Question about Exercise & Fitness
Magnetic sensor wire replace - Exercise & Fitness
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
This it normally located in the front under the cover. should be a 2 wire that plugs into the control board. the senser and wire is one piece. the sensor is usually round cylinder and black
Posted on Apr 20, 2014
Wired in home system. window sensor is not operating.
Alarm door/window sensors of one of two types - magnetic and microswitch, both are available at retail stores (hardware and electronics stores sell them) - verify type of switch: magnetic has two parts one attached to door/window while the other is attached to the frame (and in turn this part is hardwired to your alarm system control unit); the micro switch type is one part on frame *usually under window, or on hinge side of door* - harder to replace due to how they are mounted - but can be replaced.
Either type use two wire connection - basically a positive and negative wire loop via the sensor.
Purchase new sensor of same type - and replace faulty sensor.
Sep 22, 2014 | Computers & Internet
Treadmill error codes 3
please follow the steps and fix it.
E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire is NOT working, change the magnet wire or reset the magnet. Please clean it too.
See the diagram attached.
God bless you
Dec 02, 2013 | Exercise & Fitness
Treadmill error codes3
please follow this stepa and see the diagram attached.
E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire is not worlingm change the magnetic wire or reset the magnet.
God bless you
What does an E3 error code mean on my vitesse endurance xt treadmill
"E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire is not working replace see the diagram attached.However clean it. and tight the connector very well.God bless you
Apr 03, 2013 | Exercise & Fitness
Pace master 870x error code 3 ?
"E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire isnot working change the magnetic wire or reset the magnet.
God bless you
Jan 31, 2013 | PaceMaster Exercise & Fitness
Code E3 comes up on console
"E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire is not working.
see the diagram . clean it, tight the connector very well. and test for open or faulty.
Jan 25, 2013 | Weslo Exercise & Fitness
Get E3 when I press start
"E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire is open .Repair
Test the sensor speed for open or faulty. +Reed swtich sensor. for open or faulty.
God bless yousee diagram and try to adjust.1_25_2013_4_44_15_pm.gif1_25_2013_4_44_34_pm.gif
Jan 25, 2013 | Exercise & Fitness
I have technogym RUN XT iget E3 when I press start
Test the sensor speed +reed switch for open or faulty. Clean it, and tight the connector. Try to adjust see the diagram attached.
Read error 3
"E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire is not working. adjust the sensor see the diagram
Clean it. tight the connector very well.
Jan 24, 2013 | Ironman 320T.1 Treadmill
Washer will not spin LG Washer WM1832CW
1. Open back of the washing machine and control panel. Locate two wire harness coming out of main motor and main board. Check the wires for any cuts and harnesses for any corrosion. Fix the cuts and sand the corrosion to fix the issue.
2. Check the windings on the motor by pulling 3-wire connector from main board. Check resistance between each of 3 pairs using multi meter. The resistance should be 8-15 ohms. If one or more pair has no resistance reading then the winding is burned. Replace the rotor winding.
Rotor windings can be ordered from here: http://www.repairclinic.com/SSPartDetail.aspx?s=t-wm1832cw-%3d%3di1266809&PartID=1266809
3. If windings are fine then the hall sensor or speed sensor or motor sensor or sensor assembly needs to be replaced. The hall sensor sits on the inside of the rotor winding. Hall sensor has 4 wire connector attached. To remove the hall sensor: Open the outrunner or magnetic rotor from the motor first. Remove a big bolt at the center of the motor by holding the magnetic rotor. Once bolt is removed, the magnetic rotor can be removed by simply pulling it straight out. You may have to wiggle it a bit. Now remove a screw holding a wire going to hall sensor towrds bottom left of the winding. Now remove six inside bolts holding rotor windings to the drum body. The rotor windings are heavy so be careful while removing the bolts. Remove two wire connectors from the rotor windings and pull out the windings. Lay the rotor windings flat facing connector side up. Remove the hall sensor by praying out tabs.
Hall sensor can be ordered from here: http://www.repairclinic.com/SSPartDetail.aspx?s=t-wm1832cw-%3d%3di1268238&PartID=1268238
Jul 14, 2009 | Washing Machines
Exercise & Fitness Logo
24 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
