Question about Fisher and Paykel Washing Machines
Wh70f60w1 won't start - Fisher and Paykel Washing Machines
I have a fisher & paykel front loading washing machine & need to know what each of the three slots where washing powder goes stand for? Machine Product Code 98707 & numbers WH70F60W1
You normally have 3 cups; 1 for Bleach, 1 for Liquid Fabric Softener, and 1 Liquid Clothes Detergent. I don't ever recommend using Laundry powder in front loads as it has a tendency to not fully dissolve and will build up in the dispenser overtime and prevent your clothes from washing.
Feb 12, 2018 | Fisher Washing Machines
Car won't start
Car won't start Ken, You did not give me much info, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Troubleshooting Car That Won Start
Engine cranks but won start Troubleshooting tips
Engine Won Crank or Start
Diagnostic flowchart for car that won start or stalls Troubleshooting for...
Mar 23, 2016 | 1999 Oldsmobile Intrigue
Engine won't run
Cranks but won.t run, Check the attached links,instruction and guides, Good luck
Troubleshooting and Fixing Car that Won Start
No Start Diagnostic Basics EricTheCarGuy
Mar 22, 2016 | Cars & Trucks
Won t start will not turn over no crank do have lights and battery
then I can only suspect the starter has failed .
Oct 24, 2015 | Cars & Trucks
WH70F60W1 fills but won't wash
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
May 17, 2012 | Fisher and Paykel Washing Machines
2002 saturn sl won't start, turn over but won't start
Done cars have a kill switch if they are low on oil. Check your oil. If the oil is good, it may be the ignition switch.
Jan 01, 2018 | 2002 Saturn Sl
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
