Question about Keurig Vue Brewing System
2 small plastic washers have come loose on my yue 700
Stopped water flow into cup upon examining found 2 loose plastic washers one red and one black near brew heah.
SOURCE: Not Brewing
We have had this problem intermittently but we had a bigger problem that I solved yesterday. Our LCD display was not displaying properly - words were missing so we just had to guess when it was ready to brew. I called Keurig and they offered a new one for $100 since it was out of warranty. They did ask me if I had descaled the machine and, I'm embarassed to say, I had never done that. Well I descaled the machine and viola! - my LCD display completely came back just like new! Here's hoping the intermittent brewing problem is resolved as well! If you haven't descaled the machine recently, I would strongly suggest giving that a try for any problems you might be having. Of course, to descale, the machine has to at least be able to brew in order to get the vinegar through the machine...
Posted on Apr 04, 2008
SOURCE: My machine only brews 1/2 cup of coffee. I have
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Posted on Sep 30, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: My keurig machine wasn't brewing a full cup so I
do another descale..add more vinegar....run the entire full tank of water....you must have a big buildup of scale...
Posted on Dec 18, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: does not brew coffee consistencty,
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Posted on Dec 22, 2010
woobie dog
  • 1273 Answers
SOURCE: I have the issue of slow flow and the water goes
Hi, Don, W/D here.
There's not a lot of troubleshooting advise out there for Keurigs, but here are a few things to try:
Try brewing a cup, without the K-cup in the holder. As the brewing cycle starts, hold your finger over the return line to the reservoir (lift the lid to the reservoir; it's in the top, back, and it's white). Careful, there could be hot water there. Plug the hole off with a gloved finger and this will run the cycle longer, and may unplug it. De-scaling may have moved some of the accrued sediment into the dispensing lines.
If you haven't tried it, try cleaning the upper and lower tips. Take an ordinary paper clip and straighten it into an "L" with the short side about 1" long. Pass this end up into the upper piercing needle (careful-sharp!) and down into the lower needle. Sometimes, it takes several tries to clear the needles.
If you try the needle clearing, then try plugging off the by pass. Repeat as necessary.
Hope that this helps you, --W/D--
Posted on Feb 05, 2011
Water filter status has red light. Did not replace and now has green light and Ice maker stopped making ice.
Check the water inlet valve for any restrictions. You will need to shut off the valve from the household water supply before you disconnect the inlet tubing.
Check the screen that filter debris, If the screen is plugged, water flow will be restricted and the result will be small or layered ice cubes. Remove and clean the screen or replace the valve.
Inspect the ice maker mold to see if there are ice cubes present. If there are no cubes or very small cubes, then you should look for issues with the water fill system. Inspect the fill tube and the fill cup area at the back of the ice maker to make sure that they are not frozen. If there is an ice buildup in that area, confirm no foreign objects have disrupted the flow of water into the fill cup. If you find nothing the problem is definitely from the water inlet valve
Jun 04, 2015 | Refrigerators
Toilet tank fills slowly
My sister has a two year old Jacuzzi toilet that worked fine until a few months ago. Then it started to take 10 minutes to shut off after each flush. I lifted the tank cover and immediately saw the problem; at least 90% of the refill water was going into the refill pipe instead of the tank. Upon examination I discovered that the plastic part that holds the flexible refill tube to the vertical refill pipe was broken. This part not only holds the refill tube in place, it also has a small orifice at the end to restrict the flow into the pipe. The part was broken in such a way as to let nearly all the water go into the refill pipe instead of the tank, hence it would run for 10 minutes after the toilet bowl was full and waste all that water. I found a small coarse thread stainless steel screw that fit into the plastic attachment piece to help plug the orifice and cut down the amount of water going to the refill pipe. Now the toilet flushes and refills in less than 2 minutes. I'm in the process of trying to find a replacement for that part but so far no luck.
Mar 29, 2012 | Jacuzzi BK37959 White Era?? Two-Piece...
Inside of dishwasher was dirty after cycle, baskets had black in between the screen...took out all bottom and found dirty water, a couple of inches and slime in bottom...cleaned it all out and put it back...
Check the food grinder (small blade spins against a screen) in the bottom of the dish washer drain. I found the grinder to be inoperative and clogged which reduced / stopped flow of the wash water. Also, small pieces of clear plastic food wrap can block flow.
Sep 18, 2017 | Whirlpool GU2400XTP Built-in Dishwasher
My 10 cup Bunn coffee maker leaks from the top of the water resevoir, from the right top side and from the back top. It looses aprox. 2 cups of water onto my counter while brewing. What has happened to...
I have the same problem and I took the coffee maker apart to find out why. It has to do with a leak on a fitting. On mine I found that the fitting where the hole in the black plastic that the water flows through to get into the stainless steel tank needed to be repaired with some silicone sealant to fix the leak. Still making some coffee!
Oct 09, 2009 | Bunn 10 Cup Home Coffee Brewer
Overflow tube disconnected and machine leaks There is a black small hose and and clear small plastic hose both loose and dangling which appear to be reason for the leak, How do you connect each hose?
They press on to the barbed connector. Put the tubing in a cup of hot water to make it more flexible just before pushing it in place.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 08, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Our Maytag icemaker stopped making ice suddenly after we changed the filter. It dispenses water only.
Does the water have a good flow ? Did you try putting the old filter back in ? Never change the filter just because a little red light comes on . Only replace when the ice cubes get small or the water dispensor flow gets slow . I have found new filters that were bad . Distributors make a lot of money for filters just because of that little red lite . Not just maytag , but all other brands also . Try pouring about 1/2 cup of water into icemaker . If it dumps the cubes but doesn't fill , replace the water valve . If it doesn't dump , and holds the cubes for a long period of time , replace the icemaker . Also , you may need to clean the coils of dust , lint , etc....
Aug 20, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Washer hotpoint
hi,
there could be many reasons for this, try these
Air-gap device: The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. if this develops crack or is deformed, you may develop a leak or blockage.
The tube:There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. there could be blockage or deformation in this tube.
Inlet spout:Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. there could be some blockage in this.
try to find the place till which the water flow is unhindered in the machine.
cheers
Jul 26, 2009 | Washing Machines
Not a problem but more of what is it?
the pins are shipping pins, heldin by cotter pins to prevent the tub from shifting in delivery, when the unit is set up initially, the shipping cord releases all the pins ans instead of having htem hit the floor they fall into conviently located plastic cups. they have no function past that you can discard them
Nov 26, 2008 | Kenmore 22422 Top Load Washer
Water leak
it sounds like the bleach fill line. at the top of the washer is a bleach fill cup, it might attach to it. this black bleach fill line attaches to the bleach fill cup to the bottom of the tub.
Jun 15, 2008 | GE WHRE5260E Top Load Washer
Black residue
Maybe a ruber washer is breaking apart, But my advise is take the inside apart clean and inspect it and then test it.
Dec 17, 2007 | Amana 24 in. ADB2200AW Built-In Dishwasher
Keurig Vue Brewing System Logo
19 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
