Question about LG Flatron L2320A 23" LCD Monitor
I could use some help with my monitor. I noticed today that pictures seem to have .... I don't know how to describe it... it's like someone took a bright yellow pen and drew fine lines in the picture. The cords seems fine. I've checked to make sure that they are firmly attached to the monitor and to the computer. Also, this monitor is only about 9 months old.
  • 22 Answers
Have you try the monitor on another PC to see the problem is on monitor itself or the display card of your PC?
Posted on Jun 19, 2009
Reset the monitor setting to factory settings. and if problem remains then use http://tinyurl.com/mlkl2k
To get free diagnosis.
LG900G - got it yesterday. Everything seem to work up until today. Think at first Handheld memory was full when i tried to snap a pic. I deleted all the pictures i took earlier and now when i try to take a...
I'm having the same problem. It will still allow me to take video though. I don't know what's going on. I've cleared out my memory, and checked it under settings. Almost all of my memory is clear. I don't know why it's doing that. :(
Aug 09, 2011 | Cell Phones
What will show on the screen if you connect lcd acer x193w only electricity? (Without the PC you plug inserted in lcd acer x193w.) I show my "Acer" and turns off, then starts again and goes off...
Normally when you don't plug a monitor into your computer but just into the wall socket then you should get a No Signal message displayed. If the monitor is behaving erratically then it's not a good sign. Try plugging the monitor into your PC as well and see if it still keeps switching on and off.
Apr 17, 2011 | Acer X193W LCD Monitor
32" LCD HDTV Sceptre model x32, blue led but no pic or sound !
Having the same problem. Took it to a repair shop and they say it is some capacitors and the power supply... Which seems kinda hinky to me... I would think one or the other would be the problem, not both at the same time.
Apr 06, 2010 | Sceptre X32GV-Komodo 32 in. LCD Television
Shutter release button (not hearing that "click")
Same happened to me, i tooke it to this nice place to repair and they charge me 10 usd. But it has to be someone that WANT'S to repair it, because i tokk it to other places, they took a look at it and say there are no spare parts and didn't want to doit.
May 31, 2009 | Lomo Holga 120 CFN Medium Format Camera
Vison flat 19" hooked to toshiba laptop w/Vista no signal
Can't say I really "fixed" the problem. I tried other monitors, DVI cord and took the laptop to a repair shop. Nothing worked. And then....boom.....it worked! No one knows why or how. No one did anything to the computer or monitor. It just works. Who knows how long it will work, but it works today.
Jan 19, 2009 | TDV Vison TDV FV19B 19" Flat Panel LCD...
Picture and video is not clear
Hi Scandle201
Yot have done every thing right on your side. You will unfortunetly have to take the monitor back to the repair shop. Ask them to test it at your resolution settings of your home desktop and play some video's and open some pictures on there test system.
Regards
Go-Tech
Dec 15, 2008 | Microtek 211SD 21" LCD Monitor
Dell monitor keeps turning off...
The problem you are experiencing is quite common, however the solution can be expensive and frustrating if you are not sure what you are doing. The problem is due to usually 1 of 2 things but the result is the same. The result is that the H.O.T. (Horizontal Output Transistor) is blown or severely damaged and needs to be replaced along with the item that caused it to go bad to begin with. Note: sometimes just the H.O.T. transistor can be replaced and it will work ok (this is rare and due to just being over-used).
The problems that caused the original issue is either the H.O.T. Transformer (a black device with heavy red wire insulation going between the mainboard and the picture tube with a wide boot on it). The other main culprit is the picture tube itself that will internally arc between the pins on the end of it.
These devices develops internal shorts that wipe out the H.O.T. transistor which is mounted to a heat sink.
None of your pictures show this board (it appears to be the same 2 boards in different poses). In your case it sounds like the picture tube is at fault and not worth repairing.
One other possibility is just poor soldering on the main board but this is extremely rare fault.
Hope this helps!
Rich Lilja
Nov 26, 2008 | Computers & Internet
Monitor not getting power
could you describe how you got it apart? i've got the same problem, and i feel like i'm going to crack it just to get it open...i've mostly tried pulling the back off from the bottom after removing the 2 screws
thanks
Nov 28, 2007 | Computers & Internet
Pink lines/dots in pictures
Pointing a digital camera directly at the sun can damage its sensor. You should have the camera checked by a qualified repair facility
Aug 30, 2005 | Kodak EasyShare DX4330 Digital Camera
LG Flatron L2320A 23" LCD Monitor Logo
138 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
