Question about Fisher and Paykel Refrigerators
F20 service code on fasher and Paykel RF610ADUX1
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Error code F20 on RF610A
Hi.
F20 means that there is a problem with the defrost system. The temperature sensor and the element comprised in the defrost system must be tested. Testing is done removing the firewall panel (usually in the freezer compartment in F&P) and accessing the parts. Parts are tested reading impedance with a multimeter. The test will determine if element is open or if the temperature sensor is open at room temperature to find out if any of the two parts must be replaced. Voltage to element must also be tested.
Try performing a manual defrost. Remove all food and disconnect the fridge overnight. If the problem does not come back, then the fault was probably a temporary malfunction. If the defrost system is faulty the problem may come back after a couple of days, when the defrost system restart malfunctioning. In that case ring the F&P number listed on the owners manual to call a technician.
Regards.
Ginko
Posted on May 09, 2011
Fisher & paykel refrigerator RF195A
Hello!
Error F20 - it often means that the light bulb of the refrigerating chamber burned down. You need to replace it.
Here is also a link to the manual.
http://manualsbrain.com/en/manuals/1295058/?page=43
Hopefully, it will help you!
May 16, 2017 | Fisher Washing Machines
Actually mine is the kenmore oasis elite canyon dryer [problem...help!
F20 indicates insufficient water supply. Probably a pinched or partially clogged hose somewhere, either leading to the machine or in the machine itself. Have they checked all the hoses for that?
Sep 10, 2007 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Elite HE 5t is showing the F20 code 15-20 seconds into the washing cycle. F20 standing for Water inlet problem. We have cleaned and checked all inlet ports and they are good so what else
Hello Shannon;
My name is Peter. I am a retired field service appliance technician.
Code F20 also stands for pressure switch.
You have a incomplete model number so I am not sure if this is the correct switch.
Substitution: W10514214 - $48.00
This is just inside the top cover, right hand corner.
The diagram is on the following link. Plug in your model number.
Water Filters Lawn Garden Appliance Parts
Dec 11, 2014 | Kenmore Elite HE5t Washer
Defrost Cycle on Fisher and paykel RF610
Malcolm, if you are indeed getting an F20 fault, this is a problem with the flapper heater. The flapper heater current is low.
First, Check the JST in-line connections for the flapper heater.
Second, Check the resistance of the heater. If open circuit, replace the heater.
Apr 20, 2014 | Refrigerators
We keep getting F20 code
F20 No water detected entering machine, bad flow meter leaf switch, clogged water valve inlet screens,pressure switch hose clogged Service manual
Sep 17, 2011 | Kenmore 46462 Front Load Washer
CONTROL PANEL SHOWS F20 AND BEEPS WHEN OPENED PLEASE TELL ME HOW TO FIX THIS THANKS
F20 can be fixed very easy. Get something high to stand on. and see the top of the fridge. you will see the top panel and 2 pieces of plastic covers on the front corners. take of the left on and you will see broken cables. attache the cables back together and please at least use electric tapes to make it safe or soldering iron even rubber melting tubes.
Apr 15, 2011 | Fisher and Paykel RF201ADUX Bottom Freezer...
We do not know what the f20 code means
F20 No water detected entering machine, defective flow meter, clogged water valve inlet screens, unpaid water bill. themobilian_1148.jpgthemobilian_1149.jpgthemobilian_1150.jpg
Duet service manual and more HERE
Jan 30, 2011 | Washing Machines
Washer model number WFW9400VE error code F20 keeps coming up. Is there a way to reset?
F20 No water detected entering machine, Defective flow meter, clogged water valve inlet screens.
Duet sport service manual
Jan 07, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
2006 kenmore smartwash quietpak4 he3t F20 code washer
F20 ERROR CODE ON A KENMORE HE2T FRONT LOAD WASHER.THE FIX FOR ME WAS TO REPLACE THE TUBE THAT RUNS FROM THE PRESSURE SWITCH TO THE BOTTOM OF THE WASHER.YOU MUST REMOVE THE TOP AND BACK COVERS OF THE MACHINE(EASY).REPLACED TUBE WITH3/16 INCH CLEAR TUBE.THE ORINGINAL TUBE HAD A PIN HOLE FROM RUBBING AGINST THE SIDE OF THE MACHINE AFTER 5 YEARS OF USE.THIS COST UNDER $10 DOLLARS TO FIX. NO SERVICE GUY=MORE BEER MONEY GOOD LUCK.
Nov 07, 2007 | Kenmore Elite 45986 Front Load Washer
Refrigerators Logo
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
