Question about Nikon D40x Digital Camera
My Nikon dx40 camera stalls and only sometimes takes photos
I have had no problems with this camera and have had it over 12 months, never dropped it etc. i go to take photos and sometimes it works and then i have a period where it won't. I hear a buzzing sort of noise, sort of like it is trying to focus but won't work, especially when i am trying to take a photo of a certain object. I took it to a camera place this morning and he really had no idea and said it may be the software? this doesn't make sense to me? what do i do now? is it broken? i can't afford a new one.
  • 583 Answers
Its a ver common problem the battery you are using is not good.its working but is at the end of its life.many a times when battery cannot function properly resulting in less power to the camera then what is required.the camera cannot work properly and makes buzzing or crackling sound. in that case replacing the battery will solve the problem.also check the lens part which moves in and out.--sometimes the lens is **** up and jammed and this can also cause the camera to not work properly.but the 99% chances are of faulty battery.
thanks for using fixya.keep updated. please do not forget to accept and rate this solution positively.
Posted on Jun 19, 2009
  • k8yfitz Apr 18, 2011
    My camera is doing the same thing. Sometimes I have a great picture set up and I press the button and it just creaks at me. And it won't take the picture. If I step back or point it at something else it won't take the picture. Then 5mins later its fine. Is there any way of testing the battery or is it worth just buying a new battery in the hope that is what it is?
My nikon D5200 seems as if its flash and shutter speed is out of time resulting in my photos being to dark to see or to bright to see
check to make sure auto bracketing is not turned on. Otherwise send it to Nikon as it is under warranty (assuming you didn't drop it etc)
Jul 10, 2013 | Nikon Cameras
Can someone help me on my nikon D3100 freeze problem?
New battery that is fully charged. My Nikon D3100 has had the problem of freezing every ten or so pics since it was a couple of months old. Still does it today after six months of use. I take a few hundred pics with it when shooting but only shoot once or maybe twice a month.
Have to take the battery out, put it back in etc. each time. Sometimes it allows me to power off and then back on but either way it's a pain in the rear and a serious "time waster".
Feb 12, 2012 | Nikon D3000 D3100 18-55mm
Freezing of camera - only way to turn off is to remove battery.
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jul 03, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
LCD screen and pictures go completly white
The camera is defective. But as you've only had the camera three months it still is under warranty. Canon is usually very responsive to these type of problems and will bend over backwards to make things right (probably the most responsive of the camera companies).
Call 1-800-OK-CANON to resolve this issue.
May 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
Dropped my camera in a pool of water in a glacier 12 months ago. I immediately took out the battery and memory card. I then spent 2 hours with a hair dryer drying the camera. Since then the camera has...
There is no relation between the two incidents that you explained. The recent problem might have occurred due to damaging of the lens. MY solution is to replace the objective lens ( lens assembly) and the motor ( if needed ). If it costs much, then go for a new one, since digital camera with high pixels rates are available cheaply now a days.
Mar 30, 2009 | Canon PowerShot S500 IXUS 500 Digital...
Photos missing
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
You will need to use a flash card reader with this software. If you don't have one, get one, they're cheap:
http://www.amazon.com/s/ref=sr_st?keywords=card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Acard+reader&sort=price
Apr 15, 2008 | Canon PowerShot SD600 Digital Camera
Panasonic DMC FZ18 2gb digital camera: consistently crashes when downloading images to PC (Windows XP): e.g. will detect 40 images for download, but will only download the first 10. Switching the camera...
try using and SD card reader instead of the software that came with it. then you know if it is a software issue or a problem with how your camera saves the photos.
It's also quicker using an SD card reader and drag/drop - copy/paste etc.
Mar 10, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Pictures overexposed in daylight, visible lines in photos
1. Adjust ISO or ASA 100
2. Adjust AWB Indoor florescent or Bulb while outdoor select sunny or foggy it depends of the place
Dec 25, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
LCD not showing view of image to be taken
Nikon Techical Support the quickly this is a CCD or associated component failure
Jul 22, 2007 | Nikon CoolPix S2 Digital Camera
Camera won't take pictures.
Only six month old - warranty claim then. Check out the Tech support at Canon website first.
May 28, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Nikon D40x Digital Camera Logo
155 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
