Question about Cell Phones
My blackberry pearl wont make calls or text. Only have internet service. Tried updating the phones roaming towers but only got beeps.
  • 97 Answers
Hi!... Having problems like these it's much better to ask assistance to your Network Provider..
Posted on Jun 19, 2009
BlackBerry Pearl 8100: My Blackberry curve isn't receiving any SMS messag...
I'd suggest backing up your contacts and other info and then doing a wipe on the phone. To do a wipe to go to...
Options -> Security Options-> General Settings -> click the menu key and you will see the option for wipe.
If that doesn't work I'd do an OS update on the phone.
May 18, 2010 | RIM BlackBerry Pearl 8100
I cant manually activate my blackberry pearl I went to options, mobile network but all it says is roaming.
See if this works....
-Press menu key
-Click OPTIONS
-Select Mobile Network
-Click on "START PROVISIONING"
It should give you a message saying: PROVISIONING COMPLETED SUCCESFULLY.
You wont need a MSL code if you do it this way.
Nov 13, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
When i try to send text messages off my blackberry 8120 the x appears and it says requested facility not subscribed. when i try to make a call it routs me to the tmobile help center. i can access my...
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues, like text issues.
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Nov 03, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
Hi i keep getting sos,with a little red thing on the top right hand corner of my phone, then i cant use it, i have already change my sin card, but it still does this, what is wrong my phone is unlocked, i...
your blackberry device needs to have the network selection set to automatic.........whats happening is when you get out of range of your home network you end up going SOS....this means that there is absolutely no service available and only emergency calls will go through. This is what you must do.
GO to the Connections menu..(thats the one that looks like an antenna tower) select your network settings and change them to automatic to allow your device to roam......and remember, no matter what plan you have with your service provider and no matter who you call or when the call is made you will be using your anytime minutes.......thats how they say no roaming charges....they just deduct a min from your bucket instead of applying an additional dollar amount. You should be good from here on out.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Oct 14, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Blackberry pearl 8130 flashed to cricket wont connect to internet
You can call cricket and ask them to "refresh" your internet, wait 5 minutes and try again. Worked for me.
Aug 26, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
I have a RIM blackberry Pearl that wont turn on.
First try to remove the battery in putting it back in. If that fails you will need to call your service provider for a possible replacement. You may also want to try a different battery if you can.
Apr 21, 2009 | Cell Phones
Samsung u340 won't show roaming or not
you may wont to contact cricket and get verification on your service area........the roaming triangle should only apply to the device main screen when the towers being used have a roaming contract with the provider. you may very well be roaming but not from your device.....you may be roaming in the cellular network though.....contact cricket from another device for troubleshooting options at (866) 274-2538
GOOD LUCK !!!!!!!!
Apr 11, 2009 | Samsung SCH-u340 Cellular Phone
Texts and call logs deletes themselves every couple minutes
This is a known software issue on the Pearl, which can be fixed with a software update. You can download the latest software (currently the 4.5 software) from either www.blackberry.com or www.vzam.net/blackberry
Jan 28, 2009 | Verizon Communications BlackBerry Pearl...
My blackberry pearl wont recieve text meassages from time to time
The rep is correct in trying to remove the battery. Check to see how much free space is left on the phone as well. On older blackberries the messages will if there is not enough room on phone. You can also look into upgrading the operating system on the phone.
Jan 02, 2009 | RIM BlackBerry Pearl 8100
Blackberry pearl keeps beeping
have you tried taking the battery out and putting it back in?
Dec 26, 2008 | AT&T BlackBerry Pearl Smartphone
Cell Phones Logo
46 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
