Question about Canon ImageRUNNER 3570 Copier/Printer
3570 paper jamming on outer tray
4 Suggested Answers
SOURCE: Canon iR 3570
Open your top paper tray drawer and there should be a dial on the on the tray drawer (light blue). On there is different paper sizes. Turn it until you get "Ltr" and the paper is going up & down. This should fix the problem. We just had that same problem today and that's what the tech person told us. (Also, this dial only turns in one direction to the left). MMc
Posted on Nov 29, 2007
  • 13433 Answers
SOURCE: paper jam
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
canontech
  • 1219 Answers
SOURCE: imageclass mf5530 jams from paper tray, bypass
Clean the pick up roller, try to see where is stuckes. In some cases the roller holders breaks down and roller wont turn.
Posted on Jul 05, 2010
Canon ir 3570/4570 reference guide
Hi
My self Rishi Dhiman
if u want to active ur optional copy tray in ir 4570/3570/2870 machine than first of all u have to enable it ,
Go to additional function/ common setting / tray desination/ here u can select tray which u want to use
If u not get the opiton of tray desination in common setting of additional function, than u have to active it from service mode
press * 28* for entering into service mode after that click on copier, now click on option >acc>out tray press here 1 and do it ok, now u have to restart u machine one time after that opition of tray desition is avilable in common setting, nd there u can set u output tray,
caution : this method is decrease the speed of machine paper output
Any Query about this u can post it again here on this website
Oct 11, 2012 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Unable to print 70
  1. Open the Outer Back(Rear) Cover (1) at the back of the machine. Pull the jammed paper out of the machine.
  2. Close the Inner Back(Rear) Cover (1) if it is open as shown in the illustration.
  3. Close the Outer Back(Rear) Cover. Make sure the cover is closed properly.
  4. Pull the paper trays (1) out of the machine.
  5. Push the two green levers up on both sides.
  6. Pull out the jammed paper (1) and press Stop/Exit.
  7. Push the green duplex unit up.
  8. Reset the machine by lifting the scanner cover from the front of the machine and then closing it.
    If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
  9. Using both hands, use the plastic tabs on both sides of the machine to lift the Scanner Cover (1) into the open position. Make sure that there is no jammed paper left in the corners of the machine under the plastic covers.
    Note
    • If ink gets on your skin or clothing immediately wash it off with soap or detergent.
    • If the paper is jammed under the print head, unplug the machine from the power source, and then move the print head to take out the paper.
    • If the print head has stopped in the right corner as shown in the illustration, you cannot move the print head. Press Stop/Exit until the print head moves to the middle. Then unplug the machine from the power source, and take out the paper.
    1. Gently close the scanner cover using the finger holds on both sides of it as you push down on the Scanner Cover Support (1).
    Caution Be careful not to trap your fingers under the scanner cover. Always use the finger holds provided on both sides of the scanner cover when opening and closing it.
    1. Push paper tray #1 and paper tray #2 firmly back into the machine.
    Note Make sure you pull out the paper support until it clicks.
Nov 11, 2011 | Brother MFC-6890CDW Printer
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Paper Jam, when there isn't a paper jam!
just remove thr paper outer tray and see if there is any part of paper is there.
Sep 08, 2009 | HP Photosmart 3210 Printer
How can fix the jammed paper situation?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-17
Jul 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon imageRUNNER 3570 intermittent jamming 0108. Happens after the machine has been idle for a few hours, and first copy jams.
It will be the reg sensor flag sticking. There is a small rubber pad which gets really sticky and is situated behind the vertical paper guide. Difficult to see it but you can feel the pad on the far rh side of the flag (by the sensor). Peel it off and clean the residue.
Jun 10, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Always paper jam
there is so many reason for that
where the jam when u try to copy 1 copy
Apr 24, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Canon iR 3570
Oct 18, 2007 | Canon ImageRUNNER 3570 Copier/Printer
Print Jobs from our IBM Unix System Reports creates Ghost Jams
The answer to our problem ended up being a firmware upgrade to the Canon iR7095. I would look into that as your possible solution.
Oct 10, 2007 | Canon ImageRUNNER 3570 Copier/Printer
Facsimile Paper Size
TRY TO GO ON PAPER TRAY AND LOOK THE PROGRAM IN PAPER TRAY...IF U SEE CHEK THE PAPER SIZE THAT U WANT TO USE...
Jun 11, 2007 | Canon imageRUNNER 3570 Copier
12 people viewed this question
old marine
old marine
