Question about LG WM-0532HW Front Load Washer
Where is the filter located on LG WM3001 HPA steam washing machin
Where the filter located on the machine
  • 1462 Answers
SOURCE: banging pipes when washing machine fills
it is called water hammer and is difficult to cure. try turning tap off halfway. another cure but difficult and not 100% is to take the copper feed pipe round in a circle
Posted on Sep 17, 2008
SOURCE: Dead LG WF-T8016TP washing machine
Well I found the problem - fuse had blown.
There is a circuit diagram on the back of the washer that allowed me to locate the fuse. Take off the rear top plastic panel (behind the folding lid) by removing the two screws on the back. Inside close to the power cord you will find a fuse holder and an in-line ceramic fuse, 125V 12A. I checked mine for continuity and it had blown (as to why, I don't know yet - maybe the motor drew too much current with a large wash load?) - anyways, I replaced the fuse and everything works now!
Posted on Feb 15, 2009
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
SOURCE: LG WM2355C water leaking under machine after washing finished.
I had this same problem and it was not the supply connections or filters! Under the machine is a rubber bellows. The bellows had sprung a leak. The part was about $10 from Sears and I repaired it in about 30 minutes. The machine is heavy so be careful. Get a friend to make sure the machine won't rock or tip when you're making the repair.
Posted on Sep 16, 2009
DirtyOldGit
  • 5 Answers
SOURCE: what is the AE error code on LG steam direct drive washing machin
the AE code means that there is water in the base I found that the steam heater element in mine was leaking so after a quick repair using silicon and a good clean after drying the water out of the base it now works again
PS I used to be a washing machine repair engineer! I wouldn't suggest that you start opening up your washing machine!!!!
Posted on Mar 31, 2010
Why is my samsung vrt steam washer leaking from the bottem right model #WF331ANW/XAA
Locating And Repairing A Mystery Leak In A Front-Loading ...
? 3:55
www.youtube.com/watch?v=3D5q1ynWb-U
Jul 28, 2012 - Uploaded by SamuraiRepairman ... source of a leak in a front-loading washing machine and then mercilessly repairs it. ... LG Washer Repair & Diagnostic -Leaking Water from front & bottom ... Samsung Front-LoadWasher Disassembly - Washing Machine ...
Samsung vrt steam washer leaking - Fixya
www.fixya.com/support/t13638559-samsung_vrt_steam_washer_leaking
Jul 15, 2012 - Samsung vrt steam washer leaking - Samsung WF338AAB 4.0 cu. ft. ... I have a vrt ... I hope this helps.... Take of that little door on the front. Have a ...
Oct 29, 2015 | Samsung Washing Machines
My washing machine, which is a LG Intello Washer WM1485FHD is display a code of OE. Could you please advise
That is actually a DE (drain error). Clean out the filter, located behind the access door on the bottom left side on front of the machine. If there was nothing in the filter, replace the pump motor.
Jan 31, 2011 | LG Washing Machines
I have a front load LG washing machine. Its two years old and it stopped working today and it is giving a code of TE on the read out. what does this mean? Any help would be greatly appreciated!
TE is a Thermistor error.
This can be a shorted Thermistor and or a bad heater element. These items are located at the front bottom of the washer's tub.
If you have a washer with steam function. It could also be the steam generator's thermistor and or a bad heater element. The steam generator is located just behind the dispenser’s housing on the top left side.
I can get you part numbers is you need them.
Mar 14, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
What is the AE error code on LG steam direct drive washing machin
Dec 29, 2009 | LG Washing Machines
Where is the drain filter and the spin rinse sensor located on
Have not heard of a part called a "spin rinse sensor". Drain filter is located behind the small access door at the bottom left on front of the machine. Use small hose there to drain remaining water out of pump and hoses, then unscrew the big thing on the right side (end of the filter).
Mar 14, 2009 | LG WM1814CW Front Load Washer
LG Steam Washer
please give me some more details like model number. that will be easy
Apr 10, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
21 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
