Question about Metrologic Instruments 9520 Voyager
Serial keyboard emulation - Metrologic Instruments 9520 Voyager
Unformat floppy disk emulator
Your questions,what does it mean?
If you use PA50SD,of course you don't need floppy emulator.
If you use PA50 with floppy emulator,you need to format the flashdisk with special softwares (SFD 1.23 etc) that usually included when you buy the emulator.
Jan 19, 2014 | Korg Pa50 Professional Arranger Keyboard...
Tip
Using PC keyboards with your Mac
Some Mac owners may not be happy with the keyboard that comes with their Mac. Unfortunately there aren't a whole lot of third party Mac keyboard choices on the market. However, you can just as easily hook up a normal PC keyboard to a Mac, and any USB keyboard would do.
There are still other problems, sometimes when you hook up a PC keyboard to a Mac, the function keys, such as the Alt, Ctrl, and Windows key may not be assigned correctly, and it doesn't emulate the same function as the functions keys for a Mac keyboard.
For some keyboards, such as many Microsoft keyboards that comes with Intellitype preference panel for the Mac, this can be fixed with just a few settings tweak. For keyboards that doesn't come with Mac specific software, you can simply use software such as:
DoubleCommand
This utility will allow you to reassign keys on your PC keyboard to correctly emulate the same behavior as a Mac native keyboard.
on Feb 23, 2010 | Computers & Internet
Unformat floppydisk emulator
Floppy emulator can't read flashdisk untill it formatted.
Flashdisk MUST BE format by special softwares.
Install the softwares on the PC/notebook.
No matter how much flashdisk capacity,floppy emulator will continue to read as one 1.44MB floppy.
Through special softwares formater, we can determine how many floppy that we will create. Lets say,100 floppy (or more),softwares will format the floppy 1.44 100 times on the flashdisk.
So we have 100 pieces 1.44MB floppy inside flashdisk. If one floppy can store about 30 MIDI songs,then it means that we already have 3000 songs in flashdisk.
If you format for 100 floppy,the total capacity of about 144MB.
So,flashdisk with a 2GB capacity, is more than enough to store songs.
To change from one floppy to enother,just press bank number at floppy emulator panel.
I hope this helps.
Regards.
Jan 17, 2014 | Korg Pa50 Professional Arranger Keyboard...
I have magellan 2200vs it works fine but it cant read anything
If the interface is serial RS-232, only a POS software is used to read it into the application. PCs can display a bar code directly only if the interface is USB or PS2 and emulating the keyboard.
Dec 23, 2013 | PSC Magellan 2200VS Hands Free Barcode...
Need playstation 2 emulator 1.20.50 serial code
I recommend you using a freeware PS2 emulator. They are much better. PCSX2 is exceptionally good.
More info: http://www.emulator-zone.com/doc.php/ps2/
Apr 20, 2010 | Sony PlayStation 2 Slimline Console
I have downloaded nero 8 3.2.1 with emule, I need serial number
http://isohunt.com/torrent_details/161987509/nero+8?tab=summary
should be what your asking for
Mar 31, 2010 | Ahead Software Nero 9 Full Version for PC
When printing from attachmate the enterprise or extreme the application crashes and closes with no errors and not print job
I'm gonna say it's because your PC does not recognize the SDLC data. I believe your board is a 3276 controller/terminal emulator and it only displays the mainframe data. There would be no OS connection to a local printer.
Oct 16, 2009 | Attachmate SDLC 3270 Emulation (147446)...
Logitech keyboard on linux-driven machine.
Dear sirs,
I did what I should have done before posting the problem.
I retrieved some packages out of the build-in repositorie,
and now most of the function-keys are operateble.
However, to solve the rest of the problem, I have to
build and install Wine (the Windows-emulator in order
to to use the cd-rom that came with the keyboard.
Thanks for your concern in this matter.
Johan Bruynooge.
Jul 28, 2009 | Logitech S 510 Remote Control, Multimedia...
Need driver software
hi first you need to know what the interface is then if its keyboard wedge programme for keyboard emulation. if its serial you will need some type of pos programme to run it in if its usb it should be plug and play hope this helps 2dornot2d
Sep 18, 2007 | Metrologic Instruments Orbit MS7120...
Metrologic Instruments 9520 Voyager Logo
42 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
