Question about Marantz SR8001
Marantz sr3053 stuck in headphone mode
The units says heaphones are connected however they are not and prior to the issue had never had heaphones inserted.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Marantz Master
  • 924 Answers
There is a microprocessor IC(a computer inside your unit) that senses when you insert a headphone. Yes, as mentioned above, the jack may be bad, but unlikely. The connection from the jack to the IC(computer) may not be damaged, or the IC above, may be damaged. If you are interested in having your Marantz repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Posted on Jun 26, 2015
  • 139 Answers
Usually the headphone jack is like a mechanical switch and it's probably just not making a good connection inside. Use the correct size headphone jack and insert it then remove it maybe a couple of times and see if that fixes it.
Posted on Apr 18, 2014
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: how can i remove standby
Resolve the issue.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on Apr 17, 2011
  • 121 Answers
SOURCE: Marantz SR7500 headphone jack stopped working
There is a contact inside the jack that is closed when the plug is inserted. Apparently this is no longer happening. This should be an easy repair for a qualified technician.
Posted on Feb 26, 2009
Pair intex headphone with presario f700 laptop
Make sure the headphones work. Try the headphones in another computer.
Apr 27, 2012 | Computers & Internet
The ht-c6600 does not have a headphone jack. I want to listen to games and movies without blowing away the neighbors. How to I connect headphones to this system?
This unit has NO usable audio outputs.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-C6600-Home-Theater-Systems-manual/id/23703dj296/t/2/
A workaround would be to see if the TV has a headphone output. Or route the TV audio to a PC and use the PC's heaphone output.
Apr 18, 2011 | Samsung HT-C6600 Theater System
How can i remove standby mode marantz sr3053
Resolve the issue.
Apr 17, 2011 | Marantz SR8001
The wire disconnected from the jack, but the rubber wire protector still connects the two. How can I fix it?
See my tip on replacing dodgy plugs/cables on heaphones. You will find it by clicking my name.
Nov 24, 2010 | Sony MDR-XD200 Consumer Headphones
My connector is frozen on blinking red and blue. It will not connect with the head phones and go solid blue.
Have you tried doing the same with the headphones? If you hold the power button down on both the transmitter and heaphones (get them both flashing red and blue), they might pair.
Jul 15, 2010 | Logitech FreePulse Wireless Consumer...
Feb 26, 2009 | Marantz SR7500
Marantz PMD660 Headphone Jack inside machine
take out the pins that resemble watch pins! remove the stickey label with the
power switch,usb and 5 volt jack cut outs! If you have taken out the screws needed up to this point and you are a little bit technical this should get you into the unit.
If you don't have the skill, hire it out. Joe Taken
Feb 05, 2008 | Marantz PMD660 Digital Voice Recorder
Marantz SR8001 Logo
76 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
