Reason my sony cardiscman doesn't illuminate while plugged into wall outlet
Tip
How to troubleshoot 50.4 error message on printer?
The reason is as follows:-- A 50.4 error message on some of the newer HP Laser jet printer indicates a problem with the power supply.------------- If the printer is connected to a UPS, disconnect it, or disconnect it from a power strip and plug it directly into a wall outlet. A laser printer should never be plugged into a UPS, because the UPS can be damaged by the surges of power required by a printer to keep the fuser assembly warm. If that doesn’t work, make sure that all of the components in the printer are seated properly.this will help. thanks.good luck.
on Mar 05, 2010 | Office Equipment & Supplies
Wall plug for TV buzzes
Have the outlet checked by a qualified electrician. Sounds like either a power issue or ground. You should not get a buzz from an outlet for any reason.
If you plug something else into the outlet does it make the same noise?
If yes, something going on with the power. If not, then the TV power supply might be doing it, but the noise would be behind the TV and not the outlet.
Aug 17, 2014 | Sony Bravia 32-55 Inch...
Sony Home Theater System Dav Hdz273 Green-plug speaker plugged into green outlet doesn't work. However, if green plug is plugged into one of the other color outlets, speaker works. If plug anot
Green outlet is the center channel which is not used in all surround modes. Make sure that you have a dvd in the unit, and make sure there is a prologic surround mode selected.
Jan 28, 2013 | Sony HOME THEATER SYSTEM System
My dell studio1555 laptop is not recognising my mains lead/charger
Plug the adapter into the wall outlet or power strip. If using a power strip, make sure the strip is on. Most laptop power adapters have a small LED light; the light will illuminate when power is being transferred from the outlet to the adapter. If the light illuminates, chances are you have sufficient power to supply your laptop. Wiggle the power cord if the LED light did not initially illuminate. If the light turns on and off when you wiggle it, you might have a loose cord in the adapter, or the outlet could be faulty. Plug the adapter into another power outlet, preferably a different circuit in another room, if the LED light did not illuminate the first time. If it lights up from the second outlet, the first outlet either does not work or other devices were using too much power on the initial circuit. Connect the other end of the adapter to the laptop and turn the laptop on. When the computer starts up, you should see an indication of how the laptop is being powered in the lower right-hand corner. If you see a battery icon, then the laptop is being powered by the battery, not the adapter. Make sure both ends of the adapter are securely connected. If they are, and if the LED light on the adapter is lit, then you likely have a faulty wire that is not properly connecting to your computer. If you see a plug or adapter icon, then the laptop is successfully being powered by the adapter. If the LED light on the adapter is not lit, then the bulb is out, but the adapter is still working.
Jan 20, 2013 | Dell Computers & Internet
My toshiba is charging but onlythe cord out lets bliking what does that mean
Jan 20, 2013 | Toshiba Satellite Pro L300 Notebook
Inspiron 2305 power cord doesn't turn the desktop on
After connecting the AC adapter to a wall outlet and to the computer press the power button the right side of the inspiron. The button itself should then lite up white if the power adapter is good. If not, check the power outlet you are using. Plug in something else and see if it works on this wall outlet. Some outlets are connected to a wall switch. If its still a nogo you may need to replace the AC adapter.
Sep 18, 2011 | Dell Inspiron One 2305 Desktop Computer...
THE T V WILL NOT POWER ON
plug the cord into the outlet. If the wall outlet doesn't work find a different one. If the tv doesn't turn on with the remote take the plastic off of the batteries in the remote. if this all doesn't work, then there's something wrong with the tv and you should return it and get a new one.
May 16, 2011 | Tatung LD30HL Television
Please i need manual for norcent lt-3751 lcd 37" tv because this tv dont power on
Make sure the power cable is plugged into the T.V. and the wall outlet. If it still doesn't power on try a different outlet. If that still doesn't work then there might be a problem on the board that needs repaired.
May 05, 2011 | Norcent Technologies LT-3751 37 in. LCD...
Tv shuts off and on by itself dlp 5064 tv only seems to do it when the tv is on for a long period also when the power is on the standby/lamp is illuminated
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. I
Jul 26, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
70 people viewed this question
 Grubhead
Grubhead
