Question about Crosley Cruiser 3-Speed Portable Turntable -
I played a 7" and towards the last 39 seconds of a 1:51 second song. it comes to a complete stop.
MY TURNTABLE START PLAYING ON THE SECOND SONG OF THE 33" VINYL, WHAT IS THE PROBLEM
Do you have a switch to select the size of the record as well? We had a record player that could play 7" singles at 33rpm (floppy vinyls given away by Sunday papers). We had to select 33rpm and also 7" on a separate lever for this to work.
May 23, 2014 | Marantz Audio Players & Recorders
Panasonic SC-AK45 stereo not playing cassette tapes
I may not have worked on one of these before but all tape decks have some common drive parts. Yours is missing the proper torque to drive the reel table in take-up for play and your fast wind observation also points to either drive transfer problems or the motor itself. I suspect the fastest answer is to have a tape deck technician work on it. Dual cassette decks are not known for being the long lasting products like a singles cassette deck is.
Feb 23, 2013 | Audio Players & Recorders
Buffering
Try switching off the router leave it for a couple of minutes and then let it restart usually works on talktalk
Sep 25, 2012 | Toshiba Computers & Internet
How do I get it to play the entire song?
Its because the songs are set to shuffle every 10 seconds. Click on a song (any song will do) hit pause so it stops playing. Click on the gear icon at the top right of the screen. Scroll down the list to "Advanced" then make sure "Replay Interva" is set at 1. If it already is I would contact Visual Land Support witch can be found here: http://www.visual-land.com/support_form.html
Mar 09, 2012 | Visual Land V-Touch Digital Media Player
NOKIA N73 screen shows headset mode on the top right even when not connected to the headset.....so i am not able to hear anything even when i connect the headset it is not responding & i can't hear...
Hi Saik,
I think problem is caused by unplugging the jack before pausing/Stopping the music.
1) Plug in a headset into the jack
2) Open up a media player (either the MP3 player or any online music)
3) Begin to let the music play.
4) Stop the music from playing after a few seconds
5) Completely exit out of the media application.
6) With the headset still plugged in, wait about 15-30 seconds. (this is so that the media/pandora app task can "fully" stop from running)
7) Unplug the headset.
The phone should now be able to emit sound from the earpiece.
If the above does not work, other methods I have read tell you to plug in a headset & play music. While the music is playing, quickly remove & insert the headset into the jack (not too rough so if doesn't break anything) until you hear the music coming out of the speaker.
Finally, if you still have the issue, try rebooting. Turn off the Phone, Remove the battery completely and reinsert after 30 seconds. Turn on the Phone.
Hopefully that should fix the issue.
Jan 01, 2018 | Nokia N73 Music Edition Smartphone
It stops playing certain song after a few seconds
I am glad to HELP YOU!
If your machine, using a multimedia application, it stops suddenly to play a CERTAIN song ["it stops playing certain song after a few seconds"] that means the file [the song, I mean] is broken/damaged/corrupted. So - using other words - cannot be read by the application itself.
All you need to do is to get another file [the same song but from a DIFFERENT SOURCE] hoping the new file will be in good condition.
My best regards!
... and don't forget to RATE, please...
Apr 20, 2011 | Computers & Internet
My ipod plays the song for the first 10 seconds how can i stop th
go in to your settings and check all of them there should be one that says intro or something to that sort if its not in the settings it might be in the play mode but you disable that and it will play the whole song again. Its because intro is a feature on the I pod and other mp3s that lets you listen to the first ten seconds of the song to see if thats the song you want to hear. Hope this helps you out
Jun 09, 2009 | Audio Players & Recorders
My mp3 player is constantly skipping during songs
just replay it over or you probably have the wrong type of mp3 player to fit your song
Apr 02, 2009 | RCA Pearl TH1102 MP3 Player
Ipod nano can not play songs from beginning
It droped once (it wasnt a serious drop) a month ago. After that drop it worked well. Problem occured after last sync a week ago.
Jul 24, 2008 | Apple iPod nano 3rd Generation
Only plays ten seconds of songs
I HAD A VISUAL LAND MP3 PLAYER. ONLY PLAYED FIRST 10 SECONDS OF SONG. IT IS SET TO INTRO. WHILE THE SONG IS PLAYING PUSH THE BUTTONS AND YOU WILL SEE THE OPTIONS COME UP. SONG HAS TO BE PLAYING. CHANGE FROM INTRO.
May 31, 2008 | Centon Electronics MP4-001 MP3 Player
Crosley Cruiser 3-Speed Portable Turntable - Logo
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Sam Palermo
Sam Palermo
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
