Question about LG 50PA5500
No picture have sound no picture worked ok turned off at night after watching next day there was no picture but have sound
    New Friend:
    Problem Solver:
  • 6 Answers
If u r a technician turned on the tv.remove base board from tv on running tv & put it again care fully.when u do this dont turned off tv.
Posted on Jul 04, 2015
    President:
  • LG Master
  • 775 Answers
This is a common problem with this TV caused by a failed buffer board, usually the top one.
Here's two links that explain it, tell you how to test it and provide solutions:
http://www.coppelltvrepair.com/p/1173/lg-50pa5500-ua-top-buffer-board-replacement-for-tv-starting-with-no-image-problem-50-credit-for-old-dud
https://www.youtube.com/watch?v=z3dxCJ3CaTs
Hope this helps!
4 Suggested Answers
  • 4102 Answers
SOURCE: 42 inch LG Plasma TV Lost Picture
Hi it sounds like it has had an elctric fault like a resistor failing.
The click you heard would be a internal switch that cuts off the elctric supply to the screen to stop furthe damage hapening.
It could even be something simple like a bad solder and in that case will need locating and resoldering.
How old is the telly and how often is it used.
When you switch it off leave it off for about an hour then try again if you have allready done this then it probably is a blown resistor are you sure nothing has been pressed on controll have you tried seeing if you can acess the menu screen via the remote and see if that comes up on the screen let me know ok
Posted on Dec 14, 2007
freetek
  • 5568 Answers
SOURCE: picture lost sound still ok 42" LG
Since it is coming back after a union-like break, it is probably the inverter for the fluorescent backlight rather than the light itself; they can flicker and die but normally don't recover after a rest. The inverter may be a separate board in the unit and you should be able to recognize the right board due to its relationship to the backlight.
This kind of problem will not repair itself but decay further with time.
Posted on Sep 04, 2009
jdvillanueva
  • 2098 Answers
SOURCE: our lg tv was going ok the night before and when
This is an indication that you have a problem on the power supply section or on the load because of the following reasons : 1. Over Voltage - the regulator might be cycling on over voltage due to lack of load. 2. Over Current Protection - excessive load or faulty power supply cycling will trigger the over current protection circuit. This is because of open fusible resistor in line with a shorted Voltage regulator IC. 3. Leaky Capacitor - a dried up main filter capacitor or other filter capacitor in the power supply that is producing an out-of-regulation condition. A bad filter capacitor on the output of a series regulator may result in excessive/drop of voltage. 4. A problem with the microcontroller, relay or its driver, or standby power supply.
This is not DIY and quite technical, I've advice you to look for a qualified technician or send it to repair shop to isolate the problem.
But first check if your unit is under warranty then avail it because the manufacturer of your unit will fix it for free or with a little charge only.
Hope it may help you.
Have a nice day!
Thanks for using Fixya.
Posted on Feb 10, 2011
The sound on my Magnavox CD130MW9 stopped working
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 21, 2012 | Televison & Video
My samsung LN37B550k1fxza, Has Sound But no picture! day old!
While it is playing, sound that is, try holding a flash light right up next to the sceen, preferably in a dark room, and see if you have any picture. You really have to focus on it and watch closely. If you can see any picture, you probably have a bad inverter. The inverter lights the back lights in the panel to illuminate the picture. The flash light basically does the same thing from the front. The inverter is the board on the far right with several of the same kind of wires disapearing down the side. Thanks. Let me know what you find.
Nov 11, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Luminox 3100 series stops working at night
Sounds like there could be a bit of foreign material floating about inside, or the new battery was not up to scratch. Take it back for checking.
May 29, 2008 | Luminox Navy Seal Dive 3001 Wrist Watch
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Dark over night
Does the TV have a light sensor? If so, turn it off.
The light sensor limits the backlights intensity at night or when it's dark in your room in order for better vieweing convenience.
If you are in a dark environment, it really pains your eyes when the view is too bright. Same works the other way around. If it's day, and light in your room. The light sensor will dimm the backlight for it isn't needed.
Let me know if this solved your question.
Greetings,
DarkNeogen
Jan 24, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Crashing sound on Protron 32 TV
no sound, everything was working fine the night before. woke up the next morning, and turned the tv on, and there was no sound at all. nothing from the TV, DVD, and nothing from the Computer. Please help. curtisw_1999@yahoo.com.
Dec 26, 2007 | Protron PLTV-32 Television
KP-53XBR45, Sound OK, but no picture
You may have a bad convergence... short will shutdown your HV circuitry leaving just audio?
It has no bulb to change?
Oct 29, 2007 | Sony KP-53XBR45 53" Rear Projection...
Samsung dlp
HLS4266W 43" dlp. In less than 1 yr whining grew worse, but did know what it was. Year passed with warranty and lamp went out. Replaced lamp. Worked for 3.5 hrs. Turned on next day and did not work. Got another lamp, but did not work. Figured out might be color wheel. Replaced it too. TV started up. Watched that night. Turned on next day, heard loud pop. Lamp never came on. Withdrew and reinstalled lamp a couple times to see if that worked. Did not. Currently, with new lamp and color wheel installed, lamp light blinks, but no lamp comes on. What now?
Sep 17, 2007 | Samsung HLN5065W 50" Rear Projection...
LG 50PA5500 Logo
134 people viewed this question
