Question about American Standard 2770.018W.021 Cadet 5' x 32" Whirlpool, Bone
The water drains even with the stopper down - American Standard 2770.018W.021 Cadet 5' x 32" Whirlpool, Bone
    Problem Solver:
  • 107 Answers
Get a new stopper, seriously
Posted on Sep 17, 2014
How do i fix the drain stopper
Plug it .. they make a underwater jb- weld .. works wonders
Oct 30, 2014 | Home
Tip
Backed Up Kitchen Double Sink Fix with Garbage Disposal- Quick and Simple Fix
Here's how to fix a backed-up double sink (running water down one side/sink causing dirty water to well up out of the drain on the other side, with slow or no emptying). Note that this quick-and-easy tip only works if you have a functioning garbage disposal.
What you will need: a stopper, and possibly a clean toilet plunger (the cup-shaped kind that stands on its own, not the kind that is bulb-shaped)
Stopper up the side in which the water is rising up out of the drain. Make sure you hold down the stopper as well; if you don't, the stopper will shoot up on a geyser of dirty water when you perform the next step. Once you have the stopper in place and are holding it down, run water on the other side/sink and turn on the garbage disposal. Once you have done that for a reasonable amount of time, shut off the garbage disposal and water, and unstopper* the other side. Run water on both sides to make sure everything is draining properly. Doing this should save you the hassle of taking the pipes apart or plunging one side repeatedly to clear the clog.
*Note: If the stopper is stuck, place the plunger so it completely covers the opening the stopper is stuck in and give it two good plunges. The plunger should create a vacuum that will suck out the stopper, and is more effective than you trying to pry or pull on it. Do this ONLY after you have shut off the garbage disposal and water.
What is happening is that there is a clog in your pipes. When water goes down one side, it hits the clog somewhere in the pipes, has nowhere to go, and gets pushed back up the pipe leading to the other side of the double sink. By stopping up the side without the garbage disposal, you are creating a barrier preventing the water from coming back up. At the same time, the garbage disposal running on the other side is forcing the water down. Since the water now cannot escape up the stoppered side, it has nowhere to go but down, forcing the clog out with it.
on Jun 28, 2014 | Home
Grohe drain stopper installation
Try cleaning drain with a length of wire. Strip insulation back about an inch. Turn exposed wire back to form a hook and put down drain and spin, then remove from drain, repeat until hook comes out fairly
clean. Then put drain cleaner down drain, follow instructions with drain cleaner. This should remove gunk that is preventing stopper from working correctly.
Jan 20, 2014 | Plumbing
Hansgrohe 88509000 sink drain does not close completely, water slowly drains out
This could be caused by the installation. If the installer did not use plumber's putty between the the flange and basin it will not seal with the basin. Another possible cause is if the basin is not perfectly formed it will cause the flange to oval or not seat evenly. If this is the case it may leak between the flange and the basin or the stopper may not seat all the way down and it may leak between the stopper and flange.
Oct 16, 2012 | Hansgrohe 31060821 Metris S Single-Hole...
Pulled the drain stopper rod out and cant put it back in. how do i do it?
if you remove the actual drain mechanism you will see where the drain stopper rod goes into.It`s a hole that works on a lever. You need both hands to insert rod into and then use the other hand to find the right height position to anchor the drain stopper. You insert it from behind and then tighten the drain stopper on the drain pipe. Take your time this sounds complicated but it is quite easy. When you have it lined up you can check the operation of the rod by going up and down.And see if it holds water and then see if it drains the water..
Feb 19, 2011 | American Standard 0456.017.222 Heritage...
I stopper on a garden tub with a delta faucet. The stopper pushes down and locks to stop water. It takes a few tries pushing it down to get it to stop and hold water. What is the best way to fix it or...
In my part of the country, the type of drain you refer to is commonly called a tip-toe drain because you can use your toes to open and close the drain. Their locking ability diminishes over time and use, and eventually won't lock at all. They cannot be repaired, and must be replaced. You must remove the one you have to get the correct replacement because there are variations in the thread diameter at the bottom of the stopper.
You will need to use pliers large enough to grab around the white plastic underneath the top of the stopper that appears to disappear into the drain. Once you have the white plastic shaft secured with pliers, grab the very top (the chrome part) and twist it counterclockwise to remove it. Once that is off you will see a round piece of brass that looks like the top of a very large screw. IT IS! Using a stantard screw driver, again turn counterclockwise to finish removing the rest of the stopper.
A good hardware store should have a replacement for you. Be sure to match up the thread diameter at the bottom of the stopper.
To reinstall, you can reverse the steps or simply thread the complete assembly into place.
Aug 07, 2010 | Home
Direct push-type Kohler bath drain won't drain.
Spring loaded chrome stopper will not stay down to fill tub with water.
Jan 12, 2010 | Kohler Plumbing
Kohler bathtub drain seems to be disconnected from control lever. This is the type with the "in bathtub stopper" that raises up and down to let water flow out. The stopper does not move up and down as it...
Okay, remove 2 phillips head screws at lever handle/overflow.
Pull firmly with much effort and bowing the connecting rod a bit.
Up will come a heavy duty spring on the end of the rod.(prolly a big slimly hair ball too!)
Hope you get the spring, cause that's what works the drain stop.
If spring doesn't come out you'll have to "fish" it out.
Clean everything up real good and flush drain good also now.
The "Secret" now is to put the Lever,rod and spring assembly back in and replace screws and get the lever flipped to the left BEFORE you put the Drain Stop in.
Dec 30, 2009 | Kohler Plumbing
Our bathroom pedestal sink is very slow drain and clogging -2 questiions: do you have to disassemble and take off sink mounts and remove from wall to get to elbow joint? I do not know how to disengage...
You shouldn't have to disassemble everything in order to get to the trap (elbow joint). Most pedestal sinks are designed so that you can get to the trap from the back (generally after getting down on your hands and knees and crawling around with a flashlight). Most sink stoppers that are worked from the faucet itself have a little bar that extends down the back of the sink behind the drain. It will clip with a little metal piece to a lever that sticks out the back of the drain before the trap. The lever goes through a hole in the drain and pokes into a hole in the bottom of your sink stopper. As you move the lever, you will notice that your stopper goes up and down.
Unclip the rod from the lever and you should be able to unscrew the lever from the back of the drain (don't loose the little gasket that sits inside the screw-cap as it keeps water from leaking out here). At this point, you can pull out the stopper and see what is going on. If cleaning off the stuff attached to your stopper doesn't solve the problem, you can then remove the trap to see if anything is clogging that. Hopefully, by this point, your sink clog has been identified and you just need to reassemble, making sure when you put your stopper lever back in that you actually get it into the appropriate hole in the stopper itself.
If this doesn't solve your problem, it's more serious and you probably want to call a plumber as the issue is either a clog farther along or a problem with the venting of the sink drain.
Aug 30, 2009 | Home
Slow water drain from Royal whirlpool tub. How to
under the decorative knob there is a screw,this is what holds the stopper in place.if not it should just unscrew.
Jul 29, 2009 | Home
American Standard 2770.018W.021 Cadet 5' x 32" Whirlpool, Bone Logo
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
