Question about Yamaha Remote Control RAV322 p/n:WG646300
Volume buttons don't works
Can't turn up or down the volume, everything else works.
  • 30 Answers
SOURCE: Volume handle doesn't work well
Yes Mr.dinoza,you have a vr (variable resistor)or the volume control itself has a problem,you need a service center or a qualified serviceman to do it. dodoy
Posted on Feb 18, 2007
  • 395 Answers
SOURCE: shuts down at moderate volume
change the impeadence settings of the receiver page 25 of the manual will tell you how.
Posted on Feb 03, 2008
  • 336 Answers
SOURCE: Volume Knob does not adjust volume, but remote does.
Check your owners manual for "factory reset" this will reset the main micro-processor. Otherwise the encoder (volume pot) needs cleaning, soldering or replacement. It could also be a cracked circuit board (if it has recently been hit)
Posted on Jan 29, 2009
smarthome2
  • 1114 Answers
SOURCE: remote does not move volume knob
Unplug the receiver for a minute then plug it back in. This resets the controls. If you still have a problem, post a comment and I will help you troubleshoot further. Hope this helps
Posted on Jun 25, 2009
dunnbiker
  • 8546 Answers
SOURCE: The remote control volume up, volume down and mute
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Posted on Jul 24, 2011
I just bought a used ZTE N9130 cell phone when I charged / powered it up the screen is pattern locked. How do I factory reset this phone ?
To perform a hard reset, or factory reset, then there are a number of methods to try:
1) From the home screen, press Menu - Settings - Privacy - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything
If the phone is totally unresponsive, even after a reboot, then try the following methods.
2) While the phone is turned off, press and hold the Volume Up and Volume Down buttons together. Then, while holding these, press and release the Power button (keep holding the volume buttons). The phone should turn on and a menu will appear. Press the Volume down button to navigate to the Recovery option. Press the Volume Up to select (if that doesn't work, use the Power button to select). A yellow triangle and an Android logo will appear. Press the Volume Down and Volume Up button together and a recovery menu should appear. Use the Volume buttons to move to the Wipe data/Factory reset option and then press Power to select. Again, use the Volume Down key to choose Yes and press the Power button again to select.
3) While the phone is turned off, press and hold the Volume Down button. Then, while holding, press and release the Power button. A menu should appear. Use the Volume down key to go to Clear Storage. Use the Power button to select the option. Then when asked to confirm, press Volume Up for Yes.
4) While the phone is off, press and hold down Volume Up + Home + Power buttons at the same time. Then release the buttons when you see the Logo. Use the Volume Down button to go down and the Home or Power key to select. Choose the Wipe data/Factory reset option. Then Select Yes to delete all user data. Then choose to reboot the phone.
5) A final method is to enter the code into your phone's dialer: *2767*3855# This method will not give you an option to reverse the process, so be careful! This method will only work if you can boot into your phone. - See more at: http://www.phonetipsandtricks.com/tips/zte-warp/how-to-hard-reset-factory-reset-31/#sthash.9JNbyTkc.dpuf
Sep 06, 2015 | CELLULARVILLA Wallet Case For ZTE Speed...
Phone turned off itself and i turned it back on, it now says "try again in 538472 minutes"
Do a Full Reset THIS WILL DELETE EVERYTHING!!!!!!!
  1. Press and hold the Volume down and Power buttons at the same time until you feel a vibration (about 10-15 seconds).
  2. When you feel the vibration, immediately press and hold the Volume down button until you see a large exclamation mark.
  3. Once the exclamation mark appears, press the following four buttons in this order: Volume up , Volume down , Power , Volume down . Your phone should now reset and restart itself. (It might take a while for the reset to finish.)
Try again in 134600 minutes
Settings personalization
Jul 10, 2015 | Nokia Lumia 530 DUAL SIM Dark Gray Factory...
Hi do you know how to hard reset PM-0510-BV
From the home screen, press Menu - Backup and reset - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything
if you can not access this area you can proceed with the following.
This will remove all data from your device and set it back to factory defaults.
Your phone will restart and may take several minutes to come back up.
Nov 21, 2014 | Office Equipment & Supplies
How do i hard rest my phone
  1. From the main home screen, tap menu
  2. Tap Settings, then Privacy
  3. Tap Factory data reset
  4. Tap Reset phone
  5. Enter your password if required, then tap Erase everything to confirm. If those steps don't work perform the following steps:
  6. Turn the power off. If your Kyocera Echo is frozen, pull the battery out and reinsert it
  7. Hold the Volume Down button
  8. Press and hold the Power button until the device turns on
  9. You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
  10. Select Clear Storage by pressing the Volume Down button
  11. Press and release the Power button
  12. Now simply confirm your decision: Volume Up for YES and Volume Down for NO
Dec 24, 2013 | Kyocera Echo Smartphone Sprint
Trying to unlock google password and it want let me get out of it
leave the phone on take the battery out this should reboot the phone
Oct 07, 2011 | HTC EVO 4G Smartphone
Have a BA TVee 25 Soundbar. Only able to program Volume Up on my remote. Cannot program Volume Down or Mute. Nothing happens except to turn the Soundbar off and on. Don't tell me to follow...
I had this same problem and it was due to their instructions which do not adequately explain the setup procedure.
On my own, I was successful in programming volume up but that was all. I assumed that for volume down I would hold the power button and the VOLUME DOWN button and wait for the flashing light just as I had for volume up. Problem is, you never get a flashing light.
Today, I spoke with a rep from Boston Acoustics who patiently explained that step one of the instructions has to be done the same way each time as it is the step that puts the soundbar into programming mode.
It is only at step 2 that things change.
The solution is to hold the power button and the Volume Up button every time in order to get the system into programming mode. Once the light is flashing, in order to program Volume Down, you then hold the Volume Down button until the light goes solid. Once the light goes solid, then press the volume down button on your remote 4 times slowly. Works like a charm.
Works the same way to program the mute button. Follow step one to get the unit in programming mode. Once the light is flashing, hold down only the mute button until the light goes solid. When the light goes solid, press the mute button slowly 4 times.
OBTW, this was programmed with a Logitech Harmony 650 remote unit.
Jul 26, 2011 | Boston Acoustics TVee Model Two TV...
The volume button doesn't work on our leapster explorer. It shows that the volume is at the lowest point, but it will not increase so we can hear it. We tried replacing the batteries and that didn't...
I had same problem, just fixed it by a little hack. The volume up switch is broken.
1. Remove accessory door on bottom. 2. Remove all screws on back. 3. Open back cover.
Looking at the exposed board, there are 2 volume switches (back to back). Directly next the switches are four contacts: the upper 2 are for volume down, the lower 2 are for volume up.
4. Place the battery pack on the board and hold it down. 5. Press the power button to turn on the unit. 6. Use a small wire to jump the volume up contacts multiple times to change the volume to maximum (or desired level). 7. (Optional) Remove the volume buttons and throw away the rubber cushions to prevent the volume from changing. 8. Replace everything back in place.
Mar 17, 2011 | LeapFrog Leapster Explorer Learning...
How do you turn down the volume on the Hott MP3 player?
hold volume button down util the icon turns red then adjust volume with right arrow for up and left for down. when icon goes back to black it should have adjusted to the volume. Also the volume is listed numericly the higher the number the louder it gets.
Jan 12, 2011 | Audio Players & Recorders
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
chris
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Yamaha Remote Control RAV322 p/n:WG646300 Logo
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
