Question about Stanley Bostitch Coil Framing Nailer
Bostich coil nail guide shattered - Stanley Bostitch Coil Framing Nailer
5 Suggested Answers
  • 384 Answers
SOURCE: the driver is not going back up after shooting
The gun needs to be rebuilt. The seals, diaphragms, and valves need replacement. Do a search on the internet for Stanley Nail Gun rebuilding kits. Simple job to do. I did mind last year for under 15 dollars I think. Make sure you replace all the parts including the "O"-rings.
Posted on Jul 23, 2009
comax
  • 154 Answers
SOURCE: Firing Pin doesn't return
The piston is returned to its firing position by air from the trigger valve after the piston has fired. It relys on the piston sealing against the bumper at the bottom of its stroke, if the bumper was damaged when the driver shattered or it was put in upside down the piston will not return. Also the piston uses air fed into the return chamber from the little holes in the cylinder, if the seal over these holes is damaged the piston may not return. Basically change the bumper and the check seal on the cylinder.
Posted on Aug 05, 2009
  • 1383 Answers
SOURCE: my brand new bostich roofing gun froze up after
Water in gun or wrong oil for cold temp will cause gun to freeze. Make sure that the compressor is not making water form in hoses due to hot air entering cold hose then freezing in gun. Remove cap of nailer and check for water and lube with light oil that remains liquid in your temp range. If the oil is too thick, the firing valve under trigger and headvalve will not budge. Use very short hose so warm air in tank can reach the nailer (heat is produced when air is compressed, however long hose will allow air to cool before entering gun). Stay warm and good holidays
Posted on Dec 10, 2010
H2_Brad
  • 425 Answers
SOURCE: Bostich coil framing nailer will not advance the
Bad or dry feed piston o-ring or a loose feed piston as they are held on by a metric allen screw that will sometimes back out. Use blue Locktite when reinstalling the screw. It could also be the feed spring but they rarely fail on the larger framing nailer.
Posted on May 18, 2012
Bostich RN-46 seems to be over sinking the nails even went set to low depth
Adjust the air pressure on the regulator to about 90 lbs. or lower. maybe higher than 90 but that should help you set the depth.
Jun 05, 2014 | Stanley Factory Reconditioned Bostitch...
Nailer drives nails too deep
n80 coil nailer is a very powerful nailer used for hard wood. If the driver is setting nails too deep, adjust safety foot to the lowest level. Install safety foot no-mar boot to lift the gun even higher. If still too deep, most likely the lower bumper inside the gun is worn-out or cracked. Easy test. Remove nails and connect air supply. With trigger depressed, push and hold the gun against work (I use an old rubber hose tightly coiled up). This will fire the gun but keep the driver down allowing you to examine the tip of the driver. The driver should extend out past the nose less than quarter inch. If the driver is extending too far, most likely bumper is worn out. If a large quantity of air is leaking out the nose of gun during the test, indication that lower bumper is cracked. Good luck.
Apr 06, 2013 | Stanley Bostitch N80CB Coil Framing Nailer
I have a nail jammed in my Bostich coil roofing nailer
make sure nailer is unloaded loosen front slide remove nail and make sure plunger is all the way reset to top and reassemble
Mar 09, 2013 | Air Tools & Compressors
I have a 16 guage Bostich nail gun that has worked perfectly with the nails supplied with the gun. We purchased more Bostich nails and they are making a U-turn in the wood and coming back out. This is...
I would check first for the proper guage nails that you bought and then what is the capacity of the tool. You didn't specify the model number but I would think one or the other. then also check for the wood being nailed into. All could lead to your problem.
Feb 20, 2011 | Air Tools & Compressors
I just bought a used Bostitch Coil Nailer. 3 1/4" nails work fine but the 2" nails will not keep feeding.
Check the spacing of the nail collation between the two nail sizes and also the spacing of the copper wires. Some nailers have a different setting for the check paws on the latch door to compensate for the thinner nails (too much clearance between the latch door and body of gun). Check manual at www.bostich.com for proper setting of check paws between nail types. Good luck
Oct 12, 2010 | Stanley Bostitch Coil Framing Nailer
N100 framing nailer does not retract piston
Try oiling it. That is the most common problem. Also, make sure you are using the correct nails. If they are not genuine Bostich nails, try them.
Nov 28, 2009 | Stanley Bostitch Coil Framing Nailer
Jul 28, 2009 | Stanley Bostitch Coil Framing Nailer
The driver is not going back up after shooting nail.bostich coil framer
Jul 21, 2009 | Stanley Air Tools & Compressors
Problem accessing nails
Hi, No you can't. They are two different feeds. The F33 uses tape feed and the N79 uses stick feed. The N79 is a basic wood frame nailer that uses 3 to 3 1/4 sticks, while the F33 uses up to 2 1/2 paper feed. The stick nails are the most common for the older nailers and on the box look for Bostitch as the brand to fit, as the N79 was sold under that brand not Stanley. This should Fixya!
Mar 02, 2009 | Stanley F33PT Paper Tape Framing Nail
Bostich nail gun plumger not retracting
spay with pb blaster while rapid firing gun into a piece of junk material , once free oil with a small amount of hold or sewing machine oil and then oil after each use
Nov 27, 2008 | Heavy Duty Stanley Bostich Heavy-duty...
Stanley Bostitch Coil Framing Nailer Logo
Top Stanley Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Mike
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
