Question about Samsung DCS 12 Corded Phone
How to get ring tone from the phone - Samsung DCS 12 Corded Phone
How do I delete unwanted ringtones to save storage space
go into phone settings look for sound open the folder, find phone ring tones, select your options.
now if you have ring tones for friends than you have to go into the database or friends ring tones select regular ring tones.
Sep 18, 2015 | Cell Phones
How do I change the ring tone on my Uniden phone
Selecting.Ring Tones (Handset Only)
You.may.choose.from.10.melodies.or.10.tones.for.your.phone's.primary.ring.tone..Each.station.can.use.a.different.
ring.tone.or.melody...The.available.ring.tones.are.listed.below:
Melodies Ringers
Beethoven's.Symphony.#9.[Beethoven9] Flicker
For.Elise.[Elise] Clatter
We.Wish.You.A.Merry.Christmas.[Merry-.Xmas] Soft.Alert
Home.Sweet.Home.[Hm.Swt.Hm] Wake.Up
Lorri.Song.#6.[Lorri.Song] Light.Bug
When.Irish.Eyes.Are.Smiling.[Irish.Eyes] Beep.Boop
Aura.Lee.[Aura.Lee] Tone.Board
Let.Me.Call.You.Sweet.Heart.[Sweetheart] Chip.Chop
Star.Spangled.Banner.[Star.Spngl] Party.Clap
Old.MacDonald.[Old.MacDld] Reminder
Press.[menu/clear].
Select.the.HANDSET.SETUP.menu,.and.then.
the.RINGER.TONES.submenu.
Move.the.cursor.to.a.ring.tone..As.each.ring.tone.is.selected,.you.
will.hear.a.sample.of.the.ring.tone.
When.you.hear.the.tone.you.want.to.use,.press select. ..You. will hear a confirmation tone.
Oct 03, 2014 | Blueant BLUETOOTH TTS SPKR NIC
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
No ring tone on my Sony Ericsson 580i
to set a ring tone in your phone, you must first go to any profile, open it, then select the ring tone option. from there you can select the ring tone you like.
Dec 08, 2009 | Sony Ericsson w580i Cellular Phone
My phone is not ringing on incoming calls
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from oter phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Jul 15, 2008 | Nokia 1600 Cellular Phone
Ring tone
1. to set mp3 ring tones...
copy any mp3 file to phone ( via cable or bluetooth )
go to multimedia = go to mp3 = now play the song you want as tone,
when song is playing, select options, and select = set as ring tone
DONE and smile......
2. to set Default sound ring tones...
go to menu = my stuff = sounds =
browse the sound files when you like one , select options, and set as ring tone.....
Done and smile again... hope this helped...
May 13, 2008 | LG KG800 Cellular Phone
MOTO PEBL MESSAGE AND RING TONE
i think this is what you're going for...Go to SETTINGS, then RING STYLES. Whatever ring style (ie, vibrate, silent, vibe & ring, vibe then ring, loud, soft), underneath is the detail for it, which you can then change (bottom right of screen).
So right now my phone is:
"Style: Vibe & Ring" and underneath that is "Vibe & Ring Detail"
Under the details, you can change your ring tone by scrolling down to the "Calls" option and choose change (bottom right of screen). And to change your message tone, just go to "Messages" and then change (bottom right of screen).
Hope that helps!
Apr 08, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Assigning ringtones to a profile
If you set the profile ring tone to OFF. Then select a contacts' number and assign it a Ring Tone. When that contact calls you the Ring Tone you assigned will ring.
If you select the same Ring Tone for all your contacts in a group they will all sound the same when they call.
Or select the same ring tone for a profile, but cancel the Tone you assigned to the contact(s).
Feb 02, 2008 | Nokia N70 Cellular Phone
Telephone ring tone
press flash on phone til you reach desired ring tone then pick up headset to set
Sep 26, 2007 | Innovage 1604007 Corded Phone
Samsung DCS 12 Corded Phone Logo
26 people viewed this question
Top Samsung Lands Phones Experts
richie46
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
