Question about Fisher and Paykel Washing Machines
Wont spin I own a f&p smart drive, on the spin cycle it does a few cluncks then wnt spin, i have rearranged the washing to no avail help
  • grumpy11 Jun 19, 2009
    the board looks fine light come on and it starts beeping as to say that its unballanced. I also dont know how to check the clutch balance. :
  • 105 Answers
Hi
check the control board if it is fried or a fuse is blown.
if it moves when initially started check the clutch counter balance, it may be failing
Posted on Jun 19, 2009
Fisher and Paaykel Smart Drive 708 not working once filled with water.
You need to check your lid switch & out of balance switch for
corrosion and replace if faulty.
Your out of balance switch is under the big yellow motor controller
OOB switch Is where the grey plate is on this picture.
Mar 03, 2013 | Fisher and Paykel Washing Machines
Fisher paykel aquasmart top loader washing machine continuously comes up with fault 247 when trying to spin. Appears to be a balance problem as rearranging clothes and a restart allows it to...
Hi - you have possibly some restrictions in/around your smart pump unit, inside is a flapper valve suppose to control flow in both directions, often this gets the rough treatments.
Be careful if you wish to have a nosy its located beneath the smart agitator.
Jun 18, 2011 | Fisher and Paykel Washing Machines
My fisher & paykel smart drive 051 will wash then drain, but when it gets to the spin cycle it wont spin at all it fills then drains only.
Possible that the program controller is faulty and is not executing the output when the wash cycle and the drain is done. So the program must advance further to the next stage to drive the motor to spin after the water is pumped off and the water level sensor is reset.
Have the conttroller checked to confirm the fault, look for loose joints in the connections.
If not the controller can be a suspect.
Oct 15, 2010 | Fisher and Paykel GWL11 Top Load Washer
Won't drain in last cycle
Hi just read your posting.Now can you confirm the model number please.Please ;look underneath the machine to the front right and you should see a pump with a red or black fan attached.Turn this fan clockwise and anticlockwise a few times to hopefully loosen the pump if it is jammed.If the fan turns freely then put it back on its feet and start a spin cycle to see if it drains the water.Please reply with additional information on the questions and to tell me if you have the pump with the fan or if it is not draining or if it still is not draining.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Wont always spin with a medium to heavy load
seams like you need to check your belt
copy n paste this ;
http://www.youtube.com/watch?v=6XIsK3W_Qcg&NR=1
"Was this helpful?"
Jan 16, 2009 | Kenmore 22622 Top Load Washer
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
My samsung smart wash, when it gets to the spin cycle nearly always comes up with error code UE which I know means uneven, I try to rearrange any laundrey or remove some clothes from the machine but it...
Hi, I have a Samsung smart wash 12455 washing machine and My missus has forced thwe door on our washer and it will not open now. Can you tell me how to get the door open as it is now very loose when pulling on the door open mechanisium..
regards,
Steve.
Apr 09, 2008 | Washing Machines
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
