Question about Garmin Rino 530 GPS Receiver
Not powering up
My 530 will not turn on with fully charged battery, acts like switch is not working to connect and power up. Yet it turn itself on when you put a dead battery on it and hook it ti the charger ??
  • 14 Answers
SOURCE: Garmin ique 3600 won't turn on after battery goes dead
I had the identical problem; I called Garmin and a new battery = $50, installed only @ the factory. I tried buying one off eBay, but those batteries spec out ok but don't have the pigtail leads required for my M3 (probably would work just fine for M5). I soldered on the pigtail from the old battery from my M3, then put it all back together. Works! However, the new battery ultimately drains down over several hours so when I'm not using it I have to trickle-charge the thing constantly. Bottom line: I suggest sending your M3 back to the factory for a new battery rather than trying to replace it on your own.
Posted on May 30, 2008
SOURCE: dead battery- willnot charge with supplied charger
my c320 has a dead battery-how to change?
Posted on Oct 04, 2008
  • 634 Answers
SOURCE: Unit only powers on when attached to base charger
sounds like internal battery is dead, if underwarrenty contact company, if not these batteries are not user changeable u will have to use as is or replace
Posted on Jul 07, 2009
SOURCE: won't turn on or charge
Press Mode (bottom left side button) and Reset (left front button) simultaneously, let go, then press On (top left side button).
Posted on Aug 06, 2009
bob_computer
  • 3153 Answers
SOURCE: Garmin C530 won't power up. I fully discharged
How old is it and does it get quite a bit of use
If so then consider replaceing the battery
Ebay has a good selection from a wide range of reputablesellers and very good prices
Check Here
Posted on Aug 26, 2009
My galaxy r don't open again after the battery drained. When I charged it there's sign that it is charging but I cant open once I hold the power button
I don't have that particular phone, but my phone has a small LED in the front that turns to red when it's in the charger with a fully drained battery, yellow when it's above 20% charge, and green when it's fully charged.
If the phone is fully charged, but it won't turn on when you press the power button, there's probably a problem with either your charger or the battery itself. I suggest replacing the battery, or when it's built into the phone itself visit the store where you bought it. They might know what to do.
Nov 26, 2014 | Computers & Internet
The power on the Panasonic Palmcorder IQ PV-A206 turns itself off. I've tried plugging directly and with a fully charged battery, no luck.
please make this test and fix it. God bless you
If the video camera doesn't work, make sure the battery is charged (see The Battery Recharger Fix-It Guide) or replace a battery that won't hold a charge. Make sure the AC adapter is connected properly. Clean any dirty contacts on the battery, charger, and AC adapter with a cotton swab dipped in denatured alcohol. Remove corrosion with a clean pencil eraser, then wipe the area with an artist's brush to remove any debris. Find and test the fuse, if any.
If the power goes off soon after starting, recharge a low battery. Also, turn the video camera power off, then turn it back on and eject the tape. If the problem persists, check the fuse
If the battery won't charge, clean the contacts and fully discharge the battery, then recharge it. If the problem persists, replace the battery
If the video camera works intermittently, remove and reseat the to establish good contact. If necessary replace the fuse
Nov 08, 2013 | Sharp Panasonic Palmcorder Iq Model...
The battery is not charging
You can try and reset the player. resetting a Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Some things to check for when your player does not act like its taking a charge.
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location Try plugging into different USB ports (i.e. USB port in the back of the computer); occasionally the front USB ports have limited power to charge up the device.
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port.
I have some tips posted here on MP3 players and their problems. Connection problems MP3 player not found by computer
SanDisk Mp3 Player Frozen
Dec 25, 2010 | SanDisk Sansa Clip MP3 Player
My battery is fully charged but when i turn the camera on it shuts right back off
SOunds like your battery is bad. try discharing it :
  1. Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
  2. Take out your battery and slide it into your battery charger.
  3. Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
  4. Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Jun 13, 2010 | Sanyo VPC-T1060 Digital Camera
Garmin 530 doesn't turn on
if the light goes off it would indicate that the battery is fully charged.
does the unit function like a phone when charging as in showing a chg indicator even if it is off? If so there are more serious issue than maybe just a bad power switch.
Oct 22, 2017 | Garmin Rino 530 GPS Receiver
Loosing power randomly
how old are the batteries and how many times they were charged without being fully drained can cause a short life for the battery. Try a new battery-fully charging it properly, but dont charge it again till it goes off by itself completely. If you have a wall charger, plug your phone in. If it stays on that way, check your 'power save' settings. That can also make your camera shut off. Try these steps first and see if it changes the 'battery' from being empty to full and stays on. hope this helps
Aug 24, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Hi .my nokia 6220 switches itself off after the battery has been fully charged .once its switched on again it works okay
It may be due to power surge happening when you remove your charger from phone.
1.Try changing your power adapter
2. Switch off the power adapter first before removing the charger connection from your phone.
3. Remove the battery and clean the copper terminals with a cloth
4. If none of these idea works, then give a try my restoring your mobile to factory settings.
Aug 09, 2009 | Nokia 6220 Cellular Phone
1993 Plymouth Sundance will not start or turn over?
Make sure battery is fully charged. Connect a test light to battery ground and touch batt+ to check if light. Now test that there is power to the starter heavy wire directly connected to the starter. If power, good. Now test for cranking power to solenoid wire which is on top of starter; have someone cranks as you check for power. If there is power, starter could be acting up. If not, check all fuses and neutral switch. Be careful working around moving and hot parts.
Jun 12, 2009 | 1993 Plymouth Sundance
On HP 530 notebook battery/power indicator is always on as long as battery is connected and even when ac power is connected the situation is still the same.
Clarification of your battery/power led indicator:
Solid amber:
Battery is charging at 0% - 89% capacity
Solid green:
Battery is charging at 90% - 99%
Blinking amber:
Battery is low
Led is of:
Battery is charged
Dec 04, 2008 | HP 530 Notebook PC
E260 4gb sansa not turning on
some may be due to low battery power or due to software problem...while charging stop once the charge gets full,...dont overcharge the battery,,,,,,the battery life gets reduced
Jan 03, 2008 | SanDisk Sansa e260 MP3 Player
Garmin Rino 530 GPS Receiver Logo
48 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
