Unable to watch programme while recording another set clock on timer
    Problem Solver:
  • 7 Answers
Can you please post more information, is It cable, satellite, what model, etc.
Posted on Jun 19, 2009
  • NYourHead Jun 19, 2009
    My apologies, I meant to ask for a clarification request.
Samsung DVD-SH897M - Cannot get Time Programming to work
You need to contact Curry's direct, I am certain they will be able to send someone to explain it to you.
Jan 05, 2010 | Televison & Video
Stop Substitles on a LG RHT497H 160G dvd recorder?
I have the LG DVD recorder DRT389H which has the same problem. You can't switch off the subtitles during timer recording from the Electronic Programme Guide. The only way I could stop this was to go to the main set-up menu then select the A icon. Select DTV Subtitle and choose a language that the TV programme isn't broadcast in. I chose Gaelic. The only disadvantage is that this stops any subtitles being recorded so you can't access them later.
Dec 26, 2009 | LG RH177 DVD Recorder/HDD Recorder
Cannot record without watching the programme
This unit does not have twin tuner,you would have to watch another channel on the tv.
Dec 03, 2009 | Panasonic Televison & Video
How to record on vcr/dvd combo I set the timer program to record on the vcr but nothing happen, I can record by hitting the record button, but unable to get the timer to work. I received the vcr/dvd combo...
First make sure the internal clock is setup correctly observing am/pm. Then try recording something so you can watch the operation to see if it works. Make sure you have a tape you can record on and also make sure the write protect tab has not been removed from the front lower corner of the tape. Good Luck! I hope you now have success!
Nov 11, 2009 | Toshiba Televison & Video
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
Unable to record e.g MOVIE from TV to DVD disc
Just record the shows to the hdd and when your there then burn the shows into the dvd from the hdd.the dvd is pretty small it wont hold many shows.
Apr 27, 2009 | Televison & Video
Lost user manual
What brand of VCR? what model?
Feb 20, 2009 | Televison & Video
Set the clock on my Panasonic NV-J11 HQ VCR
Hey there - I've got the exact same model VCR; although I've lost the manual as well, I've been using it for so long that I
can usually remember it all from heart:
To set the clock
1. Open the flip-down lid, push [CLOCK] button.
For each of the steps below, use the white-labeled [+] and [-] tracking buttons to increase/decrease each number.
2. Two digits should be blinking - this is the year (last two digits only) - adjust and push [NEXT] when done.
3. Two digits, with a "D" next to them should now be flashing - this is the month (1=January thru 12=December), adjust and push [NEXT] when done.
4. Two digits, with a "M" next to them should now be flashing - this is the day-of-month (1..31), adjust and push [NEXT] when done.
5. The time should now be displayed, with hours flashing - adjust and push [NEXT] when done.
6. The minutes of the time should now be flashing - adjust. When you push [NEXT], this will complete the date-setting and start the seconds-of-the-minute off at zero - handy for synchronising to an external time source (I recommend using the
Teletext broadcast clock if available - you'll usually find your recordings will start right-on time when you do this, depending on your TV station).
7. If you make an error at any step above, push [CLOCK] to exit clock-setting mode and start again.
Depending on your model of VCR - the clock may either persist through power failures (backup battery) or may have to be reset next time power is lost. Mine doesn't seem to have a backup battery.
To program the VCR for timer-recording: There are two modes, Timer Record (start and finish recording at arbitrary times in the future), and OTR ("One Touch Recording", start recording right now and finish at a set time in the future).
*** Timer recording ***
There are eight programme slots (numbered 1-8 on the display), each programme slot has an individual channel and start/finish time associated with it. Programmes can be scheduled up to 1 month in the future.
Push [PROG/CHECK] to cycle through each slot (after the eighth slot, it will return back to normal operating mode).
When you want to set a programme, push [PROG/CHECK] until you find an empty slot (date/time will be all dashes). Then do the following:
1. Channel should be flashing - set this using white-labeled [+]/[-] tracking buttons and push [NEXT] when done.
2. Date should be flashing (defaults to today), use [+]/[-] to adjust starting date and push [NEXT] when done.
3. Set the starting time ("ON" should be lit next to time) (defaults to now), use [+]/[-] to adjust starting time and push [NEXT] when done.
4. Set the finishing time ("OFF" should be lit next to time) (defaults to starting time), use [+]/[-] to adjust and push [NEXT] to complete the setting of this programme. After this, you'll be returned to the start of setting the next programme (the unit will also beep five times to confirm you have a valid programme set).
If you make an error (or you need to clear a programme slot that already has a programme set), hold down the [-] and [+] buttons for three seconds until the starting time/date becomes all dashes.
When you're done with setting your programme(s), keep pressing [PROG/CHECK] until you exit into normal operating mode, then push the [TIMER REC] button to activate the timer; this will put the VCR into timer standby mode, and the orange clock icon should be lit solidly on the display. There should also be a number (1..8) lit for each programme that has been set, but is still yet to run. Make sure you have the tape inserted and positioned in the right place when you do this.
After timer standby mode is activated, you can then push [PROG/CHECK] to review the individual programme slots; each push of [PROG/CHECK] will cycle through each slot (the display will time out in 10-15 secs).
To get out of timer standby mode (either when after the programmes have run or if you've made an error), push [TIMER REC] again - this will return you to normal operating mode (where you can fix errors if need be). Programmes that have run to completion should be automatically be cleared.
*** OTR (One Touch Recording) ***
This will start the tape recording immediately (good for when you have an unexpected distraction or sudden change of plans) and have it stop at a later preset time. The OTR mode only has one programme slot, unlike timer record.
1. Insert tape, have it positioned where you want to record from. Set the channel to the one you want to record from.
2. Open the flip-down lid, look at the bottom-right corner of the array of buttons inside.
3. Push the green-labeled [OTR +] button; this will start the tape recording instantly (the red "OTR" indicator should be lit on the display).
4. The stop time should also be displayed - use the [OTR -] and [OTR +] to adjust the stop time. When you're done, that's all you need to do (you can adjust it any time later).
To abort OTR mode (ie. if you start it by mistake, or want to stop the recording early), push the main [VTR] button to stop the recording. Yes, that's right - turn the whole thing off, it'll leave you in standby mode.
Hope this helps!
-- Bryan R.
Nov 26, 2008 | Panasonic PV-7451 VHS VCR
Programmed recording to the hard drive
Either You haven't set the time/timer correctly or you need to find a way to clear/format the hard disk.
Aug 16, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
