AC unit turns on blower doesn't come on
Central air unit with furnace function working fine, but switched to ''cool'' fan is set to ''auto''. Outside AC unit turns on fine but blower never kicks on inside the furnace. I've had trouble with the limit switch in the past, but replaced it and everything worked fine. I tried fiddling with the unit and if the limit switch leads are hardwired (basically eliminating a faulty limit switch) no blower and no error indicator light, but disconnecting them kicks on the blower (infinitely) but, also gives an open limit error on the board. I don't imagine the limit plays into the AC function? but it's the only thing I know I've had trouble with. Not sure what actually triggers the blower to start on AC function...so what to check?
The Furnace is a Janitrol GPD100-4 REV-B
  • 1 more comment
  • word2thewhys
    word2thewhys Jun 19, 2009
    The thermostat is working correctly, it's activating the AC unit outside it also works for the heater.
  • word2thewhys
    I wanted to make sure I understand, There isn't a fan relay problem but probably another relay? I should check the RC terminal for any type of current? At what point should I be looking for a current? when the AC is on or when the blower should be turning on? Also this terminal is likely located somewhere on the board will it be labeled? Also can you tell me the consequences of each...if I have current that means...? If I do not have a current that means...?
  • word2thewhys
    Non-digital thermostat - Honeywell. I just realized you were talking about the the thermostat I think... and not inside the furnace? I just want to reiterate, The thermostat kicks on the AC unit outside so you still think it may be a thermostat issue? Or am I confused and we are talking about terminals on the board in the furnace?
    President:
  • 3,433 Answers
The thermostat is the controller.
Posted on Jun 19, 2009
  • 1 more comment
  • Ned C Cook
    Ned C Cook Jun 19, 2009
    Signal from thermostat is not being made to the fan relay. You should hear a click at the furnce when you lower the temp. .You don't appear to have a fan relay problem. The fan limit awitch default is closed so when the relay is tripped it interupts the limit switch circuit to the fan. Make sense? So it's a smaller relay that causes interupt with the low voltage from the thermostat.. If you can, ck the RC terminal tfor current. That is the red cool term.
  • Ned C Cook
    If you have current the blower should kick on. If there is no current , then it won't. the terminals are marked. The red and rc should be jumped I should have asked. Is this a digital thermostat or round? and what brans is it?
  • Ned C Cook
    Ned C Cook Jun 20, 2009
    The thermostat
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
Whirlpool model WC260A-1A cannot find manual and central air conditioner will not turn on worked well 2 days ago.
Does the fan turn on when you have it set to cool? does the furnace still work? Does the fan auto, and on options still work?(for example when on its on, when auto, and neither the cool or heat functions should be running, the fan is off)? Basicly i'm asking your to test your thermostat right now.
Aug 04, 2013 | Whirlpool Central Ac Condenser-new...
Reset switch on furnace to make air contitioner start
I know what you mean. Not a lot of companies around here care to work on mobile homes. There is a safety on that unit that may or may not be a reset. Normally it will have a small red peg in the center to push and reset. Some don't have a reset though. Look for a small, flat safety, it should have 2 wires. And it may be hidden. As if 2 wires just disappear behind the blower assembly. Check for voltage to it, and across it. You can find volt/ohm meters for $10. Chase or follow the signal from the tstat. R comes from the tformer and powers the tstat. Tstat closes and sends a 24v signal through Y and G in cooling. Y should go from tstat to indoor unit, and to a terminal block or wire but, then directly outside to outdoor unit. G comes from the tstat to a terminal block's (g), then to the auto,off,on, then to a switching relay's coil. This coil closes and allows line voltage to pass through powering up the fan. So at the indoor, with 1 lead connected to common with your voltmeter set to AC volts, use the other lead to follow these paths. Or keep calling companies to find someone who will work on them. Electricians will not work on HVAC equipment. Even though it's all the same principal, source/line/load. Be safe!
Mar 17, 2017 | Heating & Cooling
I installed an RTH2300 this winter to replace an old mercury thermostat. It worked fine for the heating season. I turned it to Cool for the first time today and my AC and furnace blower will not turn...
Maybe turn selector switch to off.see if every thing shuts off.if yes. turn FAN selector switch from (auto) to (on) mode.does the outside unit come on or does just the furnace blower only run ? the inside fan should be the ONLY thing on.if not, reverse the (G) & (Y) wires inside the new thermo.
Jun 07, 2011 | Heating & Cooling
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
Hello We have a Trane central air
Bad thermostat, improper wiring or bad circuit board in furnace. Turn off the disconnect outside.
Dec 30, 2009 | Heating & Cooling
My AC unit wont blow the cold air.
if the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
Jul 09, 2009 | Fedders A&B Chassis A1A07W2B Air...
Bryant central air unit fan doesn't stop.
This is a condenser fan and as long as the A/c unit is in cool mode, this fan will run. The only time it should shut off is when temperature setting is satified and the unit shuts off.
Jun 03, 2009 | Heating & Cooling
Fan will come on for heat(auto), but not for AC or set to ON
You have a blower relay in the furnace that's probably bad. In the heat mode the blower is on a temperature relay, in cooling mode the blower has to come on immediately so there is another relay for cooling. The green wire on the thermostat feeds that relay, so if you go to the furnace and shut the power off and find the green wire from the thermostat that feeds that relay and replace it, being careful to mark all the wires before removing them, also the relay terminals have numbers for identification.
Apr 07, 2009 | Heating & Cooling
Heating & Cooling Logo
1,658 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
