Question about Whirlpool Duet White Front Load Washer - WFW70HEBW
Water stuck in door - Whirlpool Duet White Front Load Washer - WFW70HEBW
Amanda refrigerator w/ ice and water in door. Button for water is stuck and keeps running every time we close the freezer door all the way
You have an obstruction in the door that is pressing the water button. Look for that where the water line is . This is probably a physical problem.
Feb 10, 2013 | Refrigerators
Ice maker, water panal on side by side refigerator not coming on when depresing handle
The water line could be frozen. Remove the water filter and see if it frozen. Also, see if the water dispenser works with the filter removed.
Sep 09, 2012 | Maytag MSD2572VEW (25 cu ft) Side by Side...
WHEN THE WATER IS TURNED ON FOR ICE MAKER IT WILL NOT STOP RUNNING THRU THE DOOR DISPENSER FOR WATER
There are several things this could be. The switch for the lever that turns on the water could be stuck and holding the solenoid on. The other thing could be the water valve could have something stuck in it that is keeping it from shutting off the water. I have taken these apart in the past and found sediment stuck in the valve. Since you say that you have filteration on the line, is the filter installed? If you find a canister looking thing on the water line, often in the basement ceiling, then the likely culprit is the switch.
Feb 24, 2011 | Kenmore 21.7 cu. ft. Side-by-Side...
Why does water dispenser stop working? Seems to work fine after thawing freezer for about a day and seems to freeze up. Water line for dispenser routes through the door.
The water is door spigot can be freezing up if the ice door is stuck open. When you actuate your ice in door function you hear a solenoid CLICK. That solenoid is supposed to open the ice door flapper. If the flapper is not funtioning correctly (stuck open) then in as few as as 2 - 3 days your water in door can freeze again. If you want unit specific information we need your make and model number to better help you.
Thanks for hoosing FixYa,
Kelly
Feb 22, 2011 | GE Refrigerators
Lg french door ice cubes stuck to together. please advice what to be done?
if the ice cubes get stuck together its usually because the ice maker water solinoid is letting too much water in. could have a bade water valve.
Aug 04, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Power locks stuck.... After a cold Christmas day,
should like water has frozen inside the door on the mech, its probely released by now , or water has cause a short in the door electrics
Dec 26, 2009 | 2007 Kia Sedona LX Minivan
Washer Dryer - drum is filled with water even when switched off and door can still open!
Try the valves inside the back where the water hoses connect to the machine they should default to the closed position when water is not required
Oct 31, 2008 | De Dietrich LZ9619 Front Load Washer /...
Door wont open
The door switch could have stuck closed. there is a way to open it up manually.
if you can just access the water pump filter cover, and at the back part of the door switch you will find a plastic ring attached to the door switch, pull it down to open the door.
drain first the water if there is water left in the unit by slowly opening the water drain filter cover and drain the water slowly.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Washing Machines
Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Jun 15, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Door is locked! Won't open! Laundry is stuck inside!
If the water has not completely emptied, this wont allow the door to open. Check by lowering the outlet hose into a bowl. If a fair amount of water comes the problem is likely to be a pump blockage
Oct 22, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet White Front Load Washer - WFW70HEBW Logo
18 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
