Question about HP LaserJet M1120 MFP All-In-One Printer
Scanner error 20
I am getting scanner error 20 on my hp printer suggest me what is the solution for this problem
    New Friend:
  • 6 Answers
Upper scanner gear or motor fault, or may be scanner cable fault. so check it.
Posted on Aug 14, 2017
seeker5211
  • 1089 Answers
SOURCE: HP Laserjet M1005 MFP scanner and printer shows
The job that you are trying to print is too complex for the printer. Add more memory. Or simplify the job.
Posted on May 17, 2010
seeker5211
  • 1089 Answers
SOURCE: I am getting scanner error 5 massage on hp 2840
A tech needs to look at it. It could be as easy as just reseating the 4 wire bundle connector that comes off the scanner and connects to the formatter.
But, in any event a tech has to check it out.
Posted on Jul 29, 2010
sandimcp
SOURCE: Scanner Error 5 "error message" on my all in one
I had this problem and it had to do with the scan bulb head not recognising the marker. My temporary fix until the bulb is replaced is to turn the printer off, open the top (ADF and all) with the gray button on the right so that it's slightly raised and then switch the printer on. When it comes up, just close and print/scan/copy as usual. Apparently the spring in the arm warped the interior surface where the head moves and it can't line up when it's closed. Hope this helps.
Posted on Sep 01, 2010
  • 8 Answers
SOURCE: Printer Model : HP Laser
indicate that the scanner unit are error.reseat the flexible cable in the scanner unit.
Posted on Nov 23, 2010
SOURCE: SCANNER ERROR 20 of HP LASERJET M1120 MFP
PRINTER: HP DESKJET M1120 MFP DISPLAY SCREEN SAYS; "SCANNER ERROR 20"...
ANY IDEAS HOW TO FIX?
MANY THX!
Posted on Feb 04, 2011
HP Laserjet M 1005 Scanner error 20 solution.
Hp are tricky scanners to install and setup. You need to unplug the USB cable, power on the scanner and begin a fresh setup.
Let the software tell you when to reconnect the USB cable to the computer. Let it finish setup and reboot computer. Once in windows, the setup will complete automatically.
Go in START menu and click on the HP Solution Center in the HP folder to activate the scanner.You can't jsut press the SCAN button on the scanner. It won't work. You need to start the software first or use Photoshop.
Also, the way to fix this Error 20 is to first ensure that your HP Printer is set up to be the default printer on your PC. It's often the case that the printer you have on your system will either not be the default, or will have some sort of error that will prevent it from being properly used. You should click onto "Printers & Faxes" on your system and then right click onto your HP Printer, and select "Set As Default". This will allow your PC to use the printer every time you print,removing some confusion.
Make sure you have enough HD space to install as this can contribute to the same error 20 code.
Dec 12, 2014 | HP Office Equipment & Supplies
My 1005mfp HP printer scanner error 20 how I
More Help... HP LaserJet Error Codes and HP Printer Support
Thanks,
Sep 19, 2014 | Office Equipment & Supplies
I have error 50.22.00 in my Hp M602 printer
Error: 52.XX.00 Error To continue turn off then on
Error Description: Laser/scanner error ? XX = 00 laser/scanner motor startup error ? XX = 20 Laser/scanner rotation error
check your printer scanner assy. need technician support.
Oct 08, 2013 | HP LaserJet 600 M602DN Laser Printer - M
Hp 1005 Scanner error 20 please suggest the problem
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
If a surge protector is being used, remove it. Plug the device directly into the wall socket.
Use thepower switch to turn the device on.
Jul 08, 2011 | HP LaserJet M1005 Printer
Please solve the details hp scanner error 20?
Are you getting this error printing a certain file or all files?
The reason I ask, according to my research this error is cause by a memory overload and they suggest lowering the DPI/resolution of the file.
I wish I had a more clean answer.
I hope this helps.
Best of luck!!
Mar 07, 2011 | HP LaserJet M1005 Printer
HOW TO SET HP LASERJET 1005 PRINTER SCANER ERROR 12
how to solve engine scanner error for hp laserjet p1005
Oct 10, 2010 | HP LaserJet M1005 All-In-One Printer
HP LJ M1120 SCANNER ERROR 20 HOW CAN I SLVE THIS PROBLEM
According to HP Tech manual, it says...
20 Error/Memory overflow: Applies to all Laserjet printers
Add more internal printer memory or too much data or data too complex, simplify the print job and retry.
Apr 29, 2010 | HP LaserJet M1120 MFP All-In-One Printer
MANY THX!
Mar 10, 2010 | HP LaserJet M1120 MFP All-In-One Printer
Scanner error 20
your scanunit's lamps frecuenci is changed you should replace the scanunit
Jun 20, 2009 | HP LaserJet M1005 All-In-One Printer
Scanner error
You will have to replace the scanner assembly.
HP Part # C9124-60103
This replacement shoult take 20 minutes.
Jan 01, 2009 | HP LaserJet 3330 All-In-One Printer
HP LaserJet M1120 MFP All-In-One Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
