I have a H2ow To, HT-20 Pre charged water system tank with a new switch housing. The unit is connected to a Myers Pump. The pressure reads 21psi. The pump starts and begins action but does not pump water, the pumping action stops without water delivery. What are some possible problems and corrections?
leecom72
  • 4806 Answers
SOURCE: Battery will not stay charged
Before you replace the battery, put the charged on back in again to see if that on charges. If it does then the original problem will have been a defective battery.
Regards.
Posted on Aug 20, 2009
freetek
  • 5568 Answers
SOURCE: leaking from underneath pump could it need new
A notebook with water cooling? Neat!
I figure however that you really wanted to know about a water pump in a vehicle. Buy a rebuilt water pump since most have been pressed together and replacing an individual O ring is often not practical.
That leak was designed in so when the inevitable happens, the coolant runs out and gets no chance to invade the oil system.
Posted on Oct 27, 2009
falspet
  • 438 Answers
SOURCE: We have an 1hp jet pump pulling water from a
depending on the motors style of start-up, if you have a centrifugal type of start winding switch, your motor may be trying to start on the run winding due to a defective contact on the centrifugal switch, if it is a capacitor type starer, you might have a defective capacitor once again the motor is trying to start on the run winding, a way to find out is to be there and listen to the motor when it tries to start and trips the barker, if the motor emits a loud humming noise you have a fault with the start-up winding control device, if the picture supplied with your post is correct the capacitor is the long cylindrical thing at the top of the motor, you can remove this and bring it to a motor shop, they can test this for you
Posted on Apr 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: grundfos mq3-45 pressure booster pump
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
SOURCE: the ignition light flashes on
j skinner508
I have exactly the same problem with the same model of Vaillant as you. Two plumbers have not solved the problem so, like you I am still looking for the answer. If I have any luck I'll let you know
adrian994
Posted on May 08, 2011
I just installed new water pressure tank,it builds pressure to max then water runs low on pressure till pump kicks back on.whats wrong
Have to set the pressure switch
(instructions are under the cover)
65 # cut off
42 # cut in
Should install a new switch every ten years
& a new check valve before the tank & manifold
assy every 20 years
Oct 25, 2014 | Water Worker 44 Gallon Vertical Stand...
Working pressure
Putting 60 lbs. of pressure in the pressure tank is not the answer.
First determine that the pump is working correctly, Open the drain valve and see if you get a good flow of water. If you do then OK, the pump is working. If you are not getting a good water flow from the drain valve, then the pump is not operating correctly - maybe a bad foot valve. Next open the drain valve and watch the water pressure gauge, and note at what pressure the pump kicks on ( that's the cut-in pressure), and when it kicks off ( that's the cut-out pressure). Most pumps are set to operate at 20-40 psi, or 30-50 psi. The cut-in and cut-out pressure is set by the water pressure switch.The pressure in the water tank has to be set 2 psi BELOW the cut-in pressure of the pump. That is, if the pump has a 20-40 psi differential, then the tank has to be pre-charged to 18 psi.
To pre- charge the pressure tank , the pump has to be shut off. The Tank needs to be emptied (drained ) of water. The air pressure is then set to 2 psi BELOW the cut-in pressure. If water escapes from the air valve, the bladder in the tank is ruptured, and a new tank needs to be installed.
So, first make sure the pump is working.
I WOULD RELIEVE MOST OF THE PRESSURE IN THE PRESSURE TANK TO ABOUT 20 PSI BEFORE CHECKING THE PUMP, AND PRCEEDING WITH THE PRE-CHARGE OF THE TANK.
May 24, 2014 | Plumbing
We have a well and our water pressure keeps changing, from very low, to blasting... irregular, no pattern
You could have two problems. The first and most likely is that the pressure tank does not have a high enough pre-charge or the diaphragm has a leak. The pressure tank acts like a shock absorber for the well pump and pressure switch. When the water pressure drops the switch turns the well pump on. The pump runs until the pressure switch stops the pump. As the water pressure builds it pushes up on the diaphragm inside the pressure tank. If the pre-charge pressure is too low the system cycles less but the pressure fluctuates more. To fix this, the tank will have a valve on top that looks like a tire air valve. The tank pre-charge should be 30-35 psi. If your pressure switch is working properly, when the pump builds up the pressure about 15-20 psi more, the switch shuts the pump off. The pre-charge above the diaphragm pushes down and forces the water out to the tap.
If the pressure switch is set incorrectly the fluctuation may produce similar results. The pressure switch should be set to deliver adequate pressure and according to the well pumps working limits. Depending on the how far up the water has to be elevated to reach the highest shower head the more pressure is needed. The pressure switch has electrical contacts that could be burned and not releasing to stop the pump correctly. This should be checked by qualified service technician. Electricity and water don't play well together, add in a little carless good intent and you could have worse problems.
Get out the pressure gage and check the pre-charge, add air with a bike pump or a regulated compressor. If water spurts out of the air valve, the diaphragm has a leak. If the pressure is not the problem, call for service. This video has all the info you may need.
Components Of Typical Well Water System
May 22, 2014 | Plumbing
I have a new 1 hp utiltech pump and a new. Precharged tank with 34 psi in it now. When i prime the pump the pressure goes right to 25 psi and i can hear some water moving . When i open the shut off valve...
The 34 psi of the pressure tank sounds high, but it depends on what the cut-in pressure is set at in the pump pressure switch. Typically the pressure switch is for 20-40 psi or 30-50 psi. To establish what the pre-charge of tank should be , you need to establish what the pressure switch setting are (i.e 20 - 40 psi , etc.) Run the water and watch the pressure gauge and note at what pressure the pump comes on. The pressure tank needs to be pre charged 2 -4 psi below that cut-in pressure. So if the cut-in pressure is say 30 psi, then the tank needs to be pre charged to 28 psi.
To pre charge the pressure tank, turn the pump off. Drain the pressure tank of water to relieve all pressure in the tank. Then check the pressure of the tank at the air valve. Set the pressure to 2 psi below what the cut-in pressure is.
If you adjust the pressure switch, say from 20-40 to 30-50, you will need to go through the procedure of re adjusting the pressure in the tank. I hope this helps....
May 21, 2014 | Plumbing
Low water pressure how do i increase the pressure
The water pressure is adjusted with the pressure switch, which turns the pump on and off. The pressure switch is typically set for a cut-in and cut-out pressure of 20-40 psi, or 30-50 psi. Usually there are adjustment directions on the inside of the switch cover. But, there are several other factors that may affect the house pressure. If there is a pressure tank that is pre-charged, the tank pressure may need to be reset, or the tank bladder may be ruptured. Have the entire system checked out.
Apr 21, 2014 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
Problem with pump?
The pump pressure switch should be checked to see what the ON-OFF pressure is set at. Typically the pressure switch is set for 20-40 psi, or 30-50 psi. The pressure tank should be purged as well. With the pump OFF, and the tank drained of water, the air valve on the tank should read approximately 2 psi below the "on pressure". So if the system operates at 20-40, the tank should be pre-charged to 18 psi. If water escapes from the air valve, the internal bladder in the tank is ruptured, and the tank needs to be replaced. A tire air gauge is used to measure the pressure in the tank after the water is emptied from the tank.. A tire air pump or a compressor is used to charge the tank. if a compressor is used, be careful not to over-inflate the tank, as this may cuase the bladder to rupture.
Apr 14, 2014 | Utilitech Plumbing
Pump not holding presure
If you have a bladder - type water pressure tank, it probably needs to be purged of air and then pre-charged to 18 psi. There may be directions on the side of the tank. Turn the water Pump off. Drain the tank of water. Check the pressure of the tank at the air valve on top of the tank. The pre-charged pressure of the bladder is set to 2 psi below the lower pressure set by the pressure switch, so in your case, the low end pressure is 20 psi. Therefore, the pre-charge pressure of the tank is 18 psi. If you set the pressure switch to operate at 30 -50 psi, then the pre-charge pressure would be 28psi., etc. Once the pre-charge pressure is set, turn the pump back on. ( don't forget to close the drain valve). The system should cycle normally. A tire gauge works to check the tank pressure. An air compressor may be used to charge the tank, but be careful not to over- inflate the bladder. A tire air pump may also be used. Hope this helps....
Apr 06, 2014 | Utilitech Plumbing
How does pressure tanks work
Pressure tanks do just that in a water system. They create pressure for water to flow when the water pump is on the off cycle. A manifold is plumbed into the tank from the main line coming from the well. The main water line continues to the house plumbing from the manifold. So it's line from pump to manifold - to tank, and from manifold to main into house. The manifold also has tappings for the pressure gauge and the pressure switch. The pressure tank creates water pressure. The water does not flow through the tank. Pressure tanks also have to be 'tuned' or adjusted to the low end pressure set by the pressure switch. Actually the tank pressure needs to be set 2psi below the low end pressure. Most residential water systems are set to operate between 20 -40, or 30-50 psi, which is set by the pressure switch, which in turn , turns the water pump on and off. So if a system operates between 20 and 40 psi, the pre-charged pressure of the tank should be 18 psi. Pre-charged means the tank is drained of water with the water pump OFF. The tank pressure is then checked adjusted by way of the air valve on top of the tank ( A tire gauge works). Pressure tank mainfolds are a common plumbing part.
Mar 19, 2014 | Utilitech 20-Gallon Vertical Pressure Tank...
My sand point well the water stops and starts again
You probably need to purge the pressure tank.
Well Pressure Tank Installation Instructions
Pressure tanks lose their Pre Charge pressure and have to be serviced. The well Pump needs to OFF. The Pressure tank needs to be emptied of water. There should be an air valve on the tank. Check the pressure .If this is a Bladder tank and Water comes out of the air valve- then the bladder is broken and the tank needs to be replaced. The Pre Charge pressure is set to 2 psi Below the cut-in pressure set by the pressure switch. If your system operates at 20-40 psi, The Pre Charge pressure will be 18 psi. Hope this helps.....
Mar 18, 2014 | Bur-Cam Pumps 750896 Water Shallow Well...
Well-Rite WR240R makes loud noise every time water flows into it
Tank may be air bound. There is an air valve on top of tank. Take cap off and depress valve momentarily. If water comes out of valve, the bladder is torn, and new tank is needed. If no water comes out, check the pre -charge pressure of tank.
First, run water in house and take note of the on-off pressure of your pump. There should be a water pressure gauge on the water line going into the tank. Take note of the cut on pressure and cut off pressure. Most well systems typically operate at 20-40, 30-50 lbs of pressure. Next,shut off electric to pump. Drain all water from tank. Take a tire gauge and check air pressure of tank. The static or pre-charge pressure should be two lbs less than the cut-on pressure,i.e if your system operates at 30-50, then the pre-charge pressure should be at 28lbs. Adjust pressure as needed. A small air compressor is ideal to use if more pressure is needed.
Jul 15, 2009 | Plumbing
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
