Question about Zojirushi Kitchen Appliances - Others
Zojirush code h01 - Zojirushi Kitchen Appliances - Others
The error code H 01 in Shows my washing machine(panasonic na-f70gs)
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3328-panasonic-na-series-washing-machine-fault-codes.html
H01
Pressure sensor or level switch detected as out of range
  • Check wiring to level sensor
  • Check pressure switch is not defective
  • Replace pressure sensor
  • Replace main power PCB
Apr 06, 2015 | Washing Machines
Hoover washer dryer error code h01
Its not an error it means its in delay start mode. Hold down the delay start button (looks like a clock) for 5 seconds and it should clear
Sep 12, 2012 | Hoover Washing Machines
Part of the lip of the lid broke off and I need a replacement lid. how can I get one?
My best recommendation would be that you contact Zojirush:
Click here please:
http://zojirushi.com/support/customer_service.html
Rating our advice will let us know if we're doing you any good. Please take a moment to login and rate this page. Thank you. And for a ton of free U.S. and Canadian breadmaker recipes visit http://www.bread-maker.net/sitemap.htm
Jun 26, 2011 | Zojirushi BBCC-X20 Home Bakery Supreme...
Riso RZ390UI a code of H010 comes up. What is the probelsm
Error H01 means: Cannot get consumables info. Input values required.
1: black / 2: color
Mar 18, 2011 | Riso RZ390 Duplicator
Display has error code h01 and dishwasher won't run model is SMS63M08AU
h:01 means 1 hour delay. Press the delay button repeatedly to get to h:00 then hit start.
Mar 06, 2011 | Bosch Dishwashers
Yamaha dvd s-80 showing error code H01 when trying to play disc. What does this mean ?
The manual isn't much help, is it?
http://www.retrevo.com/support/Yamaha-DVD-S80-DVD-Players-manual/id/320ag210/t/2/
It seems the "H01" is some kind of common and fatal error code in many disc players and I have yet to find anyone who has paid the ransom, er cost, to get one fixed as it is cheaper and makes more economical sense to just buy a new unit...
http://www.electronicspoint.com/panasonic-sc-ht75-dvd-player-broken-t55762.html
Feb 11, 2011 | Yamaha DVX-S80 System
Panasonic VCR model number NV-HD640B comes up with fault code H01 - what is this and how do I fix it?
You have a Panasonic K Deck Mechanism, you can search for more free info on it via Google. Meanwhile H01 means no drum motor or drive, it's to do with the main VCR head not going around.
Dec 04, 2010 | Panasonic NV-HD680 VCR
H01 Error
H01 means that there is an alignment problem or there's a faulty lens mechanism. Align it would cost about $50 . If there is a faulty part , then cost would start from about $80 labour plus part.
Aug 08, 2009 | Panasonic DVD-RV32 DVD Player
Fault code H01 appears in the display
You appear to have a pansonic K Mech model.
H01 is the code for no drum motor or drive.
Jan 04, 2009 | Televison & Video
Error code H01
it means no head motor rotation...The full meaning is given as: After Cylinder lock is detected the cylinder does not start rotating again even after tape unloading.
The remedy/ check is given as: Check the cylinder motor drive circuit... sorry no solution but at least you know whats wrong..
Aug 07, 2008 | Panasonic NV-HD680 VCR
Kitchen Appliances - Others Logo
49 people viewed this question
Top Zojirushi Kitchen Appliances - Others Experts
30yrmech
Level 1 Expert
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Zojirushi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
