Question about Plumbing
Aquasource vessel sink - Plumbing
2 Suggested Answers
cmartineau
  • 5 Answers
SOURCE: when shower is in use pipes vibrate and water starts to pulse,when faucet on sink is turned on it stops .What's up?Shower is an Aquasource brand.
You need to install water hammer arrestors in your basement it prevents this, if you have them already there water logged. All u do is shut off your water to your house and drain it down to the lowest point....when its done draining u fill it back up again slowly. Your water hammer arrestors may have become water logged when the new shower was installed
Posted on Dec 01, 2012
When shower is in use pipes vibrate and water starts to pulse,when faucet on sink is turned on it stops .What's up?Shower is an Aquasource brand.
Nov 14, 2012 | Plumbing
I installed the sink drain with overflow and water is leaking from behind the sink and under the countertop. What did I do wrong.
a vessel I dont beleive has a overflow. you need a differant waste for that unless theres something your not telling me
Sep 03, 2011 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Just installed a vessel sink and it leaks between the vessel and under sink.
Use silicone to seal the flange and teflon tape on the threads that the drain flange screws onto. make sure that the sink isn't cracked. make sure that you have a washer under the rubber gasket that seals the bottom of the sink and tighten the nut against the washer snuggly.
Mar 23, 2011 | Vessel Home
Installing a vessel sink
Standard Vanity height is approx 34.5". A vessel vanity is approx 31" high. If you cannot remove the legs from your existing vanity then it will have to be replaced or cut down to the correct height. The reason a vessel vanity is lower is because your sink will be approx 3 to 6 inches higher than a standard drop in sink. This may be more work than it is worth. Vessel sinks most often will require a solid surface top, either glass, stone or another type of composite material. The standard laminate vanity top has a particle board substrate which will detiorate quickly at the drain location.
Jul 07, 2010 | Buck 31" Granite Vanity Top for Vessel...
How do you care for a granite vessel sink? What
need to seal every few years---granite is like any other stone its porous and can be stained by dye products and certain oils
Apr 08, 2010 | Stone DeNovo Absolute Black Granite ...
Vessel sink's drain is leaking
a waste with a over flow does not work well with a vessel sink because the sink is to thin
Jun 16, 2009 | RTO W/ Overflow Chrome 1 5/8" Vessel Sink...
Vessel sink drain causes poolin of water.
YOU ALSO HAVE A VENT ISSUE, THE VESSEL SINK DOESN'T HAVE THE LITTLE HOLE IN IT LIKE A VANITY SINK, THERE FOR THE WATER IS GOING DOWN THE DRAIN BUT THE AIR CAN NOT COME OUT, YOU NEED TO INSTALL A STUDOR VENT OR AN INLINE VENT INTO THE DRAIN BETWEEN THE WALL AND THE TRAP CUT IN A TEE AND BRING A PIPE UP TO THE BOTTOM OF THE COUNTER TOP AND INSTALL THE VENT, USALLY HAVE TO PUT A FEMALE ADPT ON THE TOP OF THE PIPE THE VENT COMES WITH THREADS DO NOT GLUE IT IN PLACE, THEY HAVE A RUBBER FLAPPER THAT OPENS WHEN THE WATER IS GOING THRU THE DRAIN AND ALLOWS IT TO PULL IN AIR THEN THE FLAP CLOSES WHEN NO WATER IS RUNNING TO KEEP THE SEWER SMELL OUT
May 28, 2009 | Ultra Max Eden Bath Black Ultra Zen...
No installation instructions for vessel sink
Usually silicone caulking used as an adhesive is used
May 01, 2009 | Home
Poor Draining of Vessel Sink
have the plumber pop an opening on the side of the drain pipe under the sink. and add a indoor vent.
Apr 10, 2009 | Advent KRAUS Amber Rectangular Glass...
Plumbing Logo
66 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
