Question about Acer Aspire Computers & Internet
Fixing mobility center for windows 8..what is the compatible application for acer laptop
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 94 Answers
If mobility center is not working corretly, you can remove it from add/remove programs and reinstall it from Acer download page.
Posted on Jun 04, 2014
2 Suggested Answers
xxlightzoutx
  • 53 Answers
SOURCE: how do i turn on my wireless connection?my laptop
their should be a button that looks like a Antenna Tower usually blinking while the computer is running. Also in your bottom right status bar it might be running check for that as well and if that doesn't work check your network connections under mycomputer/control panel/ Network connections hope this helps!
Posted on Jul 26, 2009
You'll want to get the specific model of your Acer laptop from their website before anything else.
Generally speaking, laptop makers now have software you can download which will work with Windows to repair particular sections of the OS. Given the model number of your laptop, which can sometimes be determined by small scripts you download and run from your browser, the manufacturer will link you to the appropriate support software.
Apr 18, 2014 | Acer Aspire Computers & Internet
Turn on Network and Sharing Center Acer Aspire 4720z
You need to install the drivers for those components. GO to the website of your computer's manufacturer and install the updated drivers for those hardware and make sure that the drivers are compatible with windows 8.
After installing all drivers, make sure to keep them updated so that you can avoid from getting any problems. Install RadarSync if you want to automate the driver updating mechanism of your computer.
I hope this helps!
David
Feb 18, 2013 | Acer Aspire 5610-4648 Notebook
Acer aspire crashes and to reboots when i try to record video game footage
There is a good chance of still getting a blue screen with a OS upgrade. You should try a clean install. Then try testing the RAM. Leave one DIMM at a time and swap to one slot at a time. This may help identify a bad one.
Jan 30, 2013 | Acer Aspire Computers & Internet
Can you please tell me where the switch is to turn on my wireless on my acer Aspire 4720Z
to turn on wireless network connection you should launch windows mobility center,follows steps below
  • Use the shortcut key <windows key > + <X>
  • windows mobility center will open (start->control panel->windows mobility center)
9a3ae1b.jpg in wireless network segment click turn ON button
Jun 13, 2010 | Acer Aspire 4720 Notebook
CrystalEye Webacam error
Go into control panel>uninstall a program and then select the application from the list. Look for a repair button towards the top of the screen. If that doesn't fix the problem you can try updating the program, and if that still doesn't fix your problem, you will have to re-install the program. If you upgraded from a previous version of Windows to Windows 7, it could be a compatibility issue.
Dec 26, 2009 | Acer Aspire 5610-4648 Notebook
May i change my laptop acer aspire 5680 WLMi with window 7
Sure, because your laptop configuration complete the minimum requirement for windows vista or
If we are unsure of an application compatibility with Windows 7, the following Microsoft link provides searching capability to identify if a specific application / device will work with Windows 7 or not:
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
thanks and best of luck.
Oct 26, 2009 | Acer Aspire 5610-4648 Notebook
Keyboard stops responding after a powersave on laptop ACER 5715Z
The issue is that several of the Acer software products don't support Vista. You need to remove these programs.
Follow the instructions in this link
http://global.acer.com/support/winvista/t-faq.htm
Due to architectural changes to Windows Vista®,some Acer applications are not supported anymore. Below is a summary ofthese applications. Uninstall these applications before the upgrade.
Acer eRecovery Management The new version of Acer eRecovery Management, which is compatible with Windows Vista®,requires repartitioning your hard disk drive, causing data loss. As aresult, the Wizard will not reinstall the new version of eRecovery onyour computer under Windows Vista®. However, you will be able to find similar features in the built-in Backup Utility of Windows Vista®, including full system volume backup to a HDD or CD/DVD. Acer eAcoustics Management Windows Vista® supports similar functions of eAcoustics so Acer will no longer provide this utility for Windows Vista®. Acer ePresentation Management You can easily manage your external monitor settings via Windows Vista® Mobility Center. As a result, we do not support an upgrade to Acer ePresentation Management. Acer ePower Management Due to architectural changes to Windows Vista®,Acer ePower Management cannot be upgraded for some models. However, youcan easily manage your power settings via Windows Vista® Mobility Center instead. Acer ePerformance Management For notebooks only. Since Windows Vista® provides similar resource management functionalities, we will no longer provide this for notebook models with Windows Vista®. Acer Arcade™ Deluxe 3.x
Acer eNet Management 1.x
Acer eDataSecurity Management 1.x Due to architectural changes to Windows Vista®, these applications cannot be upgraded.
Alternately (not recommended) you can change your settings with the following method. I would recommend removing all the Acer software though as keeping them might cause problems.
Check under Advanced Power Options-> Multimedia Setting -> When Sharing Media. By default onBattery and Plugged is set to "Allow the computer to enter AwayMode" Changing this setting to "Allow Computer to sleep" should solve theproblem. On Battery the Away Mode "does" allow the computer to sleepproperly.
Jan 27, 2009 | Computers & Internet
How to switch on bluetooth on acer aspire 5920
Windows Mobility Center also includes Acer-specific settings like Bluetooth Add
Device (if applicable), sharing folders overview/sharing service on or off, and a
shortcut to the Acer user guide, drivers and utilities.
To launch Windows Mobility Center:
Use the shortcut key <windows> + <X>
Start Windows Mobility Center from the Control panel
Start Windows Mobility Center from the Accessories program group in the
Start menu
Oct 20, 2008 | Computers & Internet
Navman N40i compatability with Vista
Solution to get GPS Navman N40I working with Windows Vista.
I solver the problem (most of it) by uninstalling the old activsynk witch was delivered with the manufactory CD. Then I downloaded from “http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-center.mspx” Windows Mobile Device Center. After installing this software I connected my Navman N40I to my PC and waited to for the Mobile Device Center application to load. When it tried to gain partnership with my GPS I removed it. Voila, and the SmartST Desktop 2006 SE application was able to communicate with my GPS.
Hope this will help you!
Kind regards
Mega A
Sep 24, 2008 | Navman NavPix N40i GPS Receiver
How do I turn bluetooth on and connect a Mobile phone to a Acer Aspire 5710G
Windows Mobility Center includes Acer-specific settings like Bluetooth Add
Start menu
You should be able to turn on blutooth from there.
Please let me know if this helps.
Mar 17, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
