Question about Onkyo M-282 2-Channel Amplifier
Connecting an onkyo m282 to a vintage (1994)onkyo tx905 receiver
How can I use the 905 to control the sound? The has outpout for two sets of speakers, tape 1 tape 2 outputs and video inputs and outputs.
  • dproulx77 Jun 20, 2009
    I have found the solution.
    Using an Audioplex SPKCNV Speaker Level To Line Level Converter should resolve the connection issue.
Posted on Jun 20, 2009
Onkyo HT-R693 (HT-S7700) receiver will play video but no audio on Netflix and YouTube. However, sound comes through when connected to Comcast cable and even Pandora. I have tried the different channels...
  • Check your cable connections
  • set the input selector to the proper component sources your using.
  • set your speaker settings to either 5.1 or 7.1, according to your speaker configuration via Onkyo's AccuEQ automatic setup tool- because the same binding posts can be used for hooking up the Atmos height or surround back speakers; you'll need to tell the Onkyo system which setup you're using.
Mar 08, 2015 | Onkyo Audio Players & Recorders
DISPLAY STAYS WITH THE ONKYO DISPLAY AND THATS IT
The video card to your Onkyo is OK, as it displays the Onkyo Logo. Contact the authorized service center for Onkyo. A firmware update is necessary. With a Corrupted firmware, this kind of display effects can occur. Gopakumar Gopalan Google
Feb 28, 2014 | Onkyo TX-NR905 Receiver
Speaker buttons don't function correctly
The Speaker A and Speaker B buttons select pairs of speakers. If you have connected a pair of speakers to the "SPEAKER A" terminals on the rear of your Onkyo receiver, you will hear stereo sound when the Speaker A button is pressed on the front panel. If, for some reason, you wanted to connect a second set of speakers in the same room or perhaps another room you would connect those speakers to the "SPEAKER B" terminals on the rear. Pressing both buttons on the front panel would send sound output to both sets of speakers
Jan 17, 2013 | Onkyo Quartz Synthesized Tuner Amplifier...
I have just set up my onkyo 5305 i only have sound to front speakers have checked connection but im lost now in the settings
Onkyo are known for having 2 seperate connections for the rear speakers. 1 set for a surround sound, channel "A", and 1 set for seperate set a speakers, channel "B". check for the second set of connections. Also, your only gonna get sound out of the rear speakers thru surround sound mode when the unit actually sends singal. The sound is determined buy what setting you have the receiver set to.
Mar 06, 2011 | Onkyo HTP-102 System
Sound won't play through Onkyo TX-SR605 when using HDMI
The chances are that you have selected an incorrect sound setting or not switched it on, for the HDMI you are using. With Onkyo receivers each connection will have it own settings for video and sound. You just need to look in the manual as to how to select the settings.
May 08, 2017 | Onkyo TX-SR605 Receiver
Bose 901 hookup with Onkyo SR 805 and Onkyo M282 amp and 901 EQ/
The good news. I have a setup similar to what I think you're trying to do and it works great!
The Onkyo M-282 stereo amp for the 901's is the perfect solution. Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
**Onkyo SR805 Pre-Out Front >>> Bose EQ Amplifer IN
Bose EQ Amplier OUT >>> Onkyo M-282 IN
Set the Input Level on the back of the Onkyo to MAX. The receiver controls everything just fine after you run through your level setup routine again.
I was looking a the 12v triggers on both units and it looks like you only have a Zone 2 trigger so that wouldn't work for turning on your M-282. I guess you're going to have to turn it on and off the old fashioned way, like I do mine.
Mar 15, 2009 | Onkyo TX-SR705 Receiver
HELP: Onyo Remote Does Not Recognize Receiver when using Cable
Since you have the cable connected to the reciever thru the HDMI, you may have accidently changed the input source of the reciever from HDMI or digital to analog.
When you have the reciever set to listen to the cable, check the input mode and make sure it is set to use the HDMI or digital input and not the analog.
The rca jacks are analog, and they worked, so I think you have just solved your own problem without realizing it.
Let me know if this works and if so a good rating would be appreciated. Thanks and have a great day
Jun 16, 2008 | Audio Players & Recorders
Onkyo 605 HDMI Sound
Change the setup in the Hardware control/HDMI/ HDMI Audio...
Jan 17, 2008 | Onkyo TX-SR605 Receiver
No sound
Onkyo is a piece of shit! I had the same f'n problem....
Junk...............
Dec 16, 2007 | Onkyo TX-SR604 Receiver
Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Aug 14, 2007 | Onkyo TX-SR500 Receiver
Onkyo M-282 2-Channel Amplifier Logo
365 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
