Question about Gentron 2000W Inverter Generator
2000wi powerhouse starts and then runs for few minutes then shuts down
Truck start up run great couple minutes then shut off let set few minutes then crank up run great 30 second shuts down like you cut key off let set few minutes crank right back run fine then dose same
Sounds like it is running out of fuel. Maybe a bad fuel pump, or clogged filter. If it is carbureted, a stuck float valve or clogged float valve might be the problem.
Telling us year, make and model would allow us to help you more.
May 31, 2015 | Cars & Trucks
Why does my powerhouse PH3100ri generator run fine for about 5 minutes or so then dies and it will not start again in till it sets for 30 minutes or so then it will fire right up please help!!
Maybe faulty CDI ignition module ? There are a number of components ( electrolytic capacitors ) in the module that can fail with temperature rise.
A test... Remove the ignition plug lead when motor has stopped after the 5 minutes and put a wire inside the plug cap and place end near a metal part of motor. Careful not to zap yourself... Pull starter and look for ignition spark. If there is no spark then probable fault is ignition module. If there is spark then problem may be in fuel system.
Do check vent on fuel tank is open.
Do check choke is turned to off once motor is running.
Do check the oil level as the low oil cutoff can cause shutdown and will result in no spark.
Mar 16, 2015 | Powerhouse PH3100Ri Inverter Generator...
I have a PH3100Ri . It will not start with remote or with manual switch. The starter motor does not turn. Battery has full charge. Any ideas
My powerhouse PH3100 ri turns over with the remote and key but will not start , when it did run it ran for 10 mints and shut down and now it will not start at all
Jun 30, 2013 | Powerhouse 3100 Watt Inverter Generator...
Flat panel TV comes on by it's self
It sounds that the voltage output from its internal power regulator board is not proper. Check it.
Feb 04, 2013 | Samsung UN19D4003 TV
Car shuts off at red lights
sounds like a lose ground wire
Dec 15, 2008 | 2002 Oldsmobile Alero
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Gentron 2000W Inverter Generator Logo
32 people viewed this question
Top Gentron Electrical Supplies Experts
Phil Walker
Phil Walker
 Generator Guru...
Generator Guru...
Ted Maxwell
Are you a Gentron Electrical Supply Expert? Answer questions, earn points and help others
