PXEE61:media test failure, check cable PXEM0F:exiting PXE ROM operating system not found
  • 237 Answers
You didn't ask a question. I assume this is an error on boot-up? If so, then the system is reporting that no pxe server was found to boot your system over the network. To correct this you should enter the BIOS setup upon power-up (via hitting the delete, f1, f2 or f10 key - depending upon your computer) and disable the boot from network setting. Save configuration and restart. You should probably set BIOS boot order to 1st device = cdrom, 2nd device = harddrive.
Posted on Jun 19, 2009
My laptop has been freezing so easily, it cannot show anything on the screen. the notice says pxee61 media test failure. How do I solve this problem?
Posted on Oct 11, 2009
What is this error PXEE61 that appears at startup?
the cable to the hard drive is bad or the motherboard is bad,
Jul 10, 2015 | Acer TravelMate 2480 Notebook
PXE-E61: Media test failure, check cable PXE-M0F: Exiting Broadcom PXE ROM Operating System not found Acer Travelmate 5720G
This error is a result of your computer not finding the operating system. This is usually the case when the hard drive has failed. You will need to take the computer to a technician to replace the hard drive and have windows reinstalled.
Mar 06, 2011 | Computers & Internet
At startup : PXE-E16 : Media test failure, check cable PXE-M0F : Exiting PXE ROM Operating System not found
This is due to your Hard Drive is not detected by the BIOS to boot. Make sure the boot order in system BIOS is correct and Hard drive is properly connected to motherboard.
Feb 14, 2011 | Computers & Internet
Went to shut down comp. and screen said, and still is. broadcom undi pxe-2.1 v11.4.1 copyright [c] 2000-2008 broadcom corporation copyright [c] 1997-2000 intel corporation all rights reserved. ...
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Dec 05, 2010 | Acer Aspire 5610-2328 Notebook
PXE-E61: media test failure, check cable PXE-MOF: exiting broadcom PXE ROM Operating system not found
The motherboard has died - there is nothing that can be done to save it. Time for a new one.
Oct 10, 2010 | Computers & Internet
Aspire 3682 PXE-E61:Media test failure.check
PXE error means that it is trying to boot from an ethernet / lan connection.
check your boot order options first and set it to boot
1. Hard drive
2. CD rom drive
3. Floppy (or usb if you know how to do this)
4. network(aka PXE)
If it still fails then yes there MAY be an issue with your hard drive.
Check all hard drive connections before running off for a new one.
This can be especially true with SATA type drives most of which dont have any sort of true locking device to hold the connections secure.
Sep 28, 2009 | Acer Computers & Internet
I have an emachines e620 and when i switch my computer on it says pxe-e61 media test failure, check cable and it also says pxe-mof exiting pxe rom operating system not found help would be great
Go into set-up and change the boot order to the hard drive you have your operating system on... then cd-rom. you may actually want to start with your cd-rom as it makes it easier when you are installing an operating system.
robert
Sep 04, 2009 | eMachines E620-5885 Notebook
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
Computers & Internet Logo
1,886 people viewed this question
Alun Cox
David Payne
David Payne
