Question about Dell Vostro 1710 Laptop
Can not insert CD into Drive
My Dell Vostro 1710 laptop has a slot in CD drive meaning there is no tray. I can not insert any CD's in to the laptop. There is no CD inside the laptop either and no CD tray meaning I can not fix this by poking a paperclip through the hole. What can I do?
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 49 Answers
You can flip the laptop over, find the screw(s) holding the drive in the bay, remove the screws and the drive, and then either attempt repairing the drive (highly likely not to be worth the time), or breaking down and buying a replacement that does have a tray. Old laptop parts can be quite expensive, but CD-ROM drives in laptops old and new are often quite widely compatible among many makes and models.
Posted on Jun 01, 2014
  • Core-Lations
    Core-Lations Mar 10, 2015
    I did some testing on a CD/DVD drive of the same design as the drive in your laptop. As explained in another answer to your question here, it could be that the lens inside the drive is very dirty and needs to be cleaned. Should you choose to try this, I have had the best results from General Electric optical disc cleaners. Assuming your drive is not physically inoperable, then I strongly suspect you are experiencing an insufficient supply of power to the drive, which can be fixed by re-seating the drive firmly to ensure a solid connection between the gold contacts one the drive and in the bay. If it is a power shortage issue but re-seating the drive in the bay is not the problem, either the drive has failed or another piece of hardware between the drive bay and the laptop's internal power supply has failed or is failing.
  • 36 Answers
SOURCE: my dell d610 laptop cd/dvd drive not working
the drive has one lens, that works for both cd's and dvd's. when it reads a dvd it uses a higher light frequency, however when reading a cd it will use a lower light frequency. the lens is most likely dirty, which is why the high frequency light aka dvd is working but not the low frequency light aka cd. a specialized lens cleaning cd may be needed. or if you want to do it manually open the drive exposing the lens, then get a q-tip and some rubbing alchohol. dip the q-tip in the rubbing alchohol and rub the lens gently in a circlular motion. then turn the q-tip over to the dry side and do the same to dry it. thank you for using fixya!
Posted on May 04, 2009
rulds2008
  • 3866 Answers
SOURCE: CD ROM has disk but this will not eject - there is
Cd-rom will need to be extracted from unit the pinhole is lickly on the back of the unit most are. good luck please do leave postive feedback ether way for your free answer today.
Posted on Nov 17, 2009
Wins411
  • 166 Answers
SOURCE: my dell vostro 1710 laptop computer screen is black.
First, try reseating the memory modules in the laptop.
If still nothing, try removing the hard drive, CD/DVD Drive, and memory one at a time (in that order) see if anything makes it boot.
Replace the parts and try booting again.
The error flashing means a processor failure. If you are knowledgeable you can try re-seating the processor.
However, if your unit is in warranty I would call Dell and have them replace the main board and the memory modules as a set. Warning: They will make you go thru these same tests even if you already have.
Posted on May 04, 2010
  • 356 Answers
SOURCE: dvd will not eject from slot drive of dell vostro 1510
Restart your computer and enter set up bios. Try ejecting your dvd rom from there... it that doesn't work, get a pin and insert it in the pinhole on the dvdrom whuile pressing the eject button... that should do the trick!
Posted on Jun 03, 2010
  • 305 Answers
SOURCE: Hi, I have a Dell
Take a paper clip and straighten it. Easy goes - insert it in the small hole in the tray, just a little at a time. When you start to feel resistance, gently push a tiny bit more, and the tray will open. But do remember - be careful, don't just jam it in or you may damage your DVD as well as your tray. Sounds like you may need to have a new drive installed.
Posted on Aug 22, 2010
CD can not be inserted into the CD drive of laptop.
did you try to eject it thru the software ? Go to your (My Computer) and open up to see the Drive. Right Click and Eject. If that don't work you can manually put a paperclip in and Pull out the drive. When all else fails remove the screw that is holding the drive in the laptop and pull it out to inspect it for damage
Apr 18, 2014 | Dell Vostro 1710 Laptop
CD drive wont let me insert CD
Loading mechanism fault. In most cases, the CD ROM might be replaced. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magzine" will make surf easy Pull up older posts. Surf the site with patience.
Dell vostro 1710 won't start after bios update
Assuming you did the correct bios update, you may need to remove the CMOS battery for about 30 seconds and then replace it.
Jul 05, 2012 | Dell Vostro 1710 Laptop
A CD got struck in Dell Vastro 1310. How to eject it without dismantling. Please help
Usually there is a small hole in the face of the cd drive.
Insert a straight pin and push until the tray opens.
Aug 27, 2011 | Dell Vostro 1310 Laptop Computer PC...
Forgot my hdd password for dell vostro 1710 laptop
It probably would be easier to reformat the hard drive and start with fresh install of windows to get around this problem, only other option is go to www.ebay.com type laptop and password, and narrow it down to hdd password. There are sellers that offer software to deal with this problem, but the disc is only good so long as you can set the boot order first for the cd/dvd driver and the software must match your operational system.
Jan 24, 2011 | Dell Vostro 1710 Laptop
My Packard Bell (bought May 2010 new) laptop has a screen flicker problem. For the past week, every now and then the left half of the screen, or sometimes the bottom half of the screen, gets distorted with...
<font size="3"><i><span style="FONT-FAMILY: Arial; COLOR: #cb0101" lang="EN-US">4400mAh, 11.10V</span></i><span style="FONT-FAMILY: Arial; COLOR: #333333" lang="EN-US"> Dell Vostro 1710 Battery Replacement<span style="mso-spacerun: yes"> </span></span></font><span class="redfont1"><b><span style="FONT-FAMILY: Verdana; FONT-SIZE: 16.5pt; mso-bidi-font-family: Arial" lang="EN-US"><font color="#cb0101">$ 72.58</font></span></b></span><br /> <span style="FONT-FAMILY: Arial; COLOR: #333333" lang="EN-US"><font size="3">Dell Vostro 1710 Battery</font></span><br /> <span class="htmlval1"><span style="FONT-FAMILY: 'Courier New'" lang="EN-US"><font size="3"><font color="#0000ff">Discount Dell Vostro 1710 Battery 11.1V 4400mAh,fit for Dell Vostro 1710, Dell Vostro 1720 Laptops.Full 1-year warranty and 30-day money back!</font></font></span></span><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">ShippingArea:</span></b><b><span style="FONT-FAMILY: Verdana; COLOR: #cc0000; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">We ship all over the world!</span></b><b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US"></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Brand :Dell Vostro 1710</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Type :Li-ion</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Voltage :11.10V</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Capacity : 4400mAh</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Ltem(Cell):6-cell</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Color :Black</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Dimension :270.90 x 50.00 x <st1:chmetcnv w:st="on" tcsc="0" numbertype="1" negative="False" hasspace="False" sourcevalue="20.2" unitname="mm">20.2mm</st1:chmetcnv></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Weight :<st1:chmetcnv w:st="on" tcsc="0" numbertype="1" negative="False" hasspace="False" sourcevalue="665" unitname="g">665g</st1:chmetcnv></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery SKU :DE017K</span></b><br /> <span lang="EN-US"><a href="http://www.battery-sale.net/dell-vostro-1710-battery.html">http://www.battery-sale.net/dell-vostro-1710-battery.html</a><span style="mso-spacerun: yes"> </span></span>
Aug 27, 2010 | Computers & Internet
Dvd will not eject from slot drive of dell vostro 1510
May 24, 2010 | Dell Vostro 1510 Laptop
My dell vostro 1710 laptop computer screen is black.
May 04, 2010 | Dell Vostro 1710 Laptop
CD ROM has disk but this will not eject - there is no little pin hole on the vostro 1710 anywhere, nor does hitting eject from the Bios screen work....
Nov 17, 2009 | Dell Vostro 1710 Laptop
CD ROM is in the 1710 but system does not recognise disk and now will not eject. I have tried from the BIOS screen but no luck....
First get the cd out. On the side where the cd tray is there should be a little pin hole. Stick a pin in gently and that should release the cd tray and eject the cd. Then try updateing your cd rom drivers, uninstall and reinstall....
Nov 16, 2009 | Dell Vostro 1710 Laptop
Dell Vostro 1710 Laptop Logo
Alun Cox
