Question about Metra CHTO-02 Chrysler Pacifica 04-Up Radio Interface
Where is factory radio amp located in a 04 chrysler pacifica
2 Suggested Answers
clifford224
  • 1975 Answers
SOURCE: where is pacifica factory amp located
There are a couple of different systems. There are 2 pictures below that should help..............
Posted on Dec 07, 2012
Where is pacifica factory amp located
Dec 07, 2012 | Metra CHTO-02 Chrysler Pacifica 04-Up...
My 04 pacifica radio, heater, dvd won't play, no
Check your relays the accessory relay right hand upper corner and the run relay middle left side if they are the same relay switch them and see if that works if not could be the body control module. Realys under hood to the right of the battery
Nov 13, 2011 | 2004 Chrysler Pacifica
Where is the alternator located in the chrysler 04 pacifica/
The alternator is hiding under the engine cover. You must remove the engine cover if you have one. Locate the power steering fluid resevior. The alternator is right behind it.
Oct 24, 2010 | 2004 Chrysler Pacifica
No sound everything eles works
More than likely your pacifica has a factory amp. To turn it on it requires a digital turn on from a factory radio. You will have to rewire the speakers to your new radio and bypass the amp and you should be all set.
Jul 05, 2010 | Metra CHTO-02 Chrysler Pacifica 04-Up...
I have no sound. Radio is on, CD player works
The antenna lead you are using to turn on your amp is dropping out when your cd is coming on try using the blue/white stripe wire instead of the blue for turn on.
May 09, 2010 | Metra CHTO-02 Chrysler Pacifica 04-Up...
Radio works intermittenly,Sometimes all day,Then not at all. I have replaced Amp..Worked great for a few days.You think its the radio head unit?
had same problem in a dodge... turned out the interface module was bad. but try a relay on the amp trun on lead. there may not be enough power to trigger the factory amp
Feb 10, 2010 | Metra CHTO-02 Chrysler Pacifica 04-Up...
What type of battery do i need for a 2004 chrysler pacifica
For a general battery seletion guide, I checked Sears.com and came up with this page:
http://www.sears.com/shc/s/s_10153_12605_Automotive_Batteries+%26+Chargers_Automotive+Batteries
It showed 6 results for a FWD '04 Chrysler Pacifica - but there's also an AWD option for that vehicle and I'm not sure what type you have.
If that link does not work you can locate the battery selection guide by going to:
Sears.com
and from the left menu selecting in the following order...
Automotive > Batteries & Chargers > Automotive Batteries
Jan 12, 2010 | 2004 Chrysler Pacifica
I get sound from the radio briefly, but then all sound stops and doesn't come back until the car has been turned off for a while.
this a problem which can be repaired by a specialised technician . If you are a technician , your radio has a problem in power supply . the capacitor have to be replaced . that capacitor is located in radio where the battary is connected inside the radio
Aug 14, 2009 | Metra CHTO-02 Chrysler Pacifica 04-Up...
Metra CHTO-02 Chrysler Pacifica 04-Up Radio Interface Logo
46 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
