Question about GE Washing Machines
How can I remove the agitator on my top load ge washer model number wdrr2500k3ww?
  • 641 Answers
SOURCE: washer will not agitate
A wears out clutch might prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. Good luck!
Posted on Aug 06, 2007
onthejob5130
  • 640 Answers
SOURCE: GE topload washer Agitator
theres no nut and bolt,,only a cam or bell ..you have to roch agitator back and forth,,until it losens,,and pull up reall hard..or put your belt under agitator and yank up..onthejob
Posted on Jan 23, 2009
  • 6 Answers
SOURCE: Agitator is slipping- GE model WJRR4170G top load washer
IF the agitator is like the ones in the older models, it will just pull straight up and off of the transmission shaft.
Inside the agitator there is a rubber splined insert with an aluminum center. The soft aluminum strips out causing the grinding sound. Very common to happen.
We used to use a special puller to remove that part and then press a new one back in.
Voila! Repaired agitator!!
Most any appliance parts store should be able to look up your model # and tell you if that agitator can be resplined.
Posted on Feb 20, 2009
Macintoast
  • 4 Answers
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Posted on Feb 28, 2009
  • 56 Answers
SOURCE: GE washer agitates but won't spin
I think you may have a stopped up pump does it drain the water out if not it will not spin. A putty knife inserted 2 inches in from each side will release the spring catches and gently pull on front as you release sprins then look to the bottom right hand side and there is the pump clamp the tub to pump hose or **** water out with a shop vac take off tub to pump hose and then two 3/8 in screws that hold down the pump turn over where you can look in the pump may have an obstruction as always disconnect power before service.
Posted on May 31, 2009
Gtwn3000mows ge washer need to replace the washer drive block and cant figure out how to remove the agitator from this particular model
On my top-load GE HydroWave washer the agitator just snaps in with a bunch of tooth-like clips in the center of the inside of the agitator. To remove it, grab it on the very bottom of the agitator by hooking your fingers underneath the bottom flange (using two hands evenly spaced) and just lift hard to yank it out. The clips will unsnap and then it just lifts out. Really bad design IMHO but that's how it comes out. I thought I was going to break something doing this but it came right out.
Aug 04, 2013 | GE WBSR3140DW Top Load Washer
NEED TO REMOVE AN AGITATOR FROM A WASHING MACHINE
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    Ge top load washer won't agitate or spin after
    what is your model number is then we can started then okay
    Sep 15, 2011 | GE Washing Machines
    I received information about how to fix my agitator not working on my GE washer. But now I need info on how to get to the agitator. My model WWA8955 is different from any other GE top loading washers...
    Oops sorry about that my fault for not searching parts on your model befroe answering. What i wrote about is what ge has made for the past 10 years or so your washer is very old!
    to remove that agitator which doesnt use that part i talked about (sorry) so what you do it remove the bolt from top of inner agaitator and pull that agaitaor off. ITs been on thier for 15 or more years and will take some tugging perhaps and if lucky will come out right away after bolt removed. on the inside of the top of that inner agitator will be a coupler that works similar to the one if the vid. i showed you. that coupler needs to be knocked out and replace the spline coupler. Need to check though if center shaft of transmission is stripped before ordering and replacing that spline if the transmission is ground down the transmission would need to be replaced however since its so old the part is no longer available..
    The part number for that spilne is WH1X2641
    once again i apoligize for thinks it was less that 15 years old
    Aug 15, 2011 | GE WBSR3140DW Top Load Washer
    Coin stuck in agitator. how is agitator removed
    Normally you can take the top of the agitator off with the use of a screw driver or by turning couter clockwise. Once the top is off you should see a nut or bolt. Removing this will allow the agitator to be removed.
    Nov 12, 2010 | GE Profile WPRE6100G Top Load Washer
    How to remove agitator from GE washer? Model WHDRR418G1WW.
    how to remove agitator from GE hydrowave washer machine?
    Feb 27, 2010 | GE WBSR3140DW Top Load Washer
    GE top loader not agitating
    Your agitator splines are probably stripped out.
    Remove the agitator and check the spline grooves.And the agitator coupling on the shaft.
    Mar 04, 2009 | GE WBSR3140DW Top Load Washer
    Jan 23, 2009 | GE WBSR3140DW Top Load Washer
    GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
    The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
    Dec 03, 2008 | GE WBSR3140DW Top Load Washer
    GE washer WWSR3090T6WW
    I DONT KNOW HOW TO REMOVE MY AGITATOR PARTS TO PUT IN THE NYLON COUPLING I GOT THE TOP PART OFF BUT THATS THE ONLY PART COMES OFF
    Oct 22, 2007 | GE WDSR2080D Top Load Washer
    Washing Machines Logo
    20 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
