Question about Lexmark E260dn Laser Printer
E260dn toner light on
I have just bought this printer and has printed less than 30PAGES! and the toner light is constantly on. Tried holding the start button, shaking cartridge, CHANGING A NEW cartridge. still does not work.
checkitright
  • 1362 Answers
SOURCE: Toner light blinks and error light shows
1- you either got a bad toner ( the chip on it is telling it it is bad)
happens sometimes with recycled toners.
Return it and tell them it is defective.
The chip needs to be replaced.
Try this but doubt it will work,
open front door hold down go button, all lights will flash in sequence wait for it to stop turn off and on and close door.
Posted on Oct 25, 2007
SOURCE: E120 won't print. Orange toner light is on - but the toner is nearly new ...
This problem is caused by an imitated toner............ All you need to do is change it to the old cartridge and see if the light will not be stable. Well the solution i guess is simple............. just go to get a new original toner and it should work well. Hope this helps.
Posted on Sep 29, 2008
Printtech
  • 1087 Answers
SOURCE: TONER LIGHT STAYS ON WITH NEW TONER CARTRIDGE
If the main problem is just the toner light on then what you could do after installing the new toner is resetting the printer. You could do that by powering the printer off, open the front cover (as if you were to replace the toner) with the front cover open and the printer off push and hold the two buttons on the printer and turn the printer on while holding down the buttons then once the bottom light stays on solid, release the two buttons and that should reset the printer.
Now if the toner light is blinking that means that you have reached the 30,000 page mark and the Photoconductor needs to be replaced. If that is not the case you can follow this link to a procedure where it will explain how to reset the Photoconductor. http://bit.ly/91SWS3
Posted on Mar 19, 2010
Printtech
  • 1087 Answers
SOURCE: Lexmark E260dn toner light is
Toner light is ON, I would assume that the light is solid and not blinking. You can press and release to clear the light sequence and continue processing the print job. With the printer turned off, remove the toner cartridge and shake it to extend its life. Check the replacement toner cartridge if it is the one suitable for your region.
If the blinking light is on Toner Low, press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
For further assistance, please call Lexmark Technical Support.
Posted on Jul 06, 2011
Printtech
  • 1087 Answers
SOURCE: Lexmark e260d printer 4th light
If the blinking light is on Toner Low (4th light starting from left), press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
For further assistance, please contact Lexmark Technical Support
Posted on Jul 07, 2011
The toner light on my printer keeps blinking even with a brand new cartridge in it?
its the toner light or photocondutor light?
Open door and push stop for 15/30 sec.
Apr 08, 2015 | Lexmark E260dn Laser Printer
The exclamation and the toner lights are steady on yellow and i can't print
needs pcon or toner replacing exausted hence toner light and ! mark and will not print por before changing or it will stay the same
Nov 17, 2011 | Lexmark E260dn Laser Printer
Orange light is constantly flickering. I have put a new toner cartridge and now a new photoconductor kit in and it is still flashing
Please make sure to reset the printers' pc count. Below are the steps.
1. open the front cover. Leave the printer powered on. 2. With the front cover open, press and hold the stop/cancel (pattlnk_392009_184-e260%20stop%20button.gif) button. 3. Eventually all of the lights will begin flashing, indicating that the photoconductor page count has reset. When you see this light sequence, let go of the pattlnk_392009_184-e260%20stop%20button.gif button. 4. Close the front cover.
If you wish to confirm that the photoconductor page count has reset, print a menu settings page.
Jul 11, 2011 | Lexmark E260dn Laser Printer
How do you reset the photoconductor counter on the lexmark e260dn? the light is blinking yellow right after i replaced the toner cartridge. Have put this printer through a lot of use over the last 3/4 of...
1.open the front cover. Leave the printer powered on. 2. With the front cover open, press and hold the stop/cancel (X) button. 3. Eventually all of the lights will begin flashing, indicating that the photoconductor page count has reset. When you see this light sequence, let go of the X button.
NOTE: If you wish to confirm that the photoconductor page count has reset, print a menu settings page.
Jul 09, 2011 | Lexmark E260dn Laser Printer
The toner and the exclamation lights are steady and i just replaced the toner for thos one E260A11A AND IT DOESN'T PRINT ANYTHING not even the test page please help need to print inmediatly
Press and release to clear the light sequence and continue processing the print job. With the printer turned off, remove the toner cartridge and shake it to extend its life. Check the newly installed toner cartridge if it is the one suitable for your region.
Jun 23, 2011 | Lexmark E260dn Laser Printer
We changed the toner cartridge and the toner light keeps blinking..
Press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced
Jun 14, 2011 | Lexmark E260dn Laser Printer
There is a blinking orange light on my printer but I replaced the toner not too long ago.
Apr 20, 2011 | Lexmark E260dn Laser Printer
Lexmark E260dn toner light is still on after changing the toner cartridge
Apr 12, 2011 | Lexmark E260dn Laser Printer
Printer won't print. one of the lights is on, but I'm not sure what the symbol means. Cannot locate user manual.
Can you provide us information which light is on on the printer? the printer lights is represented by six light. starting from the left is error light, paper jam light, load paper light, toner light, ready light and continue button (green button). The light sequence will indicate a specific problem on the printer.
For further assistance, please contact Lexmark Technical Support.
Jan 26, 2011 | Lexmark E260dn Laser Printer
Lexmark E260dn Laser Printer Logo
13 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
