Will not spin dry
HOOVER 750LC MACHINE WILL NOT SPIN DRY CAN YOU HELP?
  • pauledwick Jun 19, 2009
    No The machine turns on. There is no problems with power,it just goes though the cylce but when it comes to spin dry it just clicks and just keeps pumping water till the end of the spin cycle. I have has the pump out to see if it was blocked and have also run all the water out. Please help
    Paul
    President:
  • 1,197 Answers
If you hear a switch click when the lid is open or closed
make sure the lid switch isnt broken...
I think that the lid switch has come off or broken. If you lift the lid look in the recess where the lid goes on top. There will be a small slot, if you press down on this slot with a screwdriver or something, it should make a clicking noise. Also check the lid and there should be a short prong that presses down this switch when the lid is shut. If the prong is missing or there is no clicking noise when pressed. The little clip that holds the switch has come off. This is a safety switch that protects people from the spin cycle when the lid is opened. If you are capable, remove the top panel on the washer, locate the bracket and switch. This is a small rectangular part with a button on the middle, with 1 wire attached to each end. Unplug the power, remove these 2 wires from the switch and connect them together. make sure everything is safe and plug the cord back in, turn the timer control to spin. If it spins, that it. Also, if it has an anti out of balance switch that is not working, you need to locate that too, while you have this apart. Check the literature that came with the washer to be sure it has this feature. Locate it on the machine and just replace it. Testing it may be hard to confirm. You will need a meter and may be some type of mercury switch inside.
Just pull the outer panel off, remove pump and motor and check the coupler, probably broken.
if the coupler is ok..... we advice u to change the lid switch....
if u feel i ve been helpful.... kindly rate my service.... good luck....
Posted on Jun 19, 2009
  • 105 Answers
Hi paul.
if the machine does not respond at all when turned on, you may have a failed power supply. this is resolved by replacing the DC converter of the machine
if the controls show up when turned on, you have a blown fuse in the control panel or control board. this fuse is located near the control board in between the motor.
hope this helps
regards
Hoover 2305L goes through all cycles well.does not spin fast enough to dry clothes.
how old is the 7 kg washing machine
should be direct drive to the drum not a belt drive
the motor could be wearing out
are you over loading
May 11, 2016 | Hoover Washing Machines
Hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
Jan 30, 2008 | Hoover Nextra HNF 3167 Top Load Washer
Hoover 600MB not spinning. Help please
NOTE: A 600 is not a fast spinner. towles and jeans etc do not come out very dry.
Helpful information prior to diagnose
Have you checked to see if the pump filter is blocked so that all the water can drain away.
Does the machine just stop with all it's water still in it.
Does the machine finish it's cycle.
Does all the water pump out, do you hear a sucking noise (means no water left) or a humming noise( means pump jammed)
Oct 01, 2014 | Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Hoover top loader 750lc about 8 years old
Hi just read your posting.Now the only way to drain your machine if it is not draining is to do it by hand with a small pot or bucket. Do you hear a small click when you close the lid slowly?If you do then that is the lid switch.It will not drain if your lid switch is not activating.Did you wash a big load before the problem started?Also could be a faulty or jammed drain pump.I can guide you throe the removal of the pump to see if it is the problem if you have some tools available.Please reply after you have tested the lid switch and I can guide you throe the rest of the repair if needed.
Jun 05, 2010 | Washing Machines
Wash cycle,spin dry, water level
I WOULD CHECK FOR A PLUGGED AIR PRESSURE HOSE OR THE PRESSURE SWITCH ITSELF.
Jan 26, 2009 | Hoover Washing Machines
Hoover elite 1210 won't progress to the final 'spray and spin dry cycle'.
Hoping to be of help after the spin dry wouldnt work on our hoover elite 1210.
It would do the wash cycle fine but as soon as it needed to drain, it wouldn't.
My handy man (Husband) is great at fixing things and opened the front panel by undoing the screws.
Near the motor on the bottom left, there is a wheel/fan looking thing.
(Turn the machine off first)
He tried to spin the wheel but it would only move clockwise and not anti-clockwise like it is supposed to.
So he gave the fan a few spins clockwise before giving it a gentle pull outwards in which it loosened the wheel and was able to move anticlockwise again.
We then turned the machine on and it started spinning and draining the machine.
This machine is a work horse and I refuse to get another. They don't make them like they used to!!
Mine has a leak and we use a drip tray underneath at the moment. So long as it works. I am happy.
Hope this helps someone else with the same problem.
Sep 21, 2008 | Hoover Washing Machines
Hoover Commander 7kg (about 9 years old) not working. It does not spin in any wash cycle, although it can be done manually with ease in the 'spin dry' cycle. There was a strong rubber smell before. Any...
I have a Hoover Commander Model 2045LOAUS. The machine washes OK but will not spin (ie pump the water out). Could it be a burnnt out spin solenoid or motor??
Apr 26, 2008 | Hoover Washing Machines
Hoover 2305 washine machine wont spin
hi, i have a hoover 500 mb, occasionally it will not [ click into ] the wash cycle, then gets confused and does not spin dry properly
Jun 24, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
63 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
