Question about Dishwashers
Dishwasher dms500tr, F3 keeps coming up. What is it and how can I fix the issue?
What is F3 and how do I fix it?
    New Friend:
  • 56 Answers
It is a drain line error.
what happened to your drain setting did anything change, does it drain to the disposal?
Do you have a new disposal?
Posted on Apr 19, 2014
Samsung dms500tr comes up with e2 error there is water to the aqua valve
Hello Keith:
My name is Peter. I am a retired field service appliance technician.
You have a faulty fill hose and valve assembly.
Part Number 1673572 Cost: $136.00
It is located in the back of your dishwasher.
hwk1huedygosaaaaaelftksuqmcc
Dec 13, 2014 | Samsung Dishwashers
Sumsung dishwasher DMS500TR fault- F3 how do I fix it?
where does this drain to?
is there a way to un install the dishwasher and still have it operational?
If you can get to the point where the drain hose is free and relaxed or out of the drain point and in to a 5 gallon bucket.
run it.
if the drain is free of kinks or obstructions then see if the error code shows back up.
Apr 18, 2014 | Dishwashers
F3 code and beeping noise
Not sure which model number dishwasher you have. But usually F3 error means a water temperature related fault. The water temperature is too high. Hopefully you are not using the hot water supply of your house. If so then ensure it is less than 80 deg C. If using normal mains supply (cold water) then it is likely the temperature sensor in dishwasher has failed. Not an easy job to fix as it is integrated into the water heater element at the base of the drawer for the DD603 drawer type dishwasher.
Mar 19, 2013 | Fisher and Paykel Dishwashers
I HAVE THE SAMSUNG DISHWASHER dms300trs AND IT SHOWS F3 ERROR ???
Have the same problem with brand new, unused DMS500TR dishwasher. Rang Samsung, they said F3 is a water leak error.
Aug 19, 2010 | Dishwashers
How to Fix Code F3 on GE Oven
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | GE Ovens
Fisher/ paykel dishwasher says F3
f3 water temp sensed at greater than 85 c or 185f check temp sensor or is element on all the time
Jun 29, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel Dishwasher
If the machine has stopped and still has water in it, the drain pump is jammed. The pump is situated under the machine on the right hand side and can be accessed if you tilt the machine back against a wall. Try turning the motor fan by hand. Sometimes it will clear any foreign matter caught in the pump. If still jammed, remove pump by switching the machine off at the wall and pulling out the plug. Remove the wiring harness from the pump and turn it clockwise while releasing the white plastic clip which holds it in place and keeps it from turning on its own.
Oct 03, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Dishwashers Logo
156 people viewed this question
Top Dishwashers Experts
