Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpooldryer GEW92000LW1 heats for first load then quits heating
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
Open ground at outlet , heating element wont heat
The 3 or 4 should work. Did you move the unit to a different location? What caused it to quit heating?
Oct 15, 2012 | Frigidaire FLEB8200DS Top Load Stacked...
My dryer quit heating up...it still works and spins but won't heat up. any help would be much appreciated!
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101,./'l';
Mar 19, 2011 | Asko WCAM1812 Front Load Washer / Dryer
Replaced heating element for dryer.Dryer started heating for one load. Then quit heating,found wire disconnected-reattatched wire and dryer was working.Now one small load later , dryer quit drying-no hot...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Dryer won't heat
heatman101
Jun 28, 2010 | Kenmore 62602 Electric Dryer
Dryer quit heating runs fine it is a gas dryer
Is the pilot light or "stricker" working when you start the unit.. Is it getting good supply of gas?
Mar 12, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Heat is sporadic. model DDE5900RALWH erial G246248G
Make sure lint filter is clean also frre airflow from Exhaust, if tisis ok could be thermostat or element, try basic stuff 1st...
Feb 22, 2010 | Dryers
Dryer turns but doesn't heat. How do I troubleshoot?
Likely causes are:
- broken heating element
- burned/corroded connections in heating circuit
- blown thermal fuse / limit switch
- bad thermostat
If you don't have significant of experience with electrical appliance troubleshooting & reapir, this is a difficult task.
May 08, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Dryer wont stay hot. it gets cold after first load
If dryer lights for a few minutes and will not stay lit, I believe the solenoid coils will need to be replaced. Click on link below, enter your model number lgr5620kq1 in model search feature and go to the dryer page it shows a breakdown view of your dryer. Also go to common solutions and look for gas dryer problems. I will also be here to help you, Sea Breeze
http://servicepartstec.blogspot.com/
Mar 21, 2009 | Whirlpool Dryers
Whirlpool Duet GHW9150P Front Load Washer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal De
