Question about Dewalt 18 Volt Compact Drill Kit
Having trouble removing keyless chuck from 18V DC759
    President:
  • 512 Answers
Inside of chuck you have a screw, remove screw then tighten an big allen wrench into chuck, short side in, then hold drill and hit allen wrench with a hammer quickly, should break chuck free.
Posted on Jun 19, 2009
How to remove chuck
Check first to see if there is a screw or allen head bolt deep down in the centre of the chuck, securing it against loosening due to vibration. The trouble is the head of such a screw often gets damaged, making it difficult to remove.
Then the chuck itself will be screwed onto the spindle with a RH thread, so it tightens in normal use. It may be very tight, so insert a tight fitting steel stub into the chuck key hole, and hit it sharply.
If it is a keyless chuck, there should be a slot there somewhere to fit a piece of metal into so you can hit it. Use a piece of soft steel or copper if you have it.
Nov 22, 2013 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
I,m having trouble getting the chuck off my 13618 bosch 18v hammerdrill. I have removed the screw then chucked a piece of hexed stock into it and reversed a half inch impact to it and it won't bre
Make sure it is in low gear on drill mode. try with just a bar in the socket and hit the end to shock it. This is sometimes better than a constant force.
Nov 21, 2012 | Bosch 13618 - 2G 18V Brute Tough Cordless...
Ryobi 12 volt drill/driver- cannot unlock the keyless chuck
replace the part you have taken out .
get a pair of stilson spanner adjust it so it goes around the chuck and do it and then it will ease off to do it up by hand
Sep 21, 2017 | Skil 2887 - 06 Factory - Reconditioned 18V...
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
How to replace chuck for DC759
First of all, open the jaws of the chuck and look inside. If there is a screw in there you should be able to do this yourself. If there is no screw (sometimes torx/star head, sometimes flat/straight head) then yo uwill need to take it to a service agent/dealer as a special jig is needed to lock the spindle/chuck.
If there is a screw you need to remove it. It will be a left hand thread so turn it clockwise to remove. It will be proabbaly be tight as it will be thread locked in the factory. Once this is removed, clamp a 10mm allen key in the chuck adn steady the drill on a workbench. The actual chuck will be a normal thread so this is removed by turning it anti clockwise. It will take a sudden impact to start it off so put the gearbox in a low gear and turn the clutch to 'drill mode'. Holdong the machine steady you can hit the allen key sharply to start undoing the chuck. It may take several hits to get it going.
Jun 13, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My DC759 drill has no bearing clip
http://www.ereplacementparts.com/dewalt-dc759-type-18v-cordless-drill-parts-c-1009_1162_2837.html
Here is the parts diagram. I hate to say it but I always have problems getting the chuck out of the clutch/transmission without breaking something. I havent figured out how to keep the spindle from moving while I try to turn the chuck. Sorry if this doesnt help much.
Nov 26, 2009 | Dewalt 18 Volt Compact Drill Kit
Removing the drill bit from Makita bdf452.
try hitting the chuck with an hide mallet in the undo direction, it just needs shocking, to rease it
Feb 12, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Keyless chuck
You will find a screw inside the chuck that needs to come out first of all but beware that it will be a reverse thread. This is to stop it loosening whilst in use. then you will need to unscrew the chuck but it isn't easy as you have to hold the shaft that the chuck is attatched to. You can sometimes take the chuck off by holding it and pulling the trigger while in reverse. (but they can be stuck fast).
Aug 10, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Drill chuck swap
1. Turn the screw clockwise to take it out.
2. Then you needs 3/8 allen key & insert the short side of the allen key & tighten the chuck.
3. hold the drill at the edge of the table & wack the allen key
counter clockwise & do it again as needed.
4. dewalt keyless chuck will fit but you might add a washer to insure the chuck is not rubbing the clutch collar.
5. putting it back together the other way.
Jun 01, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt 18 Volt Compact Drill Kit Logo
566 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Jim Thurston
Craig Butler
Craig Butler
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
