Question about Lexmark X5470 All-In-One InkJet Printer
MY PRINTER WON'T PRINT
POWER IS ON. "COPYING" IS ON AND IT CYCLES. I PRESS BLACK KEY. N OTHING HAPPENS
    Problem Solver:
  • 8 Answers
How old is the printer? if it is 4-6 years old, you may need to search for a replacement because lexmark printers are very technical. You can probably call lexmark because i had this problem. They sent me a free printer!!!
Posted on Jun 19, 2009
X4270 won't copy after replacing black cartridge. It did run an alignment page, however.
Try this approach:
  1. On the printer operator panel, on Copy mode, press Options.
  2. Select Maintenance.
  3. Select Clean Cartridges
Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that Copying is properly functioning now.
Aug 08, 2011 | Lexmark X4270 All-In-One InkJet Printer
How do I print a document from my files ? I hit the print button. but n othing happens. I need to print newsletters from my e-mail. e-mail is wmmurf @ att.net Thanks Martha M.
dear Martha
if you need to print your document directly by pressing quick print button then you have to set your printer as the "default printer". to do this you have to go to Control Panel > Printers and Faxes and then right click on the printer you want to set and then click "Set as Default Printer" your problem will be solved.
Thanks
Gagan
Mar 24, 2011 | Office Equipment & Supplies
Everything is work fine only the black ink cant print,i only hv this printer for 5 month ,use it not more than 20 print...black ink is new .
It is quite likely your the print head is clogged from lack of use. You need to print a Print Quality Check Sheet.
Press Menu.
Press the up or down arrow key to choose Ink or Ink Management. Press OK.
Press the up or down arrow key to choose Test Print. Press OK.
Press the up or down arrow key to choose Print Quality. Press OK.
Press Color(Colour) Start. The machine will print the Print Quality Check Sheet.
Compare the Check Sheet to the examples here:
http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/000700/000035/faq000735_011.html?reg=as&c=au&lang=en&prod=mfc255cw_all&Cat=112
If there are problems say yes to proceed with cleaning the print head. You may need to complete several cycles. If the print quality does not improve after 5 cycles you may need to contact Brither Customer service.
Trust this is helpful.
http://welcome.solutions.brother.com/bsc/public/as/au/en/dlf/download_top.html?reg=as&c=au&lang=en&prod=mfc255cw_all
Dec 28, 2010 | Brother MFC255CW All-in-One InkJet Printer
Is it possible to disable the date chip on the ink cartridge? I have a HP8250 Photosmart printer, the yellow ink is outdated and I cannot even print a black and white document! I do not live near any...
Black printer ink in HP Photosmart may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Aug 21, 2010 | HP - HP Photosmart 8250 printer
My treadmill will not incline. when you press the
Wondering if you found a solution to this problem yet? I seem to have the same situation with my 730cs treadmill. It is inclined and will not move up or down...thanks.
Mar 02, 2010 | Proform 730 Folding Treadmill Model...
When I print something out there is nothing on the papper
Did you run a test print? And then check and clean the print nozzles:
Make sure there is paper.
Press the "Maintenance" button once to display an A.
Press Black or Color
Let it run its cycles.
If there is still no print:
Press "Maintenance" button twice to display an H
Print "nozzle check"
Let it run it's cycles.
Still nothing:
Press "Maintenance" button until an M
Still nothing:
Replace BOTH cartridges and repeat the first nozzle check.
If this doesn't work, contact Canon
Jan 27, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Kodak Easyshare 5300 printer will not print black
Print a self test diagnostic page to check the status of the black ink and print heads.
To print the self-test diagnostic page
Control panel: Press (Configuration Page button), or press and hold the (Cancel button) for 3 seconds.
For models that support networks: Press (Configuration Page button).
If these are all showing OK then clean the printheads
To clean the printheads
If printed characters are incomplete, or dots or lines are missing from printouts, ink nozzles might be clogged and you might need to clean the printheads.
NOTE: Cleaning uses ink, so clean the printheads only when necessary.
The cleaning process takes up to 3.5 minutes. Some noise might be generated in the process.
Control panel: Press and hold (Power button), press (Cancel button) two times, press (Resume button) one time, and release (Power button).
If this fails then replace the black cartridge and run a clean cycle again and then a self test diagnostic then try printing again.
Sep 27, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
After copying a couple of pages, the print out suddenly became ALL BLACK. After turning off for several minutes, the same BLACK print out comes out. But I can still print good copies from CPU documents. So...
I'm brasilian, I solve it and will pass it to you:
Brasilian Portuguese:
Resetar = desligar completamente a impressora, ligar pressionando a tecla "menu"
assim ela entrará no modo "MAINTENANCE" apertar "01" aguardar, apertar "99". Ela irá resetar
completamente e reiniciar.
English:
Reset = completely off the printer, turn on by pressing the key "menu"
so it will enter in the "MAINTENANCE MODE" press "01" wait, press "99." It will reset
completely and restart.
Sry for the weak english xD I hope I've helped.
Ramon
ramon.cnet@hotmail.com
Apr 09, 2009 | Brother DCP 130C All-In-One InkJet Printer
Black won't print
I have this same model printer and had this same problem. I solved it by running the cleaning cycle repeatedly (30 times or more). It nealy drained the black cartridge, but they're cheap compared to a new printer ($100 for the mfc240c that replaced it). Press the ink button to the left of the display. Select "test print" and "print quality from the menus, then hit print. After printing, the display will ask if quality is ok. Press 2 for no. It will ask if the black was ok, press 2 for no, if the color looks ok, then press 1 when it asks if color is ok, then press 1 when it asks to start cleaning. In a minute or so, it will beep and tell you to press start. Once the sheet prints again, repeat the same sequence. I didn't even wait for the display, I would just press 2,2,1,1, each time it printed. At first the black section was blank, the one dash appeared, then two or three. I gradually gained on it until I had most of them working again, then let it set overnight and ran a few more cycles the next day and it finally all started working.
Jun 22, 2008 | Brother MFC 210C All-In-One InkJet Printer
Will not print
Go to print. Prinrt comand comes up just fine. Press ok and nothing. Document pending is all I get. Printer seems to be ready but goes into power save waiting for next comand,
Jan 12, 2008 | Lexmark X83 All-In-One InkJet Printer
Lexmark X5470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
