Question about Whirlpool Dryers
Control locked light is on
How do we turn off the locked control
  • Cynthia Molander Jun 19, 2009
    THANK YOU, IF I COULD ONLY READ THE FRONT OF THE DRYER, THANK YOU VERYMUCH
    Genius:
  • 1,689 Answers
Hi mrseyes,
To unlock the Control Locked feature:
Press and hold the End Of Cycle Signal button
for 3 seconds to turn this feature off.
NOTE: When the dryer is running and Control
Locked light is on, the dryer can be stopped by
pressing the Pause/Cancel button, but cannot
be restarted until the control is unlocked.
same method is explained in the manual below.
http://www.retrevo.com/support/Whirlpool-WED9600T-Dryers-manual/id/14149ci455/t/2/
hope this helps.
regards,
voodoo
Posted on Jun 19, 2009
I can't start my dishwasher. What lights up is control lock. I've never had this problem before.
To turn off control lock - Press and hold control lock for 3 seconds. The control lock light should turn off.
Sep 25, 2015 | KitchenAid Dishwashers
How do I turn off the control lock on a whirlpool duet washer?
To unlock the controls select and hold END OF CYCLE SIGNAL for 3 seconds untill Control Locked status light turns off
Sep 12, 2014 | Whirlpool Washing Machines
Controls locked
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
Aug 06, 2012 | Whirlpool AWM9000 Front Load Washer
I have a Maytag MSD2351 side by side and just replace the water filter. When I attempted to reset the filter light, the control locked and I can not get it to unlock. I pressed the lock and water button...
If the Control Lock feature has been enabled, the Control Lock light will flash 3 times indicating that it is activated. To turn off Control Lock, press and hold the Options key that says "Control Lock Hold 3 Sec" under it for 3 seconds. If the dishwasher has a dedicated Control Lock button in the Options selections, press and hold CONTROL LOCK for 3 seconds.
NOTE: You may need to disable Sleep Mode by pressing either Start/Resume or Cancel, or by opening and closing the door before you are able to turn Control Lock off.
NOTE: If your model requires you to press and hold PROSCRUB UPPER, 4 HOUR DELAY or BOTTLE WASH to lock the controls, the Control Lock light will be on when Control Lock is active.
Nov 03, 2017 | Maytag Refrigerators
The "Control Locked" light is
Mar 31, 2011 | Washing Machines
Child lock is on and I cant get it off
To turn on Lock, press and hold CONTROL LOCK button for 3 seconds.
The Control Lock light will stay on for a short time, indicating that it is activated, and all buttons are disabled.
If you press any button while your dishwasher is locked, the light flashes 3 times and an audible tone will sound.
The dishwasher door can still be opened/closed while the controls are locked.
To turn off Lock, press and hold for 3 seconds. The light turns off.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Mar 18, 2011 | KitchenAid Dishwashers
Fuses panel described in English
Hope this helps your out. I know the diagram and locator is a bit blurry but hopefully it gets what you need.
Drivers kick panel:
Front wiper 20A - Front wiper system Cigar 15A- Cigarette lighter Audio 10A- Audio, remote control mirror Air Bag 10A -Air bag diagnostics Stop lights- 15A -Rear brake light, high mounted stop light ECU B+ 10A - Shift lock actuator, transaxle controle module, radio, engine control module Room 10A - Interior light, clock, ignition key reminder, rear cargo area light switch ABS 10A- Anti lock brake system control unit ECU IG1 10A - Transaxle control module, shift lock actuator, ABS control unit, DRL unit Meter 10A - Instrument panel, back-up switch, electronics time control module, inhibit switch Turn signal 10A- Hazard switch ,front and rear turn lights, turn indicator IGN1 20A - Ignition switch ABS 30A- ABS pump motor TNS 30A- Tail light, license plate light COOL/FAN 30A- Cooling fan Cond/Fan 20A- A/C condenser fan Starter 15A- Start signal , Fuel pump Blower 25A- Blower Motor SR/ACC 10A - Ignition switch Hazard 15A - Hazard and turn signal light D/Lock 25A- Door locks ABS 30A - Anti lock brake system control P/W RH 20A- Power window motor right hand P/W LH 20A- Power window motor left hand IGN2 25A- Ignition Switch
Engine compartment :
Head 25A- headlights IG 2 30A- Ignition switch IG coil 15A -Ignition coil, condenser,generator IC regulator, diagnostic connector. O2 down 10A- Rear O2 sensor O2 up 10A- Front O2 sensor Fuel pump 10A -Fuel pump unit Injector 10A -Fuel injector ,camshaft positioning sensor, purge solenoid valve, EVAP, IAC actuator, Mass Airflow sensor, EGR stepper motor. fuel pump relay coil, vehicle speed sensor. A/Con 10A - A/C compressor controls, cooling fan BTN 30A- Brake light , high mounted stop light. Tail light LH 10A- License plate light, tail light , rear combo light, instrument panel illumination Tail light RH 10A-License plate light, tail light , rear combo light, instrument panel illumination Head low 15A- Headlight Head Hi 15A-Headlight Horn 15A- Horn jlmacman.png jlmacman_0.png
Mar 07, 2011 | 1995 Kia Sephia
Control Lock light is on. Cannot get it off. cannot run washer
To unlock the controls Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Jun 17, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Kenmore elite, im locked out and cant reset, no heat dry is not working to unlock get my wife off my back
I took off the lower panel and found some paperwork that gave option notes. under control lock it says "the Control Lock light is turned on and all keys of the keyboard are disabled wheneverthe control lock feature is involked by the customer. The Control Lock feature (and light) can be turned on or off by the costomer at any time by holding down the Air Dry option (water heat/ no water heat) key for 4 plus aeconds." Now I held it down (pushed) longer until the Lock light turned off, then If it doesn't turn off I did it to the no water heat and light turned off.
Hope this helps.
Mar 10, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dryers Logo
26 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
