqeeze to release salution
Jan 22, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell proheat 7 will not spray water or cleaner
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!! g
Jun 05, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
37 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
