Question about Coffee Makers & Espresso Machines
Jura impressa drip tray does not fit - Coffee Makers & Espresso Machines
SOURCE: Jura impressa x90 keeps beeping
may need descaling, if this is the case you always need to descale first
Posted on Jun 23, 2009
  • 4 Answers
SOURCE: Tray empty message
If the machine says TRAY MISSING it's the contacts at the back so clean as other people have stated, you can also use a cardboard nail file to clean the contacts at the back if there really skanky!.
If the machine keeps saying EMPTY GROUNDS even though you have, pull out the tray, look just inside the aparture where the tray goes top right at the front there is a small slot where if you look closely you can see a small white micro switch. This will be probably gunged up with coffee and the switch will be stuck up, get a can of WD40 and squirt a small amount up into the switch then poke the switch with a small screwdriver up and down until it moves smoothly.
Then replace all the bits, sit down, look smug and have a coffee cos you've fixed it!! :0)
Posted on Oct 13, 2009
  • 3 Answers
SOURCE: Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Posted on Feb 19, 2010
SOURCE: Jura Capresso Impressa S9- no steam
I had a similar problem. I took off the side and rear cover, followed the hose that comes from the steam wand to the rear of hte unit. It enters a solenoid made by ACL Italy. I dismantled the solenoid unit by disconnecting the two hose ends, removing the relay, and unscrewing the plunger unit (vertical pipe). The plunger unit internals should move freely up and down like a piston in a cylinder , powered by a small spring. In my unit, this plunger was calcified and seized. I soaked it in boiling water and pressed on it gently several times and it unstuck. I put it all back together again and presto! Good luck
Posted on Mar 30, 2010
espressonist
  • 1711 Answers
SOURCE: Jura Impressa F9
You can find some detail procedure in this tip below
http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8
Try it since it have help some other with same problem.
Posted on Aug 23, 2010
Water is dripping slowly from one spout. How do I access and remove the spout assembly on a Jura Impressa F7?
Open the whole machine and you'll find the spout. Tighten up the nut there, the washer is like a tap thats dripping
Dec 10, 2014 | Jura Capresso Impressa F7 Espresso Machine
I just went thru the entire decalcifying process and got to the final step, emptied the drip tray and coffee grounds bin, put the tray back into place, but can't get the display off of "empty...
You should Clean and dry the metal contacts on the back of the drip tray, ensuring that the gap between the contacts is clean and dry (if present, contacts not on all JURA models) Make sure that the plastic in between the contacts is clean
Sep 13, 2011 | Microwave Ovens
I have a Jura Impressa C5. My drip tray mechanism is broken because I pulled out the tray while it was still operating, and a piece of plastic of about 7.5cm x 17 cm (3 in x 7 in approx) came off and...
This is the used grounds blade that makes room in the used grounds container. This is fixed to the brewing unit, and can not be reassembled without opening the machine. If you make sure to check your grounds container often, you really don`t need to put this blade back. Just make sure that the container doesn`t overfill.
Apr 27, 2011 | Jura Capresso IMPRESSA F60
I have a Jura impressa C5, and drip tray will not go back in with the grounds basket installed. Seems as thought the mechanism is jammed out of place. I have cleaned out the tray and vacuum cleaned the...
I have a Jura Impressa 27. The tray, for some odd reason, was not going back in. I simply tried it without the top part - that receives the grounds - and was finally able to get it in. I pulled it back out and found some grounds that had been dumped. It seems something was stuck that wouldn't allow it back in with the top part. Then after I was able to put both pieces back in without a problem.
Mar 26, 2011 | Jura Capresso IMPRESSA F60
Feb 15, 2010 | Jura Capresso Impressa F9 Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
