Question about Sony TAM-100 Digital Answering Machine
How do you set it to receive messages on mailbox 2
Would like to receive message calls on mailbox 2 or 3
How in the world do you set up voice mail on the e71
Hello Debb,
Please visit the link provide below :
http://www.gen-i.co.nz/Solutions/Mobility/Device_Documents/Nokia%20E71/Setting%20up%20Voicemail%20on%20the%20Nokia%20E71.pdf
Apr 15, 2011 | Nokia E71 Smartphone
I need to know how to access the general mailbox on the Panasonic KX-T7633 to change the message received when calling in after hours.
the general mailbox can be any mailbox from 100-998... or if you have 4 digit extension numbers, 1000-9998...or it can be one of a couple hundred other greetings if you are talking about custom service menus instead of a mailbox (all this is best determined by your local panasonic dealer/serviceman)
once you know which mailbox is your general mailbox:
1) call the voicemail
2) press "#6*" + the mailbox number
3) enter password then "#"
4) press options "3" then "1" then "1"
5) record your greeting then press "1" to stop the recording then "2" to save it
6) hang up
Jan 07, 2011 | Panasonic KX-T7633 Corded Phone
Hi there, my business uses Panasonic KX-T7431 Digital Super Hybrid System and we have several lines. when nobody is available to take the call it goes directly to a company message stating are names...
The introduction message is usually setup as a custom service menu. You need to determine if this is the case by logging into the message managers mailbox and listening to find the current greeting. To log into the message manager mailbox, call voicemail, dial #6 then *98(for 2 digit mailboxes) or *998(for 3 digit mailboxes) or *9998(for 4 digit mailboxes), enter password followed by #. Once in the message managers mailbox, press 5 to record messages. Your introduction message could be the company greeting or a custom service menu. Press 1 for the company greeting and follow the prompts to listen to the greeting. Press 3 for the custom service menu, then enter the custom service number 1-100( in your case start with 1 until you find the current introduction message) and follow the prompts to listen to the message. Once you have found the current introduction message record your new message and save.
Dec 28, 2010 | Panasonic KX-T7431 Corded Phone
Cannot figure out to set answering machine on my vtech, I recevied as gift.
Turn on the answering machine by pressing the on/off button on the base. Set the time and date by pressing the Time/Set button (to the right of the menu button) and pressing Change until the correct day or time is heard. Then press Time/Set again.
To record a message, press Menu until you hear "Set Outgoing Message", then press Record and speak the message (include the mailbox info if you are using them). Press any Play/Stop button to end the message.
Set the various features by pressing Menu to access each one, then press Change to change the setting. Press Time/Set to lock in the change and press Menu to change the next feature. Press a Play/Stop key to leave the menu.
The most important one is "Set Announce Only" to Off for callers to leave a message.
All messages will go into Mailbox 1 unless the caller indicates a different mailbox. Press the Mailbox button to hear new messages if the mailbox has a mix of new and old messages. Press the button a second time to hear all messages. Skip/Quick lets you advance to the next message and Repeat/Slow will let you hear a message again.
Press Vol (up) to adjust the base speaker volume higher during playback.
In the menu, the first option lets you set the two digit security code to access the messages when you call in from another phone. When calling press # followed by 1, 2, or 3 to access the desired mailbox. Press #4 to repeat a message. #5 to skip. Press *0 to end the remote call.
For the full manual, see: http://www.vtechphones.com/vtechphones/index.cfm/support/manuals/ and scroll down to 5866.
I hope this helps.
(all this assumes the base is on (connected to power) and connected to a good phone line. Without power it will not work at all. I test phone lines for dial tone with an old corded phone.)
Sep 25, 2010 | Vtech i5866 Cordless Phone
Need email setting for nokia n81 incoming and outgoing
Hello :
Here are the instructions :
Setting up email:
1:From the standby screen, press the Messaging softkey . Altenatively, press the Menu button, and highlight Messaging .Press Open.
2:Scroll down to highlight New mailbox .Press Open.
3:A message appears: No mailbox defined. Define now? .Press Yes.
4:Instructions appear for the email wizard .To start the email set-up wizard, press Start.
5:In the email address box, type in your full email address .Press OK.
6:You can now type in the name you want to call your email mailbox, or leave it as the default name of your email service .Press OK.
7:You are asked to define the user name and password for your account . Press Yes to continue.
8:In the User name panel, edit the email address until you have your user name - this is usually the bit of your email address before the '@' sign, (though if you're unsure, check with on your email service provider's website).
9:When completed, scroll down using the navigation pad to highlight the Password panel. Type in your email account password . Press OK.
10:After a few moments a message appears onscreen informing you that the email mailbox has been defined .Press OK.
11:The first time you set up, you will be taken into your mailbox and asked: Connect to mailbox? . Press Yes.
12:After a few seconds while the phone connects, you will get a list of email message subject headers onscreen . Scroll through the list to highlight ones you want to view.
13:Press Open to download and view the full email. Scroll down to read the message .
14:If the message has an attachment, scroll to highlight it and press Attachments . Highlight the attachment and press Open . You'll be able to see the attachment in full . Press Close and Back to return to the original email.
To get back to your mailbox, press Back. Alternatively, if you want to reply, forward or see other options, press Options. A list appears onscreen .
 Replying to emails:
1:To reply, highlight Reply. Press Select. Highlight To sender .Press Select.
2:Type in the text of your message. You can also edit or delete the original message if you want to, add new recipients or alter the subject header .
3:When you're ready to send, press Options, highlight Send and press Select .
4:Alternatively, before you send the message you can add an image or other files by selecting Insert from the Options list and pressing Select .
5:A row of icons appears at the bottom of the display, representing different elements you can insert - images, others, video clips, sound clips or text . Highlight and select one of these, and you can search through files to add a suitable attachment. Press Select to add it to your email.
6:When ready to send, as before press Options, highlight Send and press Select .
Checking for new emails :
1:To check for new emails go to the Messaging menu as before .
2:Scroll down to the name you gave your email mailbox . Press Open.
3:If you're not currently connected, you will be asked if you want to connect to your mailbox . Press Yes. New messages will now be retrieved.
4:If you are already in your mailbox and want to check for new messages, press Options, scroll down to Retrieve email .Press Select.
5:Highlight New . Press Select. New messages subjects will be delivered to your mailbox.
Sending new emails:
You can send messages as emails as quickly and easily as text or MMS messages.
1:In the Messaging menu, highlight New message .Press Select.
2:Scroll down to highlight E-mail . Press OK.
3:Add the email address, subject and message .
4:If you want to, add any attachments in the way outlined above.
5:As before, when your email is ready to send, press Options, highlight Send and press Select .
good luck .
rate please !
Mar 18, 2010 | Nokia N81
My phone is Norstar M7324. I can't get voicemails. I have customers called and left voicemails but I can't receive them. I use Feature 981 and it tells me no messages everytime. Any advise? Thanks.
Maybe the callers are leaving messages in the General Delivery mailbox? From your phone, dial Feature 981, when it prompts you for a password, press the button under "OTHR", and you will be prompted for the log. (The log is the mailbox and password combination for a mailbox not assigned to your phone.) If you use 2-digit extensions, the General Delivery mailbox is #10, for 3-digit extensions, the mailbox number is #100, and etc. The default General Delivery mailbox password is "0000". So, using 2-digit ext's, the log would be 100000, then press # or OK and you can retrieve the messages. Write back if you need more help.
Mar 16, 2010 | NorStar M7324 Telephone
I left my Vtech phone in New York, left for Europe and forgot to set the answering machine on. When I call in I get a factory recorded announcement that I'm not available, etc. I have my PIN # with me,...
Can you please specify the exact model of the phone? Because the steps in accessing it remotely varies from model to model. Anyway, you can try to follow the steps posted here and then test:
Remote operation allows you to control the functions of the Answering System when you
are away from the Base,and call from an outside telephone line. The Answering
System cannot be accessed from another telephone on the same line. You can access
many of the Answering System functons from a remote location, such as listening to
messages, changing recorded announcements, and recording memos.
Remote operation can only be accessed from a touch tone telephone. If the remote phone
is set to pulse dialing, switch it tone. If tone dialing is not available, you will not be able
to access the Answering System.
Note: All function codes should be entered within 2 seconds in order to activate Remote
Operation.
To Activate Remote Operation From a Different Telephone Line
1. If the Answering System is OFF, you can dial your telephone number and wait for
the Answering System to answer your call after 10 rings. An announcement, "Please
enter your security code" is given, and you enter your security code to use remote
operation.
2. If the Answering System is ON, it will answer your call and begin playing the currently
selected announcement (as with any incoming call).
3. Enter # followed by your 2 digit security code during the announcement. The
default security code is 19.
4. Once the security code is received, a double confirmation beep will be given, and
you are in Remote Operation mode. You can then control the Answering Machine
functions using the telephone keypad.
5. The user can also enter the Remote Operation mode during message recording. The
procedure is the same as step 3. The recording will be stopped after entering the
valid security code "s#xx " and the incomplete message will be deleted. If " 0s"
is entered, the Answering System will release the line, but the recorded message
will still be retained.
6. If the user enters a wrong security code, the system will release the line.
Playing Messages Remotely
1. Press " #1 ", " #2 " or " #3 " on the touch tone keypad to play the messages in the
corresponding mailbox.
2. The system will announce "Mailbox X. You have XX new messages and XX old
messages" and the system will playback the new message only. If there are no new
messages, the system will announce "Mailbox X. You have XX old messages. On
the other hand, in the absence of old messages, the system will announce only the
number of new messages.
Repeat Messages During Playback
1. Press "#4" once during message playback to repeat the current message.
2. Press "#4" twice within 2 seconds to skip to the previous message.
Skip Messages During Playback
1. Press "#6" once to skip forward to the next message.
Stop Message Playback
1. Pressing "#5" during message playback will stop playback.
Deleting Messages
1. Press "#9" once during message playback to delete the current message.
Note: Playback will pause if "#" or " " is entered. Answering System will wait for the
command in the following 2 seconds. If no further tone is entered, playback will be resumed.
Memo Recording
1. Press " 8".
2. After selecting the mailbox by entering command "1", "2", "3", You will hear, "Now
recording", followed by a beep.
3. Enter "#5" to stop recording when you have finished.
Change OGM Remotely
1. Enter " 7" to record a new OGM. You will hear, "Now recording", followed by a
beep to signal start of recording.
2. Press "#5" to stop recording. Your new OGM will playback automatically.
Check OGM1 Remotely
Enter "#7" to review OGM. You will hear playback of OGM followed by a beep.
Turning Answering System ON or OFF
Pressing "#0" toggles the Answering System ON/OFF. "Answer machine on", or "Answer
machine off" will be announced, followed by a beep.
Voice Menu for Remote Operation
The system provides two pre-recorded voice menus to help you during remote operation.
Press " 5", and you will hear the simple voice menu.
The simple voice menu is as follows:
• Press "#1" to play mailbox 1.
• Press "#2" to play mailbox 2.
• Press "#3" to play mailbox 3.
• Press "#5" to stop.
• Press "#4" to repeat the message.
• Press "#6" to skip the message.
• Press "#9" to erase the message.
• Press " 5" for other functions.
(To advance voice menu)
The advanced voice menu is as follows:
• Press "#7" to review outgoing message.
• Press " 7" to record outgoing message.
• Press " 8" to record memo.
• Press "#4" twice to repeat previous message.
• Press "#0" to turn the system on or off.
• Press " 5" to return to the simple voice menu.
Pressing any function code will stop the voice menu, and perform the corresponding
functions.
Exiting Remote Operation
1. Enter " 0" on the touch tone keypad to exit remote operation mode. The Answering
System confirms your action with a long beep and then disconnects.
2. The Answering System also automatically disconnects if no key is pressed within 20
seconds during remote operation.
Oct 17, 2009 | Vtech Two Line Digital Answering Machine...
Email messages do not appear in inbox on Blackberry Storm
Dear Vbcarroll,
on your blackberry go in main menu- options- advance options- default services. if you have enterprise mail account setup with personal mail account, it can be the case that at the moment it is showing as desktop services but when you are in there click on main menu and change options to other mailbox which is in your case personal mail account.
that way in inbox you will receive both emails and you can see all together.
but as far as i know, I haven't setup personal account on my blackberry but i believe within main menu you get created another icon like mobile mailbox and where your personal mailbox emails are coming in. if option one doesn't work then please try to look for this new created icon within main menu.
update me if none of them are working or any other problem.
Thanks.
Regards,
AJoshi
Mar 26, 2009 | RIM BlackBerry Storm 9530 Smartphone
UNABLE TO DELETE FULL MAIL BOX ANNONCEMENT WHEN MAILBOX IS NOT FU
Try and reset your settings:
On my Nokia 6600 its done the following way:
Menu->Settings->Reset settings (Or reset to factory settings or something like that)
PS: Please rate this solution
Mar 11, 2009 | Sprint Cell Phones
SW Bell FA-980 Answering Machine
Here is a link to a similar model: http://www.swbfreedomphone.com/ib/ibansw/fa970.pdf Here is what it says: TONE REMOTE OPERATION Remote Security Code To access answering functions from an outside line, you will need to enter the three digit security code located on the bottom of your unit. Write this number on the Remote Access Card, which you can keep in your wallet. Remote Turn On If you forget to turn on your unit: 1. Call your unit from a touch-tone phone. 2. Wait 12-14 rings until the machine answers. 3. The FA970 will automatically answer by playing your greeting. You may hang up the phone, and subsequent calls will be answered. Remote Message Playback 1. Call your unit from a touch-tone telephone. 2. After your FA970 answers, it plays the outgoing greeting and beeps once. Dial your three digit security code within 20 seconds after the beep, pressing and holding each digit for 1-2 seconds. Allow a 2 seconds interval between each digit. 3. Your FA970 will sound one beep to indicate the code was entered correctly. (If there are no beeps, enter your code again.) 4. You can press the following buttons on your keypad: Option Press Playback Mailbox 1 Messages (1) Playback Mailbox 2 Messages (2) Record Memo Message (3) Record New Greeting (8) Turn Off Answer Mode (9) If you press ?1? or ?2? (to playback messages), you have the follow options: Option Press Erase Current Message (0) Repeat Current Message (4) Repeat Previous Message (4) repeatedly Stop Message Playback (5) Skip to Next Message (6) To SAVE messages, hang up the telephone. Note: Your FA970 will sound a series of beeps if there are no messages. Remote Record New Greeting If you press 8 (to record new greeting): 1. When you hear a beep, begin recording your new greeting (up to 30 seconds). 2. When you have finished recording your new greeting, press (5). The unit will beep, and the new greeting will playback to you. 3. Hang up the telephone. Remote Record Memo If you press 3 (to record memo message): 1. Within three seconds of pressing ?3?, press ?1? or ?2? to select Mailbox 1 or Mailbox 2. Otherwise, the memo will be recorded in Mailbox 1. 2. When you hear a beep, begin recording your memo (up to 60 seconds). 3. When you have finished recording your memo message, press (5). 4. The corresponding Mailbox message count will be increased by one. To Retrieve Messages when Recording Memory is Full 1. When the message capacity is full, the unit will sound 3 beeps after answering the phone. 2. Within 20 seconds after the 3 beeps, dial your 3 digit security code. 3. Your FA970 will sound one beep to indicate the code was entered correctly.
Mar 22, 2007 | Southwestern Bell FA970SN Digital...
Sony TAM-100 Digital Answering Machine Logo
Top Sony Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
