Question about Brother MFC 4800 All-In-One Laser Printer
Brother 4800 says sleeping
Printer says sleep but will not print, data cord and power is on
  • 15,935 Answers
CLICK HERE for all the available information about your printer.
CLICK HERE for the manual
NOTE: This printer is Windows ME compatible.
Will work on XP also with correct driver installed.
All Windows versions PRE Vista are programmed in 32bit.
Vista Is programmed in 64Bit Language - therefore many manufacturers simply will not spend the time to re-write software for out-dated products.
As you can see at the bottom on THIS PAGE - only Windows up to XP is supported. Not Vista.
There are no Vista drivers available for PC, so if you are running VISTA - you cannot use this printer on the machine.
The printer probably works fine - however the computer is sending it commands in an unfamiliar language (64bit) so it does not wake up from power save mode.
If the printer IS on a machine with XP or earlier - see page 4-7 of the manual to set the SLEEP mode.
Thanks for using FixYa!! :D
Posted on Jun 19, 2009
HOW TO STOP SLEEP MODE TO LEAVE PRINTER ONLINE
The are designed to sleep automatically but there might be a download on the Brother support site for a "Remote Printer Console" Are you mixing XP and Win7 documents into the que?
Mar 10, 2015 | Brother MFCL2700DW Wireless Networking...
MFC_5840CN Will not print, not showing
Typically, a Brother machine stops printing, because the connection between the computer and the Brother machine is lost. There are multiple reasons for a lost connection.
  1. The Brother print driver is Offline.
  2. The Brother printer driver is not set as the default printer driver.
  3. The computer, not the monitor, connected to the Brother machine is set to go into sleep or standby mode. When the computer goes into sleep or standby mode, the connection between the computer and the Brother machine is lost and needs to be re-established.
Follow the steps below in order to re-establish the connection between the Brother machine and the computer:
  1. Verify that the Brother machine is connected with a USB cable and is not on a network.
  2. Verify the power cord and USB cable are securely connected. If the USB cable is loose on either end, disconnect and reconnect the cable securely. Test the machine by trying to print. If the machine does not print, go to STEP3.
  3. Cycle the power of the Brother machine by unplugging the power cord from power outlet, wait approximately one minute and plug back in. Once the Brother machine displays the date and time after plugging it back in, test the machine by trying to print. If the machine does not print, to Step 4.
  4. Reboot the computer connect to the Brother machine and then try to print again.
Apr 01, 2008 | Office Equipment & Supplies
Deep sleep on printer
I am a Brother employee working for the software technical support department.
We have a solution for your printing issue posted on our solution site.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000032479
Description of Problem 100000025364
How do I perform a firmware update or firmware upgrade on my Brother machine?
Brother Software Technical Support
Jun 29, 2014 | Brother MFC7360N AllInOne Laser Printer
After instructing the Print command in Word, Control Panel etc screened a window that said my Brother MFC-4800 printer was "printing the job" and immediately the job disappeared from the queue - but the...
Try to clear the printer spooler.
Try this instruction: https://www.online-tech-tips.com/computer-tips/how-to-forcefully-clear-all-jobs-from-a-print-queue/
Cheers !
Jan 02, 2018 | Office Equipment & Supplies
HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
How do i remove the sleep mode so i can recieve faxes?
The Brother machines go into sleep mode to save power, in the machine setup you select how long to wait before going to sleep. When all is working, it will wake up as soon as a fax is received, so you really don't need to change it. If you use menu to reports and select the user settings to print, it will tell you where the setting is at.
Nov 02, 2009 | Brother MFC-8460N All-In-One Printer
My printer remains off line. I find no where in control panel or printer file where I can check an option to keep it on line.
Laser printers have a sleep mode they automatically enter to reduce power consumption. Normally they should respond with fairly quickly and awaken to a print job beign sent. ALthough you may not be able to override the sleep mode, you may be able to change how soon it goes into sleep mode in the advanced features. Otherwise, you should contact Brother support and ask the question to them. They will be able to tell you for certain.
Jul 07, 2009 | Brother MFC 8500 All-In-One Laser Printer
Says sleep on display screen it is not printing
It should wake up when a fax comes in or it receives a print job.
Jun 20, 2009 | Brother MFC 4800 All-In-One Laser Printer
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
My brother 3 in 1 printer keeps going into sleep mode how do I reset it?
sleep mode is a normal thing with brother printer, you don't have to worry bout it,it's just the way the printer is saying "hey i'm not doing anything here,might as well get some sleep! once you start to print or scan it'll come back to life.
Sep 16, 2008 | Office Equipment & Supplies
Brother MFC 4800 All-In-One Laser Printer Logo
56 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
