Where can I get the unit standard 242814 - Computers & Internet
Nissan Navara D40 2011 standard stereo wiring diagram
If your original harness is still hanging out of the dashboard I would just opt for the $15 aftermarket cord. Then it's just pretty much color code wires together
Oct 11, 2016 | Nissan Navara Cars & Trucks
Noise very bad at outside unit new american standard ac
should not be that noisy. fan bracket loose or blade out of balance.
Sep 13, 2012 | American Standard Heating & Cooling
Car transmission slipping. Works for short period and then starts slipping.
Is it an Automatic or standard shifting unit??? IF Auto, could be low on oil or band adjustment needed/replaced standard could be a clutch adjustment/replaced or even linkage grommets?? also check the oil on this type unit
Jul 19, 2010 | 2002 Chevrolet Impala
2006 NC MX5 Bose 6 stacker replacement/upgrade
Companies like Scosche and Metra make inexpensive dash kits for the Miata that will allow you to use a standard DIN head unit of any kind. They also often make special adapters to allow a standard aftermarket head unit to plug into the special Bose wiring.
Mar 29, 2010 | 2008 Mazda Mx 5 Miata
I am trying to connect the ethernet cable to a philips RJ45 wall
There are two standards for ethernet wiring. Most cables use the B standard, but many manufacturers of central wiring boxes (OnQ, LeGrand, SmartHome) have central units wired to the A standard. Wall outlets have to be wired to the same standard as the central unit, assuming there is one. You have to determine whether the other end of whatever you are wiring is wired to the A or B standard. If you are wiring both ends yourself, use the B standard. The wiring diagrams are here:
http://www.incentre.net/content/view/75/2/
Sep 21, 2009 | PC Connection RJ45 Connector
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
Standard horizon 155c not acquiring signal
If the signal is good statement seems to imply that it is working, perhaps this is my misinterpretation of what you mean by this.
Signal refers to the abi;ity to connect to satellites
4 are requied for triangulation.
If the unit is fully charged and not connecting , then it is quite possible that the unit has a damaged SIIRF chip or whatever chip was used in your model to acquire satellite connection. The cost of repair is costly, it means total replacement of the M/Board.
Never start car with the unit connected into DC car power, spikes will damage the chip
Jun 30, 2009 | Standard Horizon CP-150 WAAS GPS Receiver
Need schematic for an American Standard A/C Model number 7A0030A1
American Standard and Trane are the same thing. The diagram you want is not complicated at all. Just straight cool unit. American Standard does not put low or high pressure controls on unit. You can get diagram on line At American Standard.com. Just what do you need to know? Very basic unit.
Jun 11, 2009 | Heating & Cooling
Error message imaging unit is out
Hi rmcday: Here your problem. The imaging unit creates the image using an electro-photo process. The imaging unit consists of the following: ■ An OPC Drum ■ Waste Toner Assembly ■ Charge Roller Assembly 9.0 Consumables, Routine Maintenance Items and Options Item Life based on 5% coverage Part No. Replaceable by Black Standard Toner Cartridge Black High capacity 3,000 7,000 106R00679 106R00684 User replaceable Cyan Standard Toner Cartridge Cyan High capacity 2,000 5,000 106R00676 106R00680 User replaceable Yellow Standard Toner Cartridge Yellow High capacity 2,000 5,000 106R00678 106R00682 User replaceable Magenta Standard Toner Cartridge Magenta High capacity 2,000 5,000 106R00677 106R00681 User replaceable Imaging Unit 50,000 images 108R00593 User replaceable Transfer Belt 50,000 images 108R00594 User replaceable 500-Sheet Feeder N/A 119650600 Waste Toner Cartridge 3,000 to 5,000 pages (color 5%) 106R00683 User replaceable. Your imaging unit may have exeeded it life of 50,000 pages and will need to be replaced. Hope this helps
Jun 10, 2009 | Xerox Phaser 6120/YN Laser Printer
I have an Mk3 seat ibiza, and want to relocate a new head unit
I have the same problem and have been looking around, i have found a fascia, it looks like you can take the bottom part out and put a standard sized head unit under the heating controls. however it doesn't look like you can take it apart in sections, if i find out how its done i'll leave another post, here is the link to the site i found the fascias on, you can have a look and see what you think.....
http://www.dynamicsounds.co.uk/seat-seat-ibiza-c-284_305_599.html?page=2
Mar 29, 2009 | Car Audio & Video
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
