User Guide KORI Swamp Water Cooler with Ionizer Model : KOC - 601
  • 340 Answers
SOURCE: swamp cooler is not blowing cold air. Water is
is the pump youll have to take off a panel make sure the pump has water. what is the relative humidity if it is high swampers don't work very well .Tom
Posted on Jun 26, 2009
  • 340 Answers
SOURCE: Breezair swamp cooler parts
applianceparts.com try the manufacture web site johnstonsupply.com should have a pump you can make work. Tom
Posted on Jun 28, 2009
  • 396 Answers
SOURCE: Do not know how to work/maintain swamp cooler
Evaporative coolers are only for dry climate conditions or deserts. They cannot cool as much as central air or air conditioners which have compressors and refrigerant. The mechanics are simple requiring a water float valve, pump, spider (water distribution), aspen wood pads, blower, belt, motor, and switch. The unit must have a water supply to replenish the system due to evaporation. Your system may have a float valve which you need to adjust to shut off when the water pan is full. Floats can be adjusted by loosening the pivot screw and moving the float up and down to adjust the turn off level or by turning the float to extend or retract the length changing the water shutoff position. You do not want the water to be so high it flows out the over flow tube but the water should cover pump base. Plug in the unit and turn the switch to pump if you have that option on your unit. This will engage the pump to force water from the pan up to the spider to saturate the pads with water. After a few minutes turn the switch from pump to low or high cool. New aspen pads will have an distinct smell which will go away after a few days of usage. If you do not have a pump setting turn the switch to low or high cool which will blow warm air at first then start to cool down. You may also have a fan setting which will blow outside air without any additional cooling if the outside air is humid. Occasional maintenance is to make sure the pump is pumping water and the filter basket is clean and all the spiders are working with water flowing freely. You can use a flexible wire to force it in a spider tube to clean it if it is clogged. You may want to change the water after a month to keep the system cleaner from slime and calcium. At the end of the season disconnect the water supply and drain the water pan blowing out the water line if the winter is below freezing. Replace the pads if they have calcium build up or dry. Flush the water pan out and clean the Add some oil to the pillow blocks which are the bearings at each end for the blower. Check the belt and pulley for excessive wear. Cover the unit with canvas to prevent cold air from coming in during the winter. Next summer season all you have to do is uncover the unit and hook up the water supply.
Posted on Jul 27, 2010
  • 10865 Answers
SOURCE: I have a Westwind Convair
hi.
here is the company contact info. http://www.cylex-usa.com/company/convair-cooler-corporation-5048927.html
call them to order.
Posted on Sep 02, 2010
shastalaker7
  • 1515 Answers
SOURCE: I need a belt for
Hi John, your best bet for this, is to get the name and or number off of the belt, or take it off and go to any auto parts store and match it up. That's what we do in the field. If you try and order one, you will run in circles. Also, any appliance parts house will have one.
Shastalaker7
A/C Contractor
Posted on Jun 06, 2011
How to descale an water cooler pad?
Hello, Here is website for the recommendations for cleaning water cooler pad. How do you clean swamp cooler pad Ask com
Nov 06, 2014 | Windex Multi Task with Vinegar, 32 oz....
Need parts, pump for a ED630J adobe swamp cooler in las vegas, nevada
A swamp cooler PUMP is not really model specific. They are basically small submersible pumps. Contact ANY swamp cooler dealer in LV, tell them you have a 4500 CFM unit and need a pump.
The pump part number for this size cooler is: PN 110436 (there are several alternates)
Contact these folks and tell them what you need:
National Cooler ' Swamp Cooler
3046 Vegas Dr.Suite 1
Las Vegas, NV 89106
(702) 638-8800
If they can not help you... just look under cooling and air-conditioning in the yellow pages and find a dealer near you. This pump is common to nearly every brand in LV. You can most likely buy one at the local home depot, menards, or lowes.
There is also a Little Giant CK-5 "UTILITY"pump that is used for swamp coolers.
Thanks for choosing FixYa,
Kelly
Jun 15, 2011 | AdobeAir Mobile Swamp Evaporative Air...
How do you calculate the cfm in a swamp cooler
You will need to figure the cubic feet of space you want to cool, and then divide that number by two. The quotient will give you the CFM rating for the proper-sized swamp cooler.
Jun 14, 2011 | Heating & Cooling
How do I unclog the copper line?
The copper line and the pump. Which is the concern?
On the circuit breaker, Turn it off and in five minutes, back on.. Then check the outlet at the cooler to see if it's getting power.The copper water supply line? You do have water to the float control valve? or no?
Jul 10, 2009 | Heating & Cooling
Evaporated cooler is not filling up with water
yes ur water pump is not working properly..
ur will have to check it
Jun 29, 2009 | AdobeAir Mobile Swamp Evaporative Air...
Contact Convair cooler corporation.
Phone # 1- (602) 353-8066
Will send your parts out the same day.
Jun 28, 2009 | Heating & Cooling
Swamp cooler is not blowing cold air. Water is
Jun 25, 2009 | Heating & Cooling
Water is not going into swamp cooler
CK THE FLOAT THAT OPENS AND CLOSES THE water valve.. press down on float to see if water is available,if water flows float needs adjusting. If no water then check to seeit hasn't been turned off for the winter -good luck
May 11, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating & Cooling Logo
100 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
