AC post broke
The male pin for recharging is broke. Do I need to replace the whole motherboard or can it be a relativley easy fix? Or should I just purchase a new laptop?.......Bruce
  • Buddy Mcsparrin May 11, 2010
    What brand and model laptop do you have?
    Novelist:
    Champion:
  • 256 Answers
Dear Bruce;
Unfortunately the computer industry is a little bit better than the automotive industry. I thank God that I am not a automobile mechanic and I have seen some very smart and well accomplished mechanics. The mother board is not made to be repaired for the desktops and more so for the Laptops. Now, you seem to be a reasonable man and my reasonable thinking is that you throw nothing away as long as you can keep them working. How do you know if the next new equipment you buy will not be a lemon. So, you have examined the male pin for recharging, you already have found that the damage is not that much, it will not fall out within some time. We are lucky that the voltage that point is not that much. I would say give another visual and if you are satisfied, fix it and see how much life you can get out of it. Always keep an active back up of the unit, just in case, even though data loss happens when the program is in the RAM memories. Fix it up and be proud of your accomplishment. If there are funds available, figure a time that it would be wise to have a reserve. Run your computer until the battery burns up or the "wheels fall off". May the Lord bless you! My name is Constantin (arzconst is my internal nickname with the Fixya.com).
Posted on Jun 19, 2009
I need to buy a 16 pin molex connector
FYI, post your question in the right section, this is a courtesy to yourself since the people looking at this section are computer people not electricians. I would ask on this forum, sounds like they may even fix for you for the cost of shipping and handling. http://www.reefcentral.com/forums/
Jul 12, 2012 | Molex Computers & Internet
One of the male pins on the unit for the antenna broke off. Is there a part that I can get to fix this, maybe the whole male pin unit is one part?
Hello, is the broken pin on the back of the unit or is it on the antenna cable plug? If it is on the unit and not the cable, you would most likely need to replace the connector that is attached to the PC board inside, which extends through the back of the case. This would require knowledge of soldering / desoldering pc boards, etc. and would be best performed by a "bench technician". There are no "user replaceable" plugs available.
Feb 17, 2012 | Standard Horizon Cp180 Chartplotter
My belt siezed and broke off earlier there was a grinding rattle in engine for past few days and my ac hasnt worked for more than a month
grinding noise was probably a bearing in ac compressor, when it froze up completely it stopped turning causing extreme wear on the belt ..so it broke... check ac compressor out , could be bearing only ..could be whole compressor ..have it fixed...when compressor is removed the hoses have to be disconnected of course so if it still has refrigerant in it, that will need to be recovered at a shop..the ac system will have to be vacuum pumped down and recharged anyway.
May 23, 2011 | 2000 Saturn Ls 4dr Sedan
I have a Schumacher WM-10000A speedcharger and the ground pin on the male plug (built into the unit) has broken off. I need a replacement male plug for this unit. It has been a great charger and I cannot...
Too easy...go to any of the DIY stores, Lowes or the Depot, or your local hardware and pick up a male end for the cord. It's an easy installation, will take you MAYBE 10 minutes.
Jan 27, 2011 | Schumacher & Fast Charge Starter Charger
2pin male connector of the motherboard (261671-001) purpose?
the switching power supplies are fun, by 2 pin plug is that from the AC side or computer side?
from AC side its easy enought to go buy another plug thought it should have come with one.
i cant remember any 2 pin plugs on the computer side and i have taken quite a few of these apart. there is a four pin plug...
wire colors,
yellow 12 volt
black ground
red 5 volt,
if the old supply was any of those colors you can desolder from the old supply and re solder it onto the new supply. if it was another color then i would suspect a random signal wire or cutout, keep you from frying yourself with the case open... try plugging up the new supply and turning on the computer if it runs why worry about it?
Jun 10, 2010 | Compaq (261671-001) Motherboard
Pin inside ac charger broke off inside my dc power jack
i highly recommend u find a way to remove the pin as u would struggle to find a dc power jack for the hp mini 2140 motherboard ,if u manage to get the pin out ac power chargers are quite resonable on some internet auction sites
Mar 11, 2010 | HP Mini 2140 Notebook
Bad AC adapter port
The majority of HP laptops I've worked with have had the DC socket "on-board".
But, don't worry about having to replace the whole motherboard as you can now purchase an new DC socket for the laptop and solder it in yourself. Or you can just take the laptop to a reputable PC repair store and have them fit you a new DC socket.
This is a very common problem with all makes and models of laptops (except Apple Mac's) and i have replaced plenty of them.
Please post back if you need anymore help.
Regards.
Jan 14, 2010 | HP Compaq Presario V2000 Notebook
Power problem
If you are sure about Power pin is broken an expert technician can assist to get it fixed [instead of replacing the mother board]
Best Regards
Rafique
Feb 19, 2008 | HP Pavilion ze5185 Notebook
Computers & Internet Logo
41 people viewed this question
Alun Cox
David Payne
David Payne
