Are you sure the water is on and water is getting to the machine.
If there is no water the water valve will open & hum & nothing else will work till the tub is full.Check the little screens on the water valve behind the hot & cold hoses where they hook up the the machine they get clogged
up sometimes just pull them out and clean them. Hope this helps you
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem: 1) check to make sure the water is on 2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc. 3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
It sounds like your water inlet valve is either not getting a signal to let water in from your control board or the water inlet valve is defective. Since you are hearing a humming noise, I would say that the water inlet valve is defective or has been damaged in transit.
If you hear a humming, the coil on the water valve is probably OK. On warm, you are getting cold fill only. (hot + cold = warm) Take the hot water supply hose off the machine and look inside where the hose attached to the washer. There should be a screen inside. Remove it and clean it out. Also, check both ends of the supply hose, as sometimes you will find a screened washer in there too.
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
The humming noise is the fill valve...this sounds usually is overpowered by the water fill, but if its faulty it wont let the water in....Replace the fill valve
turn off the water and remove the hoses from both the wall and from the back of the machine. check the screens inside of the machines water valve, they are probably clogged. do the same for the hose screens on the other end. replace the hose screens at the wall end and remove the screens from inside the machine. replace hoses and turn the water on and you should be good to go
